Android notify sensor data (25FPS)
I'm trying to notify some sensor data at a constant 25 data packets per second.
If I set the `MIN_CONN_INTERVAL` to `10 and `MAX_CONN_INTERVAL` to `30` it all works well, I get data at 25 packets/second. This config does work on Android but the `conn_params_negotiation` fails as Android tablet that I use requires a `MAX_CONN_INTERVAL` of at least `40`. As soon as I update the attribute I get 5-6 `NRF_ERROR_RESOURCES`  errors per second lowering the data packets sent per second to 17-18.
I've been trying different configs but I'm not able to make it work at 25fps when the max connection interval is <= 40.
- tried to increase the min_conn_interval to 30 and set the max_conn_interval to 40 (I get `NRF_ERROR_RESOURCES`)
- tried to increase the stack size of the task in which the advertising happens (no effect)
- tried to increase the `SLAVE_LATENCY` to 4 (no effect)
I'm running a bit out of ideas and start to feel that I'm missing something.
P.S. I'm using the NRF52832, SDK v14.2 with FreeRTOS enabled.
Gabriel
