My environment is:
Windows 7
JLink Plus v9.3
IAR EWARM 8.30.1
SDK 15.0.0
Softdevice S132 from SDK 15.0.0
My hardware is a custom board with a Rigaldo BMD300 module (contains the nRF52832) and a few SPI-to-UART bridges.
I have monitor mode debugging enabled but I still hit the NRF_BREAKPOINT_COND in the app_error_fault_handler() sometimes. The J-LINK RTT Viewer shows monitor mode enabled:
LOG: J-Link RTT Viewer V6.34f: Logging started. LOG: Terminal 0 added. LOG: Device "NRF52832_XXAA" selected. LOG: ConfigTargetSettings(): Enable Monitor Mode Debugging LOG: Found SW-DP with ID 0x2BA01477 LOG: Found SW-DP with ID 0x2BA01477 LOG: Scanning AP map to find all available APs LOG: AP[2]: Stopped AP scan as end of AP map has been reached LOG: AP[0]: AHB-AP (IDR: 0x24770011) LOG: AP[1]: JTAG-AP (IDR: 0x02880000) LOG: Iterating through AP map to find AHB-AP to use LOG: AP[0]: Core found LOG: AP[0]: AHB-AP ROM base: 0xE00FF000 LOG: CPUID register: 0x410FC241. Implementer code: 0x41 (ARM) LOG: Found Cortex-M4 r0p1, Little endian. LOG: FPUnit: 6 code (BP) slots and 2 literal slots LOG: CoreSight components: LOG: ROMTbl[0] @ E00FF000 LOG: ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7 LOG: ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT LOG: ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB LOG: ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM LOG: ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU LOG: ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM LOG: RTT Viewer connected.
All I did to enable monitor mode was add the three files (JLINK_MONITOR.c, JLINK_MONITOR.h, and JLINK_MONITOR_ISR_IAR.s) and added a JLinkScript file to the project directory where EWARM creates the .jlink file. The JLinkScript file is:
* (c) SEGGER Microcontroller GmbH & Co. KG *
* The Embedded Experts *
* www.segger.com *
-------------------------- END-OF-HEADER -----------------------------
File : EnableMonitorModeDebugging.JLinkScript
Purpose : Enable Monitor Mode Debugging
Literature:
[1] J-Link User Guide (UM08001_JLink.pdf), chapter "Monitor Mode Debugging"
* Constants (similar to defines)
* Global functions
* ConfigTargetSettings()
* Function description
* Called before InitTarget(). Mainly used to set some global DLL variables to customize the
* normal connect procedure. For ARM CoreSight devices this may be specifying the base
* address of some CoreSight components (ETM, �) that cannot be auto-detected by J-Link
* due to erroneous ROM tables etc. May also be used to specify the device name in case
* debugger does not pass it to the DLL.
* Return value
* >= 0: O.K.
* < 0: Error
* Notes
* (1) May not, under absolutely NO circumstances, call any API functions that perform target
* (2) Should only set some global DLL variables
int ConfigTargetSettings(void) {
JLINK_SYS_Report("ConfigTargetSettings(): Enable Monitor Mode Debugging");
JLINK_ExecCommand("SetMonModeDebug = 1");
JLINK_ExecCommand("SetMonModeVTableAddr = 0x26000"); // Needed in case of the monitor mode interrupts needs to be forwarded, see section "Forwarding of Monitor Interrupts" in the J-Link User Guide (UM08001)
return 0;
/*************************** end of file ****************************/
Any idea why monitor mode debug causes an error?
