STM32F NRF24L01+ TX Problem
Hi.
I've been trying to send a payload with STM32F but I can not.
I've used both STM32F103 and STM32F3 to send a payload but neither of them worked.
However, when I use an Arduino Uno as a transmitter and STM32F as a receiver everything works perfectly.
I have tried 2 methods to send a payload so far but; I have not had any result.
1st method:
 void TX_Mode(uint8_t data2send)
    SetPRIM(PRIM_TX); // set as tx
	csn_low(); //CSN=0
	HAL_SPI_Transmit(&hspi1, &COMD_W_TX_PAYLOAD, 1,150);
	HAL_SPI_TransmitReceive(&hspi1, &data2send, &dummy, 1, 150); // fill the payload
	while(HAL_SPI_GetState(&hspi1) != HAL_SPI_STATE_READY);
	csn_high();
	ChipEnable_high(); //CE=1
    DWT_Delay_us(500); // wait for 500us
	Flush_TX(); //Flush TX FIFO
	CleanInterrupts(); //Clean all the interrupt flags
Note that, I confirmed that TX FIFO is filled and TX_DS Bit is set high by using 1st method.
2nd method:
    bool radio_busy = true;
	SetPRIM(PRIM_TX);
    // Fill the payload.
	csn_low(); //CSN=0
	csn_high();
	ChipEnable_high();
	while(radio_busy)
		if(TXDS_Bit_Is_Set()) // If the payload is sent
			CleanInterrupts();
			ChipEnable_low(); // CE=0
			radio_busy = false;
		if(MAXRT_Bit_Is_Set()) // If Max Re-Transmission is reached
			Flush_TX();
			CleanInterrupts();
			radio_busy = false;
I haven't changed anything about TX_ADDR. I use the reset value 0xE7E7E7E7E7 as tx address.
Thanks in advance.
