enable TWI, external interrupt and Hight frequency clock with Soft Device enabled.
I need to minimize the power consumption.
For this reason when my device is in advertising the peripherals:
  • TWI
  • hight frequency clock
  • external interrupt on one pin.
are not enabled. In this configuration between 2 advertising the current consuption in my device is about 2 uA (@3V).
If the peripherals are enabled the current is about 400 uA. (160uA for interrupt, 220uA for TWI and 20uA for clock)
When the device is connected I need to init the above peripherals.
The problem occur when I try to init the peripherals with Soft Device enabled, the processor go in HardFault handler.
I understand that I need to use the API but I can't found documentation on this argoment.
Only for the clock I have found: sd_clock_hfclk_is_running and sd_clock_hfclk_release
Can you suggest me the correct API to call to init and deinit TWI and external interrupt ?
Now I use for the interrupt:
   nrf_drv_gpiote_in_config_t in_config = NRFX_GPIOTE_CONFIG_IN_SENSE_HITOLO(true);
   in_config.pull = GPIO_PIN_CNF_PULL_Disabled;
   in_config.sense = GPIOTE_CONFIG_POLARITY_HiToLo;
   err_code = nrf_drv_gpiote_in_init(PIN_P0_07_INT, &in_config, in_pin_handler);
and for twi:
    err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi);
Thanks
Marco
