'Make' issue with nRF5_SDK_15.1.0_a8c0c4d
Apologies if this is a duplicate post:
I am successfully making nRF example apps in nRF5_SDK_12.3.0_d7731ad using GNU Tools Arm Embedded version 7 2018-q2-update in Windows 7 32-bit.
However, making the same apps within nRF5_SDK_15.1.0_a8c0c4d fails (similar issue reported in other posts), even with exactly the same makefile.windows that I use in 12.3.0.
When I compare the following 2 folders w.r.t. number of files:
..\nRF5_SDK_12.3.0\components\toolchain\gcc
..\nRF5_SDK_15.1.0\components\toolchain\gcc
I notice there are 16 files in the former, but only 5 files in the latter - why is that?
Then, when I copy the following 2 files from the 12.3.0 gcc folder to the 15.1.0 gcc folder, the make is successful:
Makefile.common (overwriting the original)
file_list.mk (does not exist in gcc folder of 15.1.0)
Any ideas?
Thank you
    Which error did you get? It is impossible for us to know which error you are talking about when you write "similar issue reported in other posts".
    I tested on Windows 7 32-bit with SDK 15.1.0 and the same GCC ARM version you used. I modified my Makefile.Windows to the following:
    GNU_INSTALL_ROOT := C:/Program Files (x86)/GNU Tools ARM Embedded/7 2018-q2-update/bin/
    GNU_VERSION := 7.3.1
    GNU_PREFIX := arm-none-eabi
    This works just as expected.
    Jørgen
  • Thank you for the update Jorgen, apologies I should have been more clear on the error message.
    I used your makefile.windows in my folder:
    C:\BLE\external\nRF5_SDK_15.1.0\components\toolchain\gcc
    When I run make in:
    C:\BLE\external\nRF5_SDK_15.1.0\examples\ble_peripheral\ble_app_eddystone\pca10040\s132\armgcc
    I get the following:
    C:\BLE\external\nRF5_SDK_15.1.0\examples\ble_peripheral\ble_app_eddystone\pca10040\s132\armgcc>make
    process_begin: CreateProcess(NULL, "C:/Program Files (x86)/GNU Tools ARM Embedded/7 2018-q2-update/bin/arm-none-eabi-gcc" --version, ...) failed.
    Cannot find: 'C:/Program Files (x86)/GNU Tools ARM Embedded/7 2018-q2-update/bin/arm-none-eabi-gcc'.
    Please set values in: "C:/BLE/external/nRF5_SDK_15.1.0/components/toolchain/gcc/Makefile.windows"
    according to the actual configuration of your system.
    ../../../../../../components/toolchain/gcc/Makefile.common:129: *** Cannot continue. Stop.
    Thank you
  • It's complaining that it cannot find GCC. Are you sure that the path is correct, and that the file is available in the path?
  • 4530.Makefile.zip
    I attached the makefile.windows file that I use to make with SDK 12.3.0.  The make is successful:
    C:\BLE\external\nRF5_SDK_12.3.0\examples\peripheral\blinky\pca10040\blank\armgcc>make
    mkdir _build
    Compiling file: nrf_log_backend_serial.c
    Compiling file: nrf_log_frontend.c
    Compiling file: app_error.c
    Compiling file: app_error_weak.c
    Compiling file: app_timer.c
    Compiling file: app_util_platform.c
    Compiling file: hardfault_implementation.c
    Compiling file: nrf_assert.c
    Compiling file: sdk_errors.c
    Compiling file: boards.c
    Compiling file: nrf_drv_clock.c
    Compiling file: nrf_drv_common.c
    Compiling file: nrf_drv_uart.c
    Compiling file: nrf_nvic.c
    Compiling file: nrf_soc.c
    Compiling file: main.c
    Compiling file: RTT_Syscalls_GCC.c
    Compiling file: SEGGER_RTT.c
    Compiling file: SEGGER_RTT_printf.c
    Assembling file: gcc_startup_nrf52.S
    Compiling file: system_nrf52.c
    Linking target: _build/nrf52832_xxaa.out
    text data bss dec hex filename
    5136 108 116 5360 14f0 _build/nrf52832_xxaa.out
    Preparing: _build/nrf52832_xxaa.hex
    Preparing: _build/nrf52832_xxaa.bin
    When I make using the makefile.windows you proposed, with SDK 15.1.0 it fails:
    C:\BLE\external\nRF5_SDK_15.1.0\examples\peripheral\blinky\pca10040\blank\armgcc>make
    Surely if the path to my gcc was not correct, making with 12.3.0 would have failed too?
    I do notice you use forward slash "/" in your proposed makefile.windows file. As per attached file for 12.3.0, my makefile.windows references a backslash "\"...
  • SDK 12.3.0 Makefile did not require the path to include /bin/ at the end of the path. This is required in SDK 15.1.0. I guess you tried my Makefile.windows with the Makefile.common you copied from SDK 12.3.0? Please also check that the files are available in the path.
