Advertising and scanning on single channel
I am using NRF52832, SDK v15.1.0.
For advertising on single channel, I added  " p_advertising->adv_params.channel_mask[4] = 03; "  in  ble_advertising_start() , yet it doesn't work.
Also, is it possible to do scanning with selective channel?
I have gone through previous blogs related this, but it doesn't work.
Is there any other way of doing this?
  • Hi Tejal.
    First, we have a new SDK version out, SDK v15.2.0, I really recommend that you download that here!
    If you want to advertise on a single channel, you can indeed turn of the other two channels.
    adv_params.channel_mask[4] = 0x80; // Dont advertise on ch 39
    adv_params.channel_mask[4] = 0x40; // Dont advertise on ch 38
    adv_params.channel_mask[4] = 0x20; // Dont advertise on ch 37
    adv_params.channel_mask[4] = 0xA0; // Dont advertise on ch 39 and 37
    adv_params.channel_mask[4] = 0xC0; // Dont advertise on ch 38 and 39
    adv_params.channel_mask[4] = 0x60; // Dont advertise on ch 37 and 38
    Just add ONE of these channel masks, depending on which channel(s) you would like to turn off, before the following:
        err_code = sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &adv_params);
    In static void advertising_init(void), my advertising_init(void) looks like this when I've masked channel 39:
        ret_code_t    err_code;
        ble_advdata_t advdata;
        ble_advdata_t srdata;
        ble_uuid_t adv_uuids[] = {{LBS_UUID_SERVICE, m_lbs.uuid_type}};
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        advdata.include_appearance = true;
        advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        memset(&srdata, 0, sizeof(srdata));
        srdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
        srdata.uuids_complete.p_uuids  = adv_uuids;
        err_code = ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
        err_code = ble_advdata_encode(&srdata, m_adv_data.scan_rsp_data.p_data, &m_adv_data.scan_rsp_data.len);
        ble_gap_adv_params_t adv_params;
        // Set advertising parameters.
        memset(&adv_params, 0, sizeof(adv_params));
        adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;
        adv_params.duration        = APP_ADV_DURATION;
        adv_params.properties.type = BLE_GAP_ADV_TYPE_CONNECTABLE_SCANNABLE_UNDIRECTED;
        adv_params.p_peer_addr     = NULL;
        adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        adv_params.interval        = APP_ADV_INTERVAL;
        adv_params.channel_mask[4] = 0x80; //The code added to mask channel 39
    All this is done in the nRF5_SDK_15.2.0_9412b96\examples\ble_peripheral\ble_app_blinky example project.
    If you want to scan a single channel I suggest you take a look at this post, where this is explained.
    Good luck.
    - Andreas
