How can I bond with central device only one time?
     This is my first time to use Nordic product and I have used nRF52832 based SDK 12.0 and SoftDevice132 v2.0 about 2 months. And the IDE used for devlopment is KEIL MDK.
In my project, I do paring operation configured with static passkey and enable bond. The problem is that after every time I reset nRF52832, my smart phone using andriod system will be asked to input static passkey again when want to connect the nRF52832.
And I used 5 days to search research usefully referrence document in Chinnese website,unfortunately I can not find any useful informations about the problem in China. So,finally I can not solve the problem by self.
I do not know the detailed operations about how to paire and bond with a BLE central device like a smart phone using andriod system only one time until now, even if nRF52832 will be reset we do not need to do bonding operations again.
So, I think I need your useful help to guide me the forever bond operations step by step, as more detailed as possible, when a project need security connectivity like paire operations.
Thanks & Cheers.
The following is my key code about the configure paire and bond operations in my project.
ble_gap_sec_params_t m_sec_params;
ble_gap_sec_keyset_t m_sec_keyset;
ble_gap_enc_key_t m_own_enc_key; //need to be stored in flash
ble_gap_enc_key_t m_peer_enc_key;
static void sec_params_init()
memset(&m_sec_params, 0, sizeof(ble_gap_sec_params_t));
//Initialize m_sec_params
m_sec_params.bond = 1;
m_sec_params.mitm = 1;
m_sec_params.io_caps = BLE_GAP_IO_CAPS_DISPLAY_ONLY;
m_sec_params.min_key_size = 7;
m_sec_params.max_key_size = 16;
m_sec_params.kdist_own.enc = 1;
m_sec_params.kdist_own.id = 0;
m_sec_params.kdist_own.sign = 0;
m_sec_params.kdist_peer.enc = 1;
m_sec_params.kdist_peer.id = 0;
m_sec_params.kdist_peer.sign = 0;
memset(&m_sec_keyset, 0, sizeof(ble_gap_sec_keyset_t));
//Initialize m_sec_keyset
m_sec_keyset.keys_own.p_enc_key = &m_own_enc_key;
m_sec_keyset.keys_own.p_id_key = NULL;
m_sec_keyset.keys_own.p_pk = NULL;
m_sec_keyset.keys_own.p_sign_key = NULL;
m_sec_keyset.keys_peer.p_enc_key = &m_peer_enc_key;
m_sec_keyset.keys_peer.p_id_key = NULL;
m_sec_keyset.keys_peer.p_pk = NULL;
m_sec_keyset.keys_peer.p_sign_key = NULL;
static void on_ble_evt(ble_evt_t * p_ble_evt)
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
err_code = sd_ble_gap_authenticate(m_conn_handle,&m_sec_params);
// Pairing not supported
// err_code = sd_ble_gap_sec_params_reply(m_conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
// APP_ERROR_CHECK(err_code);
sec_params_init();
err_code = sd_ble_gap_sec_params_reply( m_conn_handle,
BLE_GAP_SEC_STATUS_SUCCESS,
&m_sec_params,
&m_sec_keyset);
case BLE_GAP_EVT_AUTH_STATUS:
if(p_ble_evt->evt.gap_evt.params.auth_status.auth_status == BLE_GAP_SEC_STATUS_SUCCESS)
printf("\r\npair success!!!\r\n");
else{
printf("\r\npair failed!!!\r\n");
sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
case BLE_GAP_EVT_PASSKEY_DISPLAY:
printf("\r\npasskey: %s\r\n",p_ble_evt->evt.gap_evt.params.passkey_display.passkey);
case BLE_GAP_EVT_SEC_INFO_REQUEST:
sd_ble_gap_sec_info_reply(m_conn_handle, &(m_own_enc_key.enc_info), NULL, NULL);
printf("BLE_GAP_EVT_SEC_INFO_REQUEST\n");
// No implementation needed.
uint32_t err_code;
ble_gap_conn_params_t gap_conn_params;
strlen(DEVICE_NAME));
gap_conn_params.slave_latency = SLAVE_LATENCY;
gap_conn_params.conn_sup_timeout = CONN_SUP_TIMEOUT;
uint8_t passkey[] = "123456";
m_static_pin_option.gap_opt.passkey.p_passkey = passkey;
err_code=sd_ble_opt_set(BLE_GAP_OPT_PASSKEY,&m_static_pin_option);
uint32_t err_code;
bool erase_bonds;
// Initialize.
APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
uart_init();
buttons_leds_init(&erase_bonds); //button 1(@pcb key2,pin14) is used as delete bonding information
ble_stack_init();
gap_params_init();
services_init();
advertising_init();
conn_params_init();
printf("\r\nUART Start!\r\n");
err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
// Enter main loop.
for (;;)
power_manage();
  • Dear Hung Bui,
             After resolveing storing the bonding information, now I want to add the whitelist feature in my project. But I do not know how to use it and how to configure it step by step.
             I hope you can give me some instructional documents which can teach me how to use and configure the whitelist provided by SDK step by step.
           Thanks very much for your help.
            Best regards.
           Tianfei
  • Hi Tianfei,
    What you are doing is like building the peer manager from scratch. I don't see a reason why you can't use the peer manager instead of having to write everything yourself.
    We don't have a step by step guide about whitelist, but I don't think it's too complicated. You would need to follow the documentation of the function sd_ble_gap_adv_start(), sd_ble_gap_scan_start() and sd_ble_gap_connect()
    I, long ago, wrote a tutorial that has the code of using whitelist to advertise, you can have a look here
