How can I bond with central device only one time?
     This is my first time to use Nordic product and I have used nRF52832 based SDK 12.0 and SoftDevice132 v2.0 about 2 months. And the IDE used for devlopment is KEIL MDK.
In my project, I do paring operation configured with static passkey and enable bond. The problem is that after every time I reset nRF52832, my smart phone using andriod system will be asked to input static passkey again when want to connect the nRF52832.
And I used 5 days to search research usefully referrence document in Chinnese website,unfortunately I can not find any useful informations about the problem in China. So,finally I can not solve the problem by self.
I do not know the detailed operations about how to paire and bond with a BLE central device like a smart phone using andriod system only one time until now, even if nRF52832 will be reset we do not need to do bonding operations again.
So, I think I need your useful help to guide me the forever bond operations step by step, as more detailed as possible, when a project need security connectivity like paire operations.
Thanks & Cheers.
The following is my key code about the configure paire and bond operations in my project.
ble_gap_sec_params_t m_sec_params;
ble_gap_sec_keyset_t m_sec_keyset;
ble_gap_enc_key_t m_own_enc_key; //need to be stored in flash
ble_gap_enc_key_t m_peer_enc_key;
static void sec_params_init()
memset(&m_sec_params, 0, sizeof(ble_gap_sec_params_t));
//Initialize m_sec_params
m_sec_params.bond = 1;
m_sec_params.mitm = 1;
m_sec_params.io_caps = BLE_GAP_IO_CAPS_DISPLAY_ONLY;
m_sec_params.min_key_size = 7;
m_sec_params.max_key_size = 16;
m_sec_params.kdist_own.enc = 1;
m_sec_params.kdist_own.id = 0;
m_sec_params.kdist_own.sign = 0;
m_sec_params.kdist_peer.enc = 1;
m_sec_params.kdist_peer.id = 0;
m_sec_params.kdist_peer.sign = 0;
memset(&m_sec_keyset, 0, sizeof(ble_gap_sec_keyset_t));
//Initialize m_sec_keyset
m_sec_keyset.keys_own.p_enc_key = &m_own_enc_key;
m_sec_keyset.keys_own.p_id_key = NULL;
m_sec_keyset.keys_own.p_pk = NULL;
m_sec_keyset.keys_own.p_sign_key = NULL;
m_sec_keyset.keys_peer.p_enc_key = &m_peer_enc_key;
m_sec_keyset.keys_peer.p_id_key = NULL;
m_sec_keyset.keys_peer.p_pk = NULL;
m_sec_keyset.keys_peer.p_sign_key = NULL;
static void on_ble_evt(ble_evt_t * p_ble_evt)
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
err_code = sd_ble_gap_authenticate(m_conn_handle,&m_sec_params);
// Pairing not supported
// err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
// APP_ERROR_CHECK(err_code);
sec_params_init();
err_code = sd_ble_gap_sec_params_reply( m_conn_handle,
BLE_GAP_SEC_STATUS_SUCCESS,
&m_sec_params,
&m_sec_keyset);
case BLE_GAP_EVT_AUTH_STATUS:
if(p_ble_evt->evt.gap_evt.params.auth_status.auth_status == BLE_GAP_SEC_STATUS_SUCCESS)
printf("\r\npair success!!!\r\n");
else{
printf("\r\npair failed!!!\r\n");
sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BLE_GAP_EVT_PASSKEY_DISPLAY:
printf("\r\npasskey: %s\r\n",p_ble_evt->evt.gap_evt.params.passkey_display.passkey);
case BLE_GAP_EVT_SEC_INFO_REQUEST:
sd_ble_gap_sec_info_reply(m_conn_handle, &(m_own_enc_key.enc_info), NULL, NULL);
printf("BLE_GAP_EVT_SEC_INFO_REQUEST\n");
// No implementation needed.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
uint8_t passkey[] = "123456";
m_static_pin_option.gap_opt.passkey.p_passkey = passkey;
err_code=sd_ble_opt_set(BLE_GAP_OPT_PASSKEY,&m_static_pin_option);
uint32_t err_code;
bool erase_bonds;
// Initialize.
APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
uart_init();
buttons_leds_init(&erase_bonds); //button 1(@pcb key2,pin14) is used as delete bonding information
ble_stack_init();
gap_params_init();
services_init();
advertising_init();
conn_params_init();
printf("\r\nUART Start!\r\n");
err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
// Enter main loop.
for (;;)
power_manage();
  • Dear Hung Bui,
             Actually I have read and modified your company provided ble_peripheral examples like "ble_app_hrs" and "ble_hid_keyboard" , but I failed although I have tried many times to modify the examples in order to implement the functionality I wanted.
            I think the reason I failed is that I do not understant all the steps which the static passkey and bonding functionality need at all.
           But in my opinion, I think the code of your examples is too complex and difficult to understand for a freshhand. Especially the wanted functionality your provided examples do not owning, the modified works will become difficult because we do not know the specific and detailed steps when lacking of the official guidance document. So it will result in the longer period for a company to develop a product when using nRF52832.
            All the provided ble_peripheral examples do not use static passkey meanwhile using bonding. Besides that I do not know how to use your library at all and all the steps when I want the nRF52832 own static passkey and bonding functionality?
           Tianfei
  • Hi Tianfei,
    Have you tried this example ? It has support for passkey bonding.
    I understand that the learning curve to get started with Nordic would be steep. We tried our best to make it's easier for you but since there are more and more features need to be supported making the library getting more complex and would need some study before you can use it.
    The best source for study I would say is by having a look at the message sequence chart, and reading the documentation of the functions provided in our library and of course the documentation on info center.
  • Dear Hung Bui,
           In the past few days, I have been learning the infocenter's instructive documents which you provied for me. Because of my poor English, the learning progress is slow. I consider much more days will be hoped for me to understand the library's architecture before I can use it.
           Many thanks for your kind help.
           Tianfei
  • Dear Hung Bui,
             After reading your provided documents, I have resolved the problem which I posted at the first time by adding some codes as following, but without using the peer manager.
    #define MY_ENC_INFO_ADDR (0x70004)
    uint32_t * const p_dst=(uint32_t *)MY_ENC_INFO_ADDR;
    uint8_t  read_flash_flag=0;
        uint32_t err_code;
        uint8_t i;
        uint8_t static temp[50];
        uint8_t static *p_temp=(uint8_t *)(&(m_own_enc_key.enc_info));
        memset(temp, 0, sizeof(temp));
                    printf("\r\nexecute sd_ble_gap_authenticate()\r\n");
                  sec_params_init();
        &m_sec_params,
        &m_sec_keyset);
                  printf("\r\nexecute sd_ble_gap_sec_params_reply()\r\n");
              if(p_ble_evt->evt.gap_evt.params.auth_status.auth_status==BLE_GAP_SEC_STATUS_SUCCESS)           {
                    printf("\r\npair success@case BLE_GAP_EVT_AUTH_STATUS!!!\r\n");
                    if(0==read_flash_flag){
                          for(i=0;i<BLE_GAP_SEC_KEY_LEN;i++){
                                   printf("\r\n@case BLE_GAP_EVT_SEC_PARAMS_REQUEST,
                                   m_own_enc_key.enc_info.ltk[%d]=0x%X\r\n",i,m_own_enc_key.enc_info.ltk[i]);
                           for(i=0;i<sizeof(ble_gap_enc_info_t);i++){
                                   temp[i]=*p_temp++;
                                   printf("\r\ntemp[%d]=%d \r\n",i,temp[i]);
                                   SEGGER_RTT_printf(0,"\r\ntemp[%d]=%d \r\n",i,temp[i]);
                           while((err_code=sd_flash_write(p_dst,(uint32_t *)temp,5))==NRF_ERROR_BUSY);
                           printf("\r\nsd_flash_write(),return value is %d \r\n",err_code);
                            read_flash_flag=1;
           else{
                  printf("\r\npair failed@case BLE_GAP_EVT_AUTH_STATUS!!!\r\n");
                // printf("\r\npasskey: %s\r\n",p_ble_evt->evt.gap_evt.params.passkey_display.passkey);
             printf("\r\n@case BLE_GAP_EVT_SEC_INFO_REQUEST\r\n");
                         printf("\r\n@case BLE_GAP_EVT_SEC_INFO_REQUEST,
    uint32_t err_code;
    bool erase_bonds;
    uint8_t i;
    uint8_t *p_flash=(uint8_t *)MY_ENC_INFO_ADDR;
    // Initialize.
    uart_init();
    ble_stack_init();
    gap_params_init(); //including configuring static key.
    services_init();
    advertising_init();
    conn_params_init();
    #ifdef RTT_DEBUG_EN
    SEGGER_RTT_Init();
    if(*p_dst!=0xffffffff){
        m_own_enc_key.enc_info=*((ble_gap_enc_info_t *)MY_ENC_INFO_ADDR);
              printf("\r\n@program initialize, m_own_enc_key.enc_info.ltk[%d]=0x%X\r\n",
        read_flash_flag=1;
    else{
        read_flash_flag=0;
    for (;;)
       nrf_delay_ms(7000);
             SEGGER_RTT_printf(0,"flash address 0x%X is 0x%X \r\n",MY_ENC_INFO_ADDR+i,*(p_flash));
             p_flash++;
       SEGGER_RTT_printf(0,"**************The end**************\r\n\r\n\r\n");
       power_manage();
              But now I have found a new problem. When I use the function "sd_flash_write()", I find it can only write the same flash address one time,if you want to use the function to write the same address of flash again ,the operation will take no effect, eventhough I have changed the value which will be written to flash. But meanwhile the return value is NRF_SUCCESS, the result makes me very confused.
              I do not know what's the reason of me in using the function "sd_flash_write()" to execute storing some datas in flash. Wish you can give some useful guidance.
    Thanks very much for your help.
    Tianfei
  • Hi Tianfei,
    You would need to erase the flash before you can write again to the same location. It's the nature of the flash. It can only change from 1 to 0. If you want to change from 0 to 1 you need to erase it first.
    Please be aware that when you call sd_flash_* functions, they are not a blocking functions. They will return immediately after the command has been queued in the softdevice not when the flash actually be written or erased. You would need to wait for a call back. Please follow the softdevice specification.
