Change The Subscription Addresses Of Client In Mesh
I am working on light switch example. I am broadcasting a message from client to servers using the API access_model_publish() with the opcode SIMPLE_ON_OFF_OPCODE_SET_UNRELIABLE. there are 3 servers in total, 0x105, 0x106, 0x107. Even though message is delivered in all three servers, I am getting the status of only  two servers (0x105, 0x106). I am taking this status from the function handle_status_cb() of the simple_on_off_client.c code. Why I am not able to get the status of the third server? I guess this is because client is only subscribed to 0x105 and 0x106. I need status of two more servers. In order get the status of remaining servers what configuration should I change?
  • Hi!
    I'm sorry about the delay.
    Have you made any progress on your issue?
    I'll get back to you by the end of the day with an answer for you.
    Joakim.
  • Hi Joakim,
    Thank you for replying. I have some doubts. Hope you will be able to help. Creating new case for each of them might take some time to get answered. That's why I am asking here. I have made some progress.
    I want to make several servers to send message to client. Client should receive their uni-cast address too. I looked through node_setup.c and found that I have to change a whole lot to make that happen. I don't need group cast, just uni-cast method. Each server should send message to client with their unicast address. Is that possible?
    I have another doubt too. Is there anyway I could find the current ttl value of the node? With each hop ttl decrements right?  I want to know whether the message is initiated by current node and/or how many nodes message have hoped to get the current node.
    Can I receive a string message that I send from server to client from the function handle_status_cb() through access_message_rx_t. Or is it only possible through mesh_evt_cb()
    Thank you
    Arya
     Yes, you can use unicast address for sending messages to a particular node. You can find out how the light switch client node sends unicast messages to the server by taking a look at the button_event_handler() in the main.c file. The simple_on_off_client_set() function will send a unicast message to the first provisioned & configured server when button 1 is pressed on the client.
    The simple_on_off_client_set() then calls access_model_reliable_publish(), which is where the unicast address of the server gets retrieved via the dsm_address_get() function.
    The unicast address also gets displayed in the provisioner during the app_health_event_callback() function in main.c
  • Hi Joakim,
    We can send unicast message to only two servers right (0x105, 0x106)? That is why I am getting status back to client only from them right? I want to get status of some more servers in client. How is that possible? Should I change everything in node_setup.c?
  • Hi Joakim, How can I send message to the client from servers 0x0107 and 0x0108? Is it possible? I looked in node setup.c and found that we have to more clients to do this. Is there any other way?
