ble_advdata_encode returns SVC Handler Missing
I have a project that generally operates as a typical peripheral, but occassionally sends advertising packets of type BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED. In the process of broadcasting these non-connectable packets, I have to call ble_advdata_encode. Usually this is not a problem, but sometimes it returns error 0x01 (SVC Handler Missing). When I look at documentation of ble_advdata_encode, it says it should return either NRF_SUCCESS, NRF_ERROR_INVALID_PARAM, or NRF_ERROR_DATA_SIZE. I'm also not picking up on any pattern that this behavior follows. Can anyone enlighten me as to what might cause  ble_advdata_encode to return error 0x01 (SVC Handler Missing)?
SDK: 15.0.0_a53641a
Soft Device: 6.0.0
IDE: Keil uVision5
  • You have the code for ble_advdata_encode() and you can see it calls several sd_* functions and then checks the result, any return code which is non-zero is returned. So the documentation shows the specific error codes but a lot of methods which use any of the sd functions can also return one of the sd error messages.
    Are you possibly calling this before you enable the softdevice?
  • Thank you for the reply. The soft device is enabled when I receive this error. I am able to connect to a phone and send some broadcasting packets before ble_advdata_encode() starts to consistently return SVC Handler Missing. I'm just having a hard time determining what is causing this change.
  • The root of the problem was in our function for broadcasting arbitrary advertising packets. It turns out that the length value in the advertising data structure in the global ble_gap_adv_data_t structure is updated with every packet to the length of that packet. If a longer packet is broadcast following a shorter packet, an error is returned. The solution was simply to update the length value for every broadcast packet. Here is what we're currently using to broadcast arbitrary advertising packets:
    static ble_gap_adv_data_t m_bcast_data =	//structure that contains a pointer to encoded advertising data and the length of that data
    	.adv_data =
    			.p_data = m_enc_bcast_data,
    			.len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    /**@brief Function for broadcasting advertising packets.
     * @details Provide a pointer to the packet data, provide the length of the data
     *						Function returns true when packet is sent successfully, false if tranmission fails.
    bool broadcast_packet( uint8_t* data, uint8_t length )
    	bool						success = true;
    	ble_advdata_t               adv_data;
    	ble_gap_adv_params_t		adv_params;
    	ble_advdata_manuf_data_t    mfg_data;
    	//clear data structures
    	memset( &adv_data, 0, sizeof(adv_data) );
    	memset( &adv_params, 0, sizeof(adv_params) );
    	memset( &mfg_data, 0, sizeof(mfg_data) );
    	//global m_bcast_data.adv_data.len needs to be reset between packets
    	//when a packet is sent, len is updated to the packet length (truncating any trailing zeros in the packet)
    	//if a longer packet is sent after a shorter packet without updating len, ble_adv_data_enc will return 0x0C -- invalid data size
    	//apparently, len is updated AFTER the size check in ble_adv_data_enc -->> manuf_specific_data_enc
    	m_bcast_data.adv_data.len = BLE_GAP_ADV_SET_DATA_SIZE_MAX;
    	//check packet length, truncate if too long
    	if( length > BROADCAST_LENGTH_MAX )
    		length = BROADCAST_LENGTH_MAX;
    	//configure custom data
    	mfg_data.company_identifier = BROADCAST_COMPANY_ID;
    	mfg_data.data.p_data = data;
    	mfg_data.data.size = length;
    	//point advertising data structure to custom data
    	adv_data.p_manuf_specific_data = &mfg_data;
    	//encode advertising data in m_bcast_data structure
    	if( ble_advdata_encode( &adv_data, m_bcast_data.adv_data.p_data, &m_bcast_data.adv_data.len ) != NRF_SUCCESS )
    		return !success;
    	//set advertising parameters
    	adv_params.primary_phy     = BLE_GAP_PHY_1MBPS;
    	adv_params.duration        = 12;																											//Duration, in 10ms units
    	adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;	//Broadcast packets are non-connectable, non-scannable, and undirected
    	adv_params.interval        = 0x30;                                                      //Interval, in 625us units
    	//stop any advertisement activity
    	sd_ble_gap_adv_stop( m_adv_handle );
    	//configure the packet with specified parameters
    	if( sd_ble_gap_adv_set_configure(&m_adv_handle, &m_bcast_data, &adv_params) != NRF_SUCCESS )
    		return !success;
    	//start broadcast
    	if( sd_ble_gap_adv_start( m_adv_handle, APP_BLE_CONN_CFG_TAG ) != NRF_SUCCESS )
    		return !success;
    	return success;
    /*  We need to return to connectable advertising once the broadcast packet terminates
        Add this to ble_evt_handler:
        case BLE_GAP_EVT_ADV_SET_TERMINATED:
    		if( m_conn_handle == BLE_CONN_HANDLE_INVALID )
    			advertising_init();
    			advertising_start();
    		break;  */
