Programming Custom nRF52 board with Jlink via SWD
Good day, I am having serious problems flashing my custom NRF5282 board. I started with Openocd, using the st-link v2 debugger and I was able to connect to the device and view memory as well as read registers, but I am unable to program the chip using openocd. I get this error:
JTAG failure -4
JTAG failure -4
JTAG failure -4
JTAG failure -4
JTAG failure -4
JTAG failure -4
target halted due to debug-request, current mode: Thread
xPSR: 00000000 pc: 00000000 msp: 00000000
jtag status contains invalid mode value - communication failure
Polling target nrf52.cpu failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
Previous state query failed, trying to reconnect
I have seen a lot of suggestions on this site about disabling app_protect using:
dap apreg 1 0x04 0x01
But this does not work for me. I have also posted a question on stack overflow but I couldnt get much help. stackoverflow.com/.../problem-flashing-nrf52-chip-using-openocd
But now I got an original jlink. But with the jlink I am not even able to connect ot the board. I get this error:
J-Link>connect
Device "NRF52832_XXAA" selected.
Connecting to target via SWD
Found SW-DP with ID 0x2BA01477
Scanning AP map to find all available APs
AP[2]: Stopped AP scan as end of AP map has been reached
AP[0]: AHB-AP (IDR: 0x24770011)
AP[1]: JTAG-AP (IDR: 0x02880000)
Iterating through AP map to find AHB-AP to use
AP[0]: Skipped. Could not read AHB ROM register
AP[1]: Skipped. Not an AHB-AP
****** Error: DAP error while reading DP-Ctrl-Stat register.
Cannot connect to target.
J-Link>
I have also tried the nrfjprog command line tools but I get this error:
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
I think my connection is good because I am able to connect to the device via openocd and stlink-v2, But I am not using the reset pin.
My device voltage is also 4.8v. Please can anyone help me with any suggestions? Thanks for your anticipated cooperation
  • The title says "J-Link", but your post says "ST-Link".
    Please clarify!
  • Hello, if I have tried both the ST-Link and the Jlink, Please read the post, I have explain the steps I have taken so far
  • My device voltage is also 4.8v.
     This is way outside the Absolute maximum ratings for the nRF52832. You should make sure the voltage is within specs, and that the debugger is running at the same voltage as the board.
    Can you provide the log from nrfjprog?
  • Hello, I have changed the device voltage to 3.3v but I still get these errors. Here is the log form nrfjprog:
    nrfjprog -r --log
    nrfjprog version 9.7.3
    nRF_open_dll
    . nRFXX_open_dll
    . . nRFXX_dll_version
    nRF_enum_emu_snr
    . nRFXX_enum_emu_snr
    nRF_enum_emu_snr
    nRF_connect_to_emu_with_snr
    . nRFXX_connect_to_emu_with_snr
    . . nRFXX_is_connected_to_emu
    . . nRFXX_connect_to_emu_without_snr
    . . . nRFXX_is_connected_to_emu
    . . . nRFXX_enum_emu_snr
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 Firmware: J-Link V10 compiled Sep  4 2018 11:24:21
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 Hardware: V10.10
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 S/N: 260111328
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 OEM: SEGGER-EDU
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 Feature(s): FlashBP, GDB
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 TELNET listener socket opened on port 19021
    . . nRFXX_connect_to_emu_without_snr:	JLink:	WEBSRV  Starting webserver
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (8501ms, 8506ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	WEBSRV Webserver running on local port 19080
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (8515ms, 8520ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	  returns O.K.
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (8518ms, 8523ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	JLINK_GetHWStatus(...)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	  returns 0x00
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0004ms, 8547ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	JLINK_ExecCommand("Device = NRF52832_xxAA", ...).
    . . nRFXX_connect_to_emu_without_snr:	JLink:	XML file found at: C:\Program Files (x86)\SEGGER\JLink_V634g\JLinkDevices.xml
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0002ms, 8551ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	C:\Program Files (x86)\SEGGER\JLink_V634g\JLinkDevices.xml evaluated successfully.
    . . nRFXX_connect_to_emu_without_snr:	JLink:	Device "NRF52832_XXAA" selected.
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0079ms, 8628ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    . . nRFXX_connect_to_emu_without_snr:	JLink:	  returns 0x01
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 8635ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	JLINK_ExecCommand("DisableFlashDL", ...).
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 8637ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	JLINK_ExecCommand("SetDbgPowerDownOnClose = 1", ...).
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0002ms, 8642ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 8645ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	JLINK_TIF_Select(JLINKARM_TIF_SWD)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0002ms, 8648ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	JLINK_SetSpeed(2000)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 8649ms total)
    nRF_read_connected_emu_snr
    . nRFXX_read_connected_emu_snr
    . . nRFXX_is_connected_to_emu:	JLink:	JLINK_IsOpen()
    . . nRFXX_is_connected_to_emu:	JLink:	  returns 0x01
    . . nRFXX_is_connected_to_emu:	JLink:	 (0002ms, 8652ms total)
    nRF_read_device_family
    . nRFXX_read_device_family
    . . nRFXX_is_connected_to_emu:	JLink:	 (0002ms, 8654ms total)
    . . nRFXX_read_access_port_register
    . . . nRFXX_coresight_configure
    . . . nRFXX_coresight_configure:	JLink:	JLINK_CORESIGHT_Configure()
    . . . nRFXX_coresight_configure:	JLink:	  returns 0
    . . . nRFXX_coresight_configure:	JLink:	 (0102ms, 8757ms total)
    . . . nRFXX_power_debug_and_system_regions
    . . . . nRFXX_write_debug_port_register
    . . . . nRFXX_write_debug_port_register:	JLink:	JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    . . . . nRFXX_write_debug_port_register:	JLink:	  returns -1
    . . . . nRFXX_write_debug_port_register:	JLink:	 (0001ms, 8758ms total)
    . . . . nRFXX_write_debug_port_register:	JLinkARM.dll CORESIGHT_WriteAPDPReg returned error -1.
    . . . nRFXX_power_debug_and_system_regions:	JLinkARM.dll CORESIGHT_WriteAPDPReg returned error -102.
    nRF_close_dll
    . nRFXX_close_dll
    . . nRFXX_is_connected_to_emu:	JLink:	 (0001ms, 8760ms total)
    . . nRFXX_disconnect_from_emu
    . . nRFXX_disconnect_from_emu:	JLink:	JLINK_Close()
    nrfjprog -e --log
    nRF_open_dll
    . nRFXX_open_dll
    nRF_enum_emu_snr
    nRF_enum_emu_snr
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0021ms, 0025ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0023ms, 0027ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0024ms, 0028ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0003ms, 0032ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0002ms, 0036ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0076ms, 0110ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 0112ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 0114ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 0115ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 0117ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0002ms, 0120ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 0122ms total)
    . . nRFXX_is_connected_to_emu:	JLink:	 (0001ms, 0123ms total)
    . . nRFXX_is_connected_to_emu:	JLink:	 (0002ms, 0126ms total)
    . . . nRFXX_coresight_configure:	JLink:	 (0102ms, 0228ms total)
    . . . . nRFXX_write_debug_port_register:	JLink:	 (0002ms, 0235ms total)
    nRF_close_dll
    . nRFXX_close_dll
    . . nRFXX_is_connected_to_emu:	JLink:	 (0001ms, 0237ms total)
    nrfjprog --recover --log
    nRF_open_dll
    . nRFXX_open_dll
    nRF_enum_emu_snr
    nRF_enum_emu_snr
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0020ms, 0027ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0021ms, 0028ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0022ms, 0029ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0004ms, 0034ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 0038ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0077ms, 0114ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 0116ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0000ms, 0117ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0000ms, 0119ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 0121ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0002ms, 0124ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 0130ms total)
    . . nRFXX_is_connected_to_emu:	JLink:	 (0001ms, 0131ms total)
    . . nRFXX_is_connected_to_emu:	JLink:	 (0001ms, 0133ms total)
    . . . nRFXX_coresight_configure:	JLink:	 (0101ms, 0235ms total)
    . . . . nRFXX_write_debug_port_register:	JLink:	 (0002ms, 0237ms total)
    nRF_close_dll
    . nRFXX_close_dll
    . . nRFXX_is_connected_to_emu:	JLink:	 (0006ms, 0243ms total)
    nrfjprog -e --log
    nRF_open_dll
    . nRFXX_open_dll
    nRF_enum_emu_snr
    nRF_enum_emu_snr
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0035ms, 0044ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	WEBSRV Webserver running on local port 19081
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0037ms, 0046ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0039ms, 0048ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0002ms, 0051ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0016ms, 0069ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0105ms, 0158ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 0160ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0000ms, 0161ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 0164ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 0166ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0004ms, 0170ms total)
    . . nRFXX_connect_to_emu_without_snr:	JLink:	 (0001ms, 0172ms total)
    . . nRFXX_is_connected_to_emu:	JLink:	 (0002ms, 0175ms total)
    . . nRFXX_is_connected_to_emu:	JLink:	 (0001ms, 0177ms total)
    . . . nRFXX_coresight_configure:	JLink:	 (0102ms, 0280ms total)
    . . . . nRFXX_write_debug_port_register:	JLink:	 (0004ms, 0285ms total)
    nRF_close_dll
    . nRFXX_close_dll
    . . nRFXX_is_connected_to_emu:	JLink:	 (0002ms, 0289ms total)
  • How did you connect it to the debugger? Have you tested with multiple boards?
