Bootloader on custom board using uart
We have developed a customized board for use in a gateway. We would like to have a working bootloader on that board but it looks like it is almost impossible to make things work.
We are using nRF5 SDK version 15.0.0. I have tested the secure_dfu_test_images for nrf52840 on a PCA10056 board and they do not work as expected, so perhaps I was foolish to think that it would make any difference adapting the secure uart example for our board.
I have tested the uart example on both boards and they work perfectly so there is nothing wrong with the hardware (at least the uart is working properly). I have tried various baudrates since one support case suggested a baudrate of 9600 instead of the 115200 which is default in the bootloader example. I have also read most of the other support cases concerning the dfu and I have not found anything that could explain the problems that I see. I have also altered the python code to make the default baudrate 9600 but I cannot understand how to create a new version of nrfutil. However I assume that using the -b 9600 argument makes those changes unnecessary.
When trying to upload a new application to the board I get the following response:
pc_ble_driver_py.exceptions.NordicSemiException: No ping response after opening COM port
I have nrfutil version 3.5.1 (some support cases suggests exactly version 3.0.0 while others say >= 3.0.0).
Now I am out of ideas to try and fix this. Any ideas and/or suggestions?
If it does not work with nrfutil, how am I going to write a similar software to use inside the gateway? Is there a detailed specification for the protocol used by the bootloader/nrfutil? In that case where? (Yes, I know - RTFM, but the documentation is really fragmentet in certain parts and it is far from easy to know where to look).
Best regards
Anders
