ble_app_lbs - init.led_write_handler = 0
    uint32_t err_code;
    ble_lbs_init_t init;
    init.led_write_handler = led_write_handler;				//Assigns handle to LED  set/clear call from BT Controller
    err_code = ble_lbs_init(&m_lbs, &init, bdata);
after executing the line init.led_write_handler = led_write_handler; if I look at the value of init.led_write_handler it's equal to 0. Is this normal? I was expecting a non-zero value for the handler.
When I write to the LED in the Master Control Panel, everything looks normal, but I have a break point in the function void led_write_handler(....), and it never breaks. Like the scheduler is not calling the function. Any thoughts?
Thanks
