low power saadc
when I start ADC the current will be HIGH .even I UN-Initialization it .
what I have done like that below;
#define SAADC_CONFIG_LP_MODE 1
void my_adc_init(void)
		MI_LOG_DEBUG("my_adc_init\r\n");
    ret_code_t err_code;
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    nrf_saadc_channel_config_t channel_config0 =
    NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(LIGHT_CHECK);
	channel_config0.reference=NRF_SAADC_REFERENCE_VDD4;
    err_code = nrf_drv_saadc_channel_init(LIGHT_CHECK-1, &channel_config0);
	nrf_saadc_channel_config_t channel_config1 =
    NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(BATTRY_CHECK);
    err_code = nrf_drv_saadc_channel_init(BATTRY_CHECK-1, &channel_config1);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool,SAMPLES_IN_BUFFER);
void start_ADC(void)
	MI_LOG_DEBUG("start_ADC\r\n");
	uint32_t err_code;
	LIGHT_PIN_control(LIGHT_CONTRL_ACTIVE);
	my_adc_init();
	err_code=nrf_drv_saadc_sample();//
    MI_LOG_DEBUG("saadc_callback\r\n");
	static uint32_t count=0;
	count ++ ;
    if (p_event->type == NRF_DRV_SAADC_EVT_DONE)//ADC转换完成
    	MI_LOG_INFO("the BATTRY  value is  %d . %d V\r\n", battry_V,(battry_V-(unsigned char )battry_V)*100);
		nrf_drv_saadc_uninit();
	if(p_event->type == NRF_DRV_SAADC_EVT_LIMIT)
		MI_LOG_INFO("ADC  NRF_DRV_SAADC_EVT_LIMIT %d \r\n",count);
	if(p_event->type == NRF_DRV_SAADC_EVT_CALIBRATEDONE)
		MI_LOG_INFO("ADC  NRF_DRV_SAADC_EVT_CALIBRATEDONE %d \r\n",count);
before I started it  The current is 0.6ma
but when I start it the current becom 7ma  .
Is there anything else should I do .
IS there any one can help me .
  • I'm guessing you're not using the DCDC regulator and not putting the CPU to sleep after starting the SAADC. Do you mind posting the relevant code to your SAADC usage?
  • I‘ve tried open dcdc .it downs to 3.75ma
    but what make me puzzled is that      :start the SAADC or not ,the current could chang so much .
    start :3.75ma
    no start :0.7ma
     I start SAADC  and then it finsh check    I UN-Initialized the SAADC but it always be high current .
    I give my main fuction below
        uint32_t err_code;
        ble_stack_init();
    	power_first();
        gap_params_init();
        my_service_Init();
        advertising_init();
        conn_params_init();
    //    printf("\r\nUART Start!\r\n");
        err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
    	My_flash_init();
    	get_save_and_synchronous_num();
        // Enter main loop.
        for (;;)
    			if(My_Time_Fuction_Enable==1)// changes pro min
    				My_Time_Fuction_Process();
    				My_Time_Fuction_Enable=0;
            power_manage();
    //most time it wait event until one minite.
    //stars pro min
    	uint32_t err_code;
    	my_adc_init();
    // if I Shielded this code   the current would be 0.7ma .
    // or it will be 3.75ma
    SAADC starts pro minite .and after it finished I  UN-Initialized the SAADC.
  • sorry pro minite mean per minute . sorry about that I have forgetten that word。
    here is my code about my project .please take a look .
    thank you very much .
    //SDK_CONFIC.H set
    #ifndef SAADC_ENABLED
    #define SAADC_ENABLED 1 //改
    #if SAADC_ENABLED
    // <o> SAADC_CONFIG_RESOLUTION - Resolution
    // <0=> 8 bit
    // <1=> 10 bit
    // <2=> 12 bit
    // <3=> 14 bit
    #ifndef SAADC_CONFIG_RESOLUTION
    #define SAADC_CONFIG_RESOLUTION 0
    // <o> SAADC_CONFIG_OVERSAMPLE - Sample period
    // <0=> Disabled
    // <1=> 2x
    // <2=> 4x
    // <3=> 8x
    // <4=> 16x
    // <5=> 32x
    // <6=> 64x
    // <7=> 128x
    // <8=> 256x
    #ifndef SAADC_CONFIG_OVERSAMPLE
    #define SAADC_CONFIG_OVERSAMPLE 0
    // <q> SAADC_CONFIG_LP_MODE - Enabling low power mode
    #ifndef SAADC_CONFIG_LP_MODE
    // <o> SAADC_CONFIG_IRQ_PRIORITY - Interrupt priority
    // <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice
    // <0=> 0 (highest)
    // <1=> 1
    // <2=> 2
    // <3=> 3
    // <4=> 4
    // <5=> 5
    // <6=> 6
    // <7=> 7
    #ifndef SAADC_CONFIG_IRQ_PRIORITY
    #define SAADC_CONFIG_IRQ_PRIORITY 7
    // <e> SAADC_CONFIG_LOG_ENABLED - Enables logging in the module.
    #ifndef SAADC_CONFIG_LOG_ENABLED
    #define SAADC_CONFIG_LOG_ENABLED 0
    #if SAADC_CONFIG_LOG_ENABLED
    // <o> SAADC_CONFIG_LOG_LEVEL - Default Severity level
    // <0=> Off
    // <1=> Error
    // <2=> Warning
    // <3=> Info
    // <4=> Debug
    #ifndef SAADC_CONFIG_LOG_LEVEL
    #define SAADC_CONFIG_LOG_LEVEL 3
    // <o> SAADC_CONFIG_INFO_COLOR - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef SAADC_CONFIG_INFO_COLOR
    #define SAADC_CONFIG_INFO_COLOR 0
    // <o> SAADC_CONFIG_DEBUG_COLOR - ANSI escape code prefix.
    // <0=> Default
    // <1=> Black
    // <2=> Red
    // <3=> Green
    // <4=> Yellow
    // <5=> Blue
    // <6=> Magenta
    // <7=> Cyan
    // <8=> White
    #ifndef SAADC_CONFIG_DEBUG_COLOR
    #define SAADC_CONFIG_DEBUG_COLOR 0
    #endif //SAADC_CONFIG_LOG_ENABLED
    // </e>
    #endif //SAADC_ENABLED
    // </e>
    //main fuction
        uint32_t err_code;
        ble_stack_init();
        power_first(); //上电就做电源管理
        gap_params_init();
        my_service_Init();
        //services_init();
        advertising_init();
        conn_params_init();
        My_flash_init();
        // Enter main loop.
        for (;;)
            if (NRF_LOG_PROCESS() == false)//将保存的LOG都吐出来之后进入休眠
                power_manage();
    //SADDC Initialization
    ADC_start(void)  //starts  per minute
    //saadc callback
    void saadc_callback(nrf_drv_saadc_evt_t const * p_event) //ADC完成中断 功能完成,具体参数需要调试
        count ++ ;
            MI_LOG_DEBUG("ADC has completed %d times\r\n",count);
            LIGHT_PIN_control(!LIGHT_CONTRL_ACTIVE);
            err_code=nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer,SAMPLES_IN_BUFFER);
            light_value=(p_event->data.done.p_buffer[0]);
            MI_LOG_INFO("the LIGHT_CHECK ADC value is %X\r\n", light_value);//p_event->data.done.p_buffer[0]);
            MI_LOG_INFO("the BATTRY_CHECK ADC value is %d \r\n", p_event->data.done.p_buffer[1]);
            battry_V=((float )p_event->data.done.p_buffer[1])/256*0.6*6*133/33;
            battry_level=(uint8_t)((battry_V-BATTRY_ZERO)/(BATTRY_FULL-BATTRY_ZERO)*100);
            if(battry_V<BATTRY_ZERO)
                battry_level=0;
            if(battry_level>100)
                battry_level=100;
            if(battry_level<BATTRY_LOW_WARNING)//电量低
             POWER_LOWER_FLAG=1;
            POWER_LOWER_FLAG=0;
            if( light_value<LIGHT_TOO_HIGH_GATE)
                light_flag=TO_HIGH;
                MI_LOG_INFO("light is too bright \r\n");
            else if(light_value>LIGHT_TOO_LOW_GATE)
                light_flag=TO_LOW;
                MI_LOG_INFO("light is too dark \r\n");
                light_flag=NORMAL;
        if(p_event->type == NRF_DRV_SAADC_EVT_LIMIT)//超出限制
        if(p_event->type == NRF_DRV_SAADC_EVT_CALIBRATEDONE)//校准完成
  • HI ,Haakonsh ,
    I have found the cause of the problem.
    During the processing of ADC, I activated the floating point unit.
    The power problem has been solved, thank you all the same .
