DFU SDK15 CRC problem.
Hi!
nRF52832, SDK15, S132.
I try to use DFU. I already implemented same DFU on a SDK13. All works correct.
When flash SD132 and merged firmware with bootloader_setting.hex, always DFU targ started in a air.
 0> <info> app: Inside main
 0> <debug> app: In nrf_bootloader_init
 0> <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
 0> <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
 0> <debug> app: Enter nrf_bootloader_fw_activate
 0> <info> app: No firmware to activate.
 0> <debug> app: Enter nrf_dfu_app_is_valid
 0> <debug> app: Return false in CRC
 0> <debug> app: DFU mode because app is not valid.
 0> <info> nrf_bootloader_wdt: WDT is not enabled
 0> <debug> app: in weak nrf_dfu_init_user
 0> <info> app_timer: RTC: initialized.
 0> <info> app: Entering DFU mode.
 0> <debug> app: Initializing transports (found: 1)
 0> <debug> nrf_dfu_ble: Initializing BLE DFU transport
 0> <debug> nrf_dfu_ble: Setting up vector table: 0x00072000
 0> <debug> nrf_dfu_ble: Enabling SoftDevice.
 0> <debug> nrf_dfu_ble: Configuring BLE stack.
 0> <debug> nrf_dfu_ble: Enabling the BLE stack.
 0> <debug> nrf_dfu_ble: No advertising name found
 0> <debug> nrf_dfu_ble: Using default advertising name
 0> <debug> nrf_dfu_ble: Advertising...
 0> <debug> nrf_dfu_ble: BLE DFU transport initialized.
 0> <debug> nrf_dfu_flash: Initializing nrf_fstorage_sd backend.
 0> <debug> app: Enter main loop
Therefore, problem in a CRC that DFU can't calculate CRC of the app.
        if (crc != s_dfu_settings.bank_0.image_crc)
            // CRC does not match with what is stored.
            NRF_LOG_DEBUG("Return false in CRC");
            return  false;
If I changed to return true; , all work fine.
One more time, I use same merge code for get bootloader_setting.hex in the SDK13 and it wors fine.
I use example from
https://devzone.nordicsemi.com/b/blog/posts/getting-started-with-nordics-secure-dfu-bootloader
Should make any changes for calculate CRC in the SDK15?
    This is relevant information. When you place information in flash this way, the application area extends over the whole flash between the start of the application and the end of the data below the bootloader, and the CRC is calculated over the whole range. Do you for instance write any other data to flash between this regions from your application? In that case you will modify the flash within the (in this case large) application region, leading to the CRC mismatch.
  • Thanks. And what should I do for decide this problem? I only write flash data like an application and also located data
    ... __attribute__((section(".ARM.__at_0x71400"))) =
    There are no any else data.
    Should at this case correct calculate crc? Why crc calculated not correct? Or I can't to lacate data at this memory region?
  • The only reason I can think of that would make the CRC not correct is if your application write something to flash within that region. Can you let me know your flash memory layout? Does the application store any other information to flash? Doe sit use FDS or similar for something? If so, how many pages? There seems to be somthing that is different within the application flash region once your application runs compared to when you calculate the bootloader settings page of the application image, but I cannot say what without knowing the details of what/how/when/where you use the flash.
  • My flash settings:
    Yes, information stored into flash via fds. #define FDS_ENABLED 1, #define FDS_VIRTUAL_PAGES 3
    Any idea?
  • Ah, there we have it, then. You write that you use a debug bootloader starting at address 0x72000. Below there you have three FDS pages, which is 3*4*1024 = 0x3000, so they start at 0x6F000, which is below your fixed data starting at 0x71400, so they overlap. This means that when your application initializes FDS it writes to the flash area that is within the application region, which in turn will result in a different CRC (as it should). You simply have to move the fixed below the FDS pages to correct this.
