Just as the title says, I'm trying to measure an input pulse width using PPI and GPIOTE. I am currently measuring the pulse width using timer interrupts, but I would like to move to PPI to avoid issues when I start to use the Soft Device.
From looking at the forums, here is the start of my code:
NRF_GPIOTE->CONFIG[0] = GPIOTE_CONFIG_MODE_Event << GPIOTE_CONFIG_MODE_Pos | GPIOTE_CONFIG_POLARITY_LoToHi << GPIOTE_CONFIG_POLARITY_Pos | V_SENSOR << GPIOTE_CONFIG_PSEL_Pos | GPIOTE_CONFIG_OUTINIT_High << GPIOTE_CONFIG_OUTINIT_Pos; // ignored when gpio is set to event mode NRF_GPIOTE->CONFIG[1] = GPIOTE_CONFIG_MODE_Event << GPIOTE_CONFIG_MODE_Pos | GPIOTE_CONFIG_POLARITY_HiToLo << GPIOTE_CONFIG_POLARITY_Pos | V_SENSOR << GPIOTE_CONFIG_PSEL_Pos | GPIOTE_CONFIG_OUTINIT_High << GPIOTE_CONFIG_OUTINIT_Pos; // ignored when gpio is set to event mode ////////////////// NRF_PPI->CH[5].EEP = (uint32_t)&NRF_GPIOTE->EVENTS_IN[0]; //What happens on the LotoHi transition from CONFIG[0] NRF_PPI->CH[5].TEP = (uint32_t)&NRF_TIMER3->TASKS_START; NRF_PPI->FORK[5].TEP = (uint32_t)&NRF_TIMER3->TASKS_CLEAR; NRF_PPI->CH[6].EEP = (uint32_t)&NRF_GPIOTE->EVENTS_IN[1]; //What happens on the HitoLo transition from CONFIG[1] NRF_PPI->CH[6].TEP = (uint32_t)&NRF_TIMER3->TASKS_CAPTURE[3]; //value of timer will be stored in NRF_TIMER3->CC[3] NRF_PPI->FORK[6].TEP = (uint32_t)&NRF_TIMER3->TASKS_STOP;
I am assuming the code should do the following:
V_SENSOR is P0.30, which has a periodic pulse of unknown pulse width. The pulse will come every second, and the width will be between 100-400ms. On the LotoHi transition the timer will clear and begin to count, and on the HitoLo transition the timer will store the value so I can read it into a variable.
I have a 1 second interrupt where I try to grab the value of the timer, value = NRF_TIMER3->CC[3]; but that never seems to give me anything useful.
I configure and start my timer like so.
void timer_init() { NRF_TIMER3->BITMODE = TIMER_BITMODE_BITMODE_24Bit << TIMER_BITMODE_BITMODE_Pos; NRF_TIMER3->PRESCALER = 4; NRF_TIMER3->SHORTS = TIMER_SHORTS_COMPARE0_CLEAR_Msk << 5; NRF_TIMER3->MODE = TIMER_MODE_MODE_Timer << TIMER_MODE_MODE_Pos; NRF_TIMER3->CC[5] = 16; NRF_TIMER3->CC[0] = 6; }
In my main program I initialize the timer, initialize the GPIOE, and then start the timer.
Any advice would be appreciated.
