Destination unreachable:address unreachable.
I am trying to set up mqtt between 2 nrf52s and rpi3 with the examples of sdk 15.0.2. I am very new to nrf52, rpi3 and networking. I have read everything needed as much as I can. However when I was following examples from infocenter and https://visualgdb.com/tutorials/arm/nrf51/6lowpan/ , there is a problem occurred. I could connect to nrf52 via bluetooth but I cannot send a ping to it. I have read related docs about Ipv6, 6Lowpan, BLE but could not find what is the point I have missed. May you please direct me to a way to understand my problem?
I am using Raspbian stretch lite version 4.14
SS of result of ping6 command
SS of result of ifconfig command
  • Hi again,
    Now, I am able to send ping to address, the problem is I missed the point about linux kernel >= 4.12 mine is 4.14 and I need to omit 2 after fe80:: . I could succesfully connect and ping to the devices however cannot see any change when I press to button 1 on publisher. I think I could have some issues from mosquitto broker. I used non secure 1883 port to start broker by this command:
    mosquitto -p 1883
    before this I used
    sudo apt-get update
    sudo apt-get upgrade -y
    sudo apt-get install mosquitto
    sudo apt-get install mosquitto-clients
    commands to install mosquitto broker to my rpi. What could be the problem here?
    Halil
  • What do you mean by "need to omit 2 after fe80::" ?
    What is your application supposed to do after you press button 1? Can you please, please, please tell me what you have programmed on your nRFs?
  • Hey Edvin,
    Sorry for my uncertain post. I am using PCA10040: nRF52832: S132.
    I meant by omitting:
    My kernel is 4.14 and I do not need to give an address with this scheme.
    Now, I succesfully did everything and I can blink LED4 of board by sending pub message from broker.
    Now, another problem is arisen. When I connect one of my board either as sub or as pub to RPi router and send command to blink led, everything is ok. However, when I connect both of my boards at the same time to the router the connection is gone and buttons do not work. I give 2001:db8::1/64 to my bt0 interface, should I give 2001:db8::2/64 to second device?
    I am sorry for bad English. Thank you very much.
    Halil
