Updating DFU via RS-485 and UART without python on nRF52840 DK
Hi!
What would be the best course of action if I have a connection like this:
 Android device (without Bluetooth support) -> RS-485 -> UART ->  Main nRF52840 DK + other devices connected via Mesh to this device
So is it possible to somehow:
1.Upload .hex file to Android device
2.Send .hex (converted to byte array) via RS-485 / UART to nRF52840 DK
3. Save .hex file on nRF52840 DK flash
4. Convert / update firmware of all mesh devices from nRF52840 DK which is connected to Android device?
Is this even possible, so that firmware update happens, all on DK devices without the need of Over the Air update or update with python libraries which are not present on Android device?
Edit:
I also noticed it could work in a way that
1. .hex is already converted to .zip file
2. .zip file is sent to nRF52840 DK
3. nRF52840  DK somehow initiates nrfutil dfu serial -pkg dfu_prov-1.zip -p COM9 -b 115200 -i 1 -fc -m
Or
Android starts DFU without nrfuitl(or nrfutil in java/C without python) somehow?
Problem in case when Android tablet would update all mesh devices via UART would be the downtime of system because of serial port(uart) usage for updating, which would last +30 minutes
Thank you!
  • I am afraid that we do not have any Java or C implementation of nrfutil. There is also no mechanism for the nRF device to initiate a DFU update, this is done by the Ble Central/ Serial Master device.
    So in order to make this work you will have to create some code that reads the hex file and sends it over UART in the same format as nrfutil does.
    Best regards
    Bjørn
  • 1. But first nRF52840 DK can't work as Ble Central / Serial Master device and others as "slave" maybe?
    2. Would if work if I convert dfu_transport_mesh.py(if that is only thing needed?) into Java to create DFU mesh packet and send if via UART like nrfutil does? (which will block serial port for 30+minutes)
  • Q1: The nRF52840 with the S140 SoftDevice can be a BLE Central. But the issue here is transferring the firmware image from the Android tablet to the nRF52840, not from the 52840 to the other devices in the mesh.
    Q2: Yes, if you use the python code from our nrfutil implementation as a reference and convert that to Java, so that the .zip packet is parsed correctly and send via UART. Not sure if dfu_transport_mesh.py is the only source you will have to migrate from python to java.
