Modify HID descriptor
I am trying to send 'h' or the number 1 using vendor defined page (custom HID descriptor). How do I do it?
NOTE: I have worked with hid mouse & keyboard examples and also successfully tried a few modifications.
I am unable to customize the descriptor. Please help!
  • I assume you want to write a value to one of the report characteristics. In the HID Mouse Application, the creation of these characteristics is already taken care of (and they support notification).
    In order to notify a value to one of these characteristics, the SVCALL sd_ble_gatts_hvx(...) needs to be called.
    This function have two inputs:
    • conn_handle: A handle to the current connection, which will be assigned after connected
    • p_hvx_params: This is a struct that contains all the information when notifying an attribute value, for more information check out this link
    I modified the HID Mouse Application to write a value of 1 to the report characteristic for button movement, and the function below is called when button 4 is pressed.
    static void send_awesome_message(){
        NRF_LOG_INFO("sending awesome message");
        ble_gatts_hvx_params_t hvx_params;
        uint16_t               hvx_length = 1;
        uint32_t err_code;
        uint8_t my_data = 1;
        hvx_params.handle = m_hids.inp_rep_array[INPUT_REP_MOVEMENT_INDEX].char_handles.value_handle;
        hvx_params.type   = BLE_GATT_HVX_NOTIFICATION;
        hvx_params.offset = 0;
        hvx_params.p_len  = &hvx_length;
        hvx_params.p_data = &my_data;
        err_code = sd_ble_gatts_hvx(m_conn_handle, &hvx_params);
        if ((err_code == NRF_SUCCESS) && (*hvx_params.p_len != INPUT_REP_MOVEMENT_LEN))
            err_code = NRF_ERROR_DATA_SIZE;
    p_hvx_params fields:
    • Handle: Characteristic Value Handle that belongs to the report characteristics for button movement
    • Type: Used BLE_GATT_HVX_NOTIFICATION for notification
    • Offset: The offset within the attribute value is zero
    • Length: Length is 1 byte
    • Data: The data to be sent is 1
    I have provided the code down below:
    ble_app_hids_mouse_modified.zip
    In order to receive the notifications, you must remember to enable it from the client (e.g. phone or computer).
    Best regards, Simon
