My ultimate issue is trying to get a bootloader working on custom hardware with an nRF52832. The bootloader is mostly the base UART DFU bootloader from the Nordic SDK, with a few customizations to work with our hardware. I've been able to get the bootloader up and running by using the following flash set up that I have for the application: FLASH (rx) : ORIGIN = 0x26000, LENGTH = 0x5a000. However, when I try to change the start address (e.g. to FLASH (rx) : ORIGIN = 0x25000, LENGTH = 0x5b000), the bootloader no longer appears to run. Similarly, I can use Eclipse to step into the debug code of the bootloader when it starts at 0x26000, but not at 0x25000.
To try to eliminate as many variables as possible, I also tried changing the start address of one of the SDK examples and running it on an nRF52 dev kit. In the same way as the bootloader on custom hardware, building the ble_central/ble_app_blinky_c produces an hex file that will run successfully on the dev kit, while building it with the start address changed to 0x25000 produces a hex file that will not run successfully. Below is a diff of my complete changes to the blinky example.
In both the custom code/hardware and stock SDK/dev kit situations I'm using GCC as my compiler and SDK 15.2.0, with softdevice s132_nrf52_6.1.0_softdevice.hex. My programming procedure in each case is:
What am I missing about changing the starting address of either the application or the bootloader? What configuration needs to be done to get an application and bootloader running together?
Thanks.
