uint32_t err_code;
err_code = sd_power_pof_enable(POWER_POFCON_POF_Enabled << POWER_POFCON_POF_Pos);
err_code = sd_power_pof_threshold_set(POWER_POFCON_THRESHOLD_V23);
if(err_code == NRF_ERROR_SOC_POWER_POF_THRESHOLD_UNKNOWN )
DEBUG_ERROR("Invalid Power threshold!!");
So using the above code I am trying to set the threshold of 2.3 volts on the power comparator. I am using sdk12.1 with Soft device 3.0.0 on an nrf52832
I keep getting NRF_ERROR_SOC_POWER_POF_THRESHOLD_UNKNOWN when I try and set the threshold.
The sd_power_pof_enable correctly sets the POFCON register to 0x01 but then fails when I try and set the threshold.
- What are the valid values for an nrf52832 chip? (I have tried quite a few) From the product data sheet it looks like I can use all of them but from what I have seen on the forums this might not be the case.
- Does this have to be called after enabling the softdevice? (I assume so but it would be good to have clarification)
