1. Is it reasonable easy to get a stable throughput over 1Mbps at a 3 meters range?
2. How much CPU resource is available at above situation? Or how many DMIPS is left at the above transmission situation.
Thanks a lot!
Thanks a lot!
==== Current test configuration ====
Board role: tester
ATT MTU size: 247
Data length: 251
Connection interval: 15 ms
Connection length ext: on
Preferred PHY: 1 Mbps
GAP event length: 400
Total: 1079.58 µs spent in softdevice per 15 ms interval (92.8% available CPU)
Thanks a lot for quick reply Jorgen!
Do you have the data about the situation of maximum throughput, that is, about 1.3Mbps ? Or could you help get that data?
Thanks again!
I think this data is interested by many many users.
I did not check more than 20 ms of the transfer, but the CPU usage seems to be quite constant:
==== Current test configuration ==== Board role: tester ATT MTU size: 247 Data length: 251 Connection interval: 320 units Connection length ext: on Preferred PHY: 2 Mbps GAP event length: 400 [00:00:00.005,096] <info> app: Time: 6.376 seconds elapsed. [00:00:00.005,126] <info> app: Throughput: 1315.82 Kbps. [00:00:00.005,126] <info> app: ============================= [00:00:00.005,126] <info> app: Sent 1048712 bytes of ATT payload.
3658.86 µs spent in softdevice during 20 ms period checked, corresponding to 81.7% CPU availability.
Thanks!
