Bootloader on custom board using uart
We have developed a customized board for use in a gateway. We would like to have a working bootloader on that board but it looks like it is almost impossible to make things work.
We are using nRF5 SDK version 15.0.0. I have tested the secure_dfu_test_images for nrf52840 on a PCA10056 board and they do not work as expected, so perhaps I was foolish to think that it would make any difference adapting the secure uart example for our board.
I have tested the uart example on both boards and they work perfectly so there is nothing wrong with the hardware (at least the uart is working properly). I have tried various baudrates since one support case suggested a baudrate of 9600 instead of the 115200 which is default in the bootloader example. I have also read most of the other support cases concerning the dfu and I have not found anything that could explain the problems that I see. I have also altered the python code to make the default baudrate 9600 but I cannot understand how to create a new version of nrfutil. However I assume that using the -b 9600 argument makes those changes unnecessary.
When trying to upload a new application to the board I get the following response:
pc_ble_driver_py.exceptions.NordicSemiException: No ping response after opening COM port
I have nrfutil version 3.5.1 (some support cases suggests exactly version 3.0.0 while others say >= 3.0.0).
Now I am out of ideas to try and fix this. Any ideas and/or suggestions?
If it does not work with nrfutil, how am I going to write a similar software to use inside the gateway? Is there a detailed specification for the protocol used by the bootloader/nrfutil? In that case where? (Yes, I know - RTFM, but the documentation is really fragmentet in certain parts and it is far from easy to know where to look).
Best regards
Anders
  • Hi Anders.
    When you say you have tested the secure_dfu_test_images for nRF52840, could you be a bit more specific? Which files have you flashed to your board? Did you follow any of the DFU bootloader examples and if you did, which example?
    You also say you tested the uart example, which UART example? The one found in examples\dfu\secure_dfu_test_images\uart, or in examples\ble_peripheral\ble_app_uart?
    Any more information would be much helpful, so I can try to recreate what you're doing.
    - Andreas
  • Hi Andreas,
    I used the files under ..\examples\dfu\secure_dfu_test_images\uart\nrf52840 and I am using nrfutil.exe version 3.5.1 (which I found on my computer because downloading and the master branch using pip install nrfutil produces som very strange failures probably due to python version mismatch) and nrfjprog.
    I am using several batch files containing the following content
    nrfjprog --eraseall
    nrfjprog --reset --program bootloader_secure_uart_debug_without_bonds_mbr.hex --family NRF52 --sectoranduicrerase
    nrfjprog --reset --program mbr.hex --family NRF52 --sectoranduicrerase
    nrfjprog --reset --program softdevice_s140.hex --family NRF52 --sectoranduicrerase
    nrfutil dfu serial -pkg blinky_mbr.zip -p COM3 -b 115200 -fc 0
    Using the instructions found on http://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk5.v15.0.0%2Fsdk_app_serial_dfu_bootloader.html&cp=4_0_0_4_3_4
    w
    hich by the way is difficult to follow since the instructions are intended for other uses. Which of the points needs to be done in order to test the bootloader? 1? 2? 3? 4? 5? 6? 7? 8? 9? 10?
    The uart has been tested with ..\examples\peripheral\uart\pca10056\blank\ses both using the original board (PCA10056) and with my custom board, and it works every time.
    We are using an FTDI cable to connect the devices to the PC and we are not using flow control since it is not available on our custom board, so only GND, RX and TX are used.
    I have tried debugging the bootloader while trying to download the application and it appears that the ping is received in the bootloader and it is replying as expected. Altering the copmmand line to add "-fc 0" did actually do someting for the result from nrfutil. It then became:
    pc_ble_driver_py.exceptions.NordicSemiException: Extended Error 0x07: The array of supported SoftDevices for the update does not contain the FWID of the current SoftDevice.
    Which may be a good thing since it no longer complains about no response from ping. I have not yet been able to make a package that does not contain an "--sd-req". This is strange because neither the bootloader nor the application depends on having a softdevice (why is it even included in the "secure_dfu_test_images"?). How can I create that zip file without having to tell nrfutil the version of the soft device when I do not want any soft device?
    If I get this bootloader up and running, which I firmly believes that I already have,  there is still a problem on how to create a similar functionality (working that is) like that of nrfutil to be able to download new software over the uart using C-code in a gateway. For that I would like to have som specifications on the protocol...
    Addition:
    Just noted one thing in ReadMe.md "**Note**: The Thread stack doesn't use a SoftDevice but --sd-req option is required for compatibility reasons. You can provide any value for the option as it is ignored during DFU.". Am I to understand that I can put any value in "--sd-req" like for instance 0x00, but then why does nrfutil complain about SoftDevice?
    BTW is there a way to get soft device versions like you get when you use s_dfu_settings.app_version? All I see is the s_dfu_settings.sd_size which may or may not be enough information...
    Best regards
    Anders
  • Hi again.
    The batch files you try to flash now does not require a SoftDevice.
    Could you try to run this batch script and perform a DFU?
    nrfjprog --eraseall
    nrfjprog --reset --program examples\dfu\secure_dfu_test_images\uart\nrf52840\bootloader_secure_uart_debug_without_bonds_mbr.hex --chiperase
    nrfjprog --reset --program examples\dfu\secure_dfu_test_images\uart\nrf52840\mbr.hex
    nrfutil dfu serial -pkg examples\dfu\secure_dfu_test_images\uart\nrf52840\blinky_mbr.zip -p COM3 -b 115200 -fc 0
    Run it from the nRF5_SDK_15.0.0_a53641a folder. I got the following output, and the LEDs start blinking.
      [####################################]  100%
    Device programmed.
    I agree that the steps in the example are a bit difficult to follow, as you say they are combination of DIY and use the examples provided.
    Before, when you tried to do a DFU, did you generate a DFU packet yourself, or did you use the blinky_mbr.zip packet found in examples\dfu\secure_dfu_test_images\uart\nrf52840\ ? Since the error you have now suggests that the SoftDevice firmware id (FWID) of the packet you tried to do a DFU with is wrong compared to the FWID already on the chip.
    If you are creating either your own bootloader or application when you are trying to do the DFU you should note that you need a private key, and you also have to configure whether or not to use flow-control or different baudrates in the sdk_config.h file.
    - Andreas
    If I run it from where I have the nrfutil.exe it gives the following response:
    C:\Users\anderslundqvist\Documents\Projekt\IoT card\PC NrfUtil>nrfutil dfu serial -pkg blinky_mbr.zip -p COM3 -b 115200 -fc 0
    [------------------------------------] 0%
    File "nordicsemi\__main__.py", line 987, in <module>
    File "site-packages\click\core.py", line 722, in __call__
    File "site-packages\click\core.py", line 697, in main
    File "site-packages\click\core.py", line 1066, in invoke
    File "site-packages\click\core.py", line 895, in invoke
    File "site-packages\click\core.py", line 535, in invoke
    File "nordicsemi\__main__.py", line 745, in serial
    File "nordicsemi\__main__.py", line 680, in do_serial
    File "nordicsemi\dfu\dfu.py", line 129, in dfu_send_images
    File "nordicsemi\dfu\dfu.py", line 90, in _dfu_send_image
    File "nordicsemi\dfu\dfu_transport_serial.py", line 211, in open
    Failed to execute script __main__
    If I run it from the position you suggest, I get the following response:
    C:\Users\anderslundqvist\Documents\SEGGER Embedded Studio Projects\nRF5_SDK>nrfutil dfu serial -pkg examples\dfu\secure_dfu_test_images\uart\nrf52840\blinky_mbr.zip -p COM3 -b 115200 -fc 0
    File "C:\Users\anderslundqvist\AppData\Local\Programs\Python\Python37\Scripts\nrfutil-script.py", line 11, in <module>
    load_entry_point('nrfutil==3.5.1', 'console_scripts', 'nrfutil')()
    File "c:\users\anderslundqvist\appdata\local\programs\python\python37\lib\site-packages\click\core.py", line 722, in __call__
    return self.main(*args, **kwargs)
    File "c:\users\anderslundqvist\appdata\local\programs\python\python37\lib\site-packages\click\core.py", line 697, in main
    rv = self.invoke(ctx)
    File "c:\users\anderslundqvist\appdata\local\programs\python\python37\lib\site-packages\click\core.py", line 1066, in invoke
    return _process_result(sub_ctx.command.invoke(sub_ctx))
    File "c:\users\anderslundqvist\appdata\local\programs\python\python37\lib\site-packages\click\core.py", line 895, in invoke
    return ctx.invoke(self.callback, **ctx.params)
    File "c:\users\anderslundqvist\appdata\local\programs\python\python37\lib\site-packages\click\core.py", line 535, in invoke
    return callback(*args, **kwargs)
    File "c:\users\anderslundqvist\appdata\local\programs\python\python37\lib\site-packages\nordicsemi\__main__.py", line 745, in serial
    do_serial(package, port, connect_delay, flow_control, packet_receipt_notification, baud_rate, True)
    File "c:\users\anderslundqvist\appdata\local\programs\python\python37\lib\site-packages\nordicsemi\__main__.py", line 680, in do_serial
    dfu.dfu_send_images()
    File "c:\users\anderslundqvist\appdata\local\programs\python\python37\lib\site-packages\nordicsemi\dfu\dfu.py", line 129, in dfu_send_images
    self._dfu_send_image(self.manifest.application)
    File "c:\users\anderslundqvist\appdata\local\programs\python\python37\lib\site-packages\nordicsemi\dfu\dfu.py", line 90, in _dfu_send_image
    self.dfu_transport.open()
    File "c:\users\anderslundqvist\appdata\local\programs\python\python37\lib\site-packages\nordicsemi\dfu\dfu_transport_serial.py", line 211, in open
    raise NordicSemiException("No ping response after opening COM port")
    When working with the PCA10056 I have not created any DFU package at all. It is strange that my PCA10056 does not work with this. My PCA10056 has a n MCU marked QIAAAA which means that it is som sort of preseries sample. Could this be the reason that it doesn't work?
    The Software device error message stems from my attempt in using my tweaked bootloader to accept my DFU package (or whatever you call it).
    I have created a private key - the example I used as a template, did not compile otherwise. That same key is also used to create the zip file.
    In fact this bootloader is overly complicated and since we will program the device from the gateway, it is not necessary to have a secure bootloader. However, your bootloader example that does not have elevated security also requires a private key (and public c-file key). In out case the security will reside in the programming the gateway. However, I see no solution that simplifies this process and all recommendations that I have seen is not to create anything from scratch - i.e. use the examples and do not mess with the SDK... Am I right or have I misunderstood your intentions?
    Addition:
    In case you are wondering why the ticket concerns two separate but very much connected issues, it is because last ticket I created took more than two months before anyone bothered to answer it. So I am thankful for your swift response. In retrospective, I should perhaps have created two different tickets...
    Best regards
    Anders
  • Hi.
    Could it be that you are using the wrong COM port? Could you check if COM3, which you use is in fact a JLink CDC UART Port?
    And when you say you have created a private key which you used to create the zip file, is this the zip file you tried to use as the DFU package? In that case then the keys from the precompiled .hex files and this zip file does not match.
    There is nothing wrong with doing modifications with the examples found in the SDK or creating something from the ble_app_template, just remember that more and more modifications increases the difficulty of making things compatible.
    - Andreas
