NRF52832 unexpected PWM rate
I am using hardware PWM on NRF52832 in order to drive a MOS. I found something unexpected with the rates. i understand the PWM rate is determined by the clock divider and the counterTop value, which can be considered as the resoution in bit. So i generated a table of all available rates from DIV1 to DIV128 and from 15 bit to 4 bit resolution :
            15 14  13   12   11   10    9     8     7      6      5      4
 DIV_128    61 122 244  488  976  1953  3906  7812  15625  31250  62500  125000
 DIV_64     69 139 279  558  1116 2232  4464  8928  17857  35714  71428  142857
 DIV_32     81 162 325  651  1302 2604  5208  10416 20833  41666  83333  166666
 DIV_16     97 195 390  781  1562 3125  6250  12500 25000  50000  100000 200000
 DIV_8     122 244 488  976  1953 3906  7812  15625 31250  62500  125000 250000
 DIV_4     162 325 651  1302 2604 5208  10416 20833 41666  83333  166666 333333
 DIV_2     244 488 976  1953 3906 7812  15625 31250 62500  125000 250000 500000
 DIV_1     488 976 1953 3906 7812 15625 31250 62500 125000 250000 500000 1000000
But the table doesnt match with actual measured values, here are few rates i measured:
div128, 15bit = 3.78 Hz
div16, 15bit = 30.2 Hz
div1, 15bit = 483 Hz
While it it close in the whole range for DIV_1, it really doesnt match-up for DIV_16 and DIV_128, so i wonder what is the reason for this and how to calculate properly the PWM rates? here is what i used:
f = ((16000000 / divider ) / maxValueForResolution(bitResolution))
Thanks
    I'm not sure what you are doing wrong, but the values in your table look wrong. Your formula looks alright, but when I run the numbers I get:
    Bit width and Counter Top
    Divider (Prescaler) F_PWM_CLK 32767 16383 8191 4095 2047 1023 511 255 127 63 31 15
    128 125000 3.815 7.630 15.261 30.525 61.065 122.190 244.618 490.196 984.252 1984.127 4032.258 8333.333
    64 250000 7.630 15.260 30.521 61.050 122.130 244.379 489.237 980.392 1968.504 3968.254 8064.516 16666.667
    32 500000 15.259 30.519 61.043 122.100 244.260 488.759 978.474 1960.784 3937.008 7936.508 16129.032 33333.333
    16 1000000 30.519 61.039 122.085 244.200 488.520 977.517 1956.947 3921.569 7874.016 15873.016 32258.065 66666.667
    8 2000000 61.037 122.078 244.170 488.400 977.040 1955.034 3913.894 7843.137 15748.031 31746.032 64516.129 133333.333
    4 4000000 122.074 244.156 488.341 976.801 1954.079 3910.068 7827.789 15686.275 31496.063 63492.063 129032.258 266666.667
    1 16000000 488.296 976.622 1953.363 3907.204 7816.317 15640.274 31311.155 62745.098 125984.252 253968.254 516129.032 1066666.667
    These values seem pretty spot on when I test with a logic analyzer.
    PS: Remember that the tolerance of your PWM frequency will only ever be as accurate as your high frequency clock source. So if you rely on the internal HF RC Oscillator (HFINT) your accuracy can be off by as much as 6 %.
  • Thank you for the return, indeed the wrong values were due to the rounding in the function which printed the table and a wrong prescaler (div_2), my bad. Yes i am aware that overall accuracy of PWM frequency is determined by the HF oscillator accuracy, i use a 5ppm one.
