nrf52840
sdk 15.2
i am using termite for serial viewer. and problem is my code gets complied with no errors and when i open termite there is no data in termite. i checked all port and baud rate aslo but didnt worked.please anyone help me
nrf52840
sdk 15.2
Have you debugged your code? Is it running properly?
Can you upload your project files?
twi_sensor - Copy.rarthis project only not showing anything in serial monitor
Are you using the correct UART RX and TX pins? To make your project work on my nRF52840 DK kit (v0.12.0) I had to change the pin numbers defined in sdk_config.h like this:
AFTER I CHANGE I AM GETTING LOTS OF ERROR ONLY. ARE YOU ABLE TO READ SENSOR VALUES
What do the errors say?
I can't read the sensor values because I don't have your sensor.
