I want to connect nRF52832 with PC. The objective is using nRF52832(I am using BT832 Module) I have to scan all Blue Tooth deceives details and send to PC. Please help with pin connection with sample code.
Ashiq Mohammed
Ashiq Mohammed
What do you mean, "connect" ?
You mean one of these: https://www.fanstel.com/bt832-1-1/ ?
That's what the Dev Kit is for!
You could either use Fanstel's own "Evaluation Board EV BT832" - listed on that page - or a Nordic nRF52-DK
https://www.nordicsemi.com/eng/Products/Bluetooth-low-energy/nRF52-DK
Documentation is here:
Yes awneil, I am using BT832F ( https://www.fanstel.com/bt832-1-1)
I have nRF52 DK and able to program BT832F.
I am expecting diagram of Wired connection between BT832F and Desktop USB for sending data from BT832F to USB. Please help.
The nRF52832 does not have a USB peripheral. The reason it works with the nRF52832 DK is that it uses UART to communicate with the SEGGER chip on board the DK, which translates data to USB.
If you want a device that works as a USB device, you must use the nRF52840.
Edvin
Or use a USB-to-UART chip, or a USB-to-UART cable; eg,
https://www.ftdichip.com/Products/Cables/USBTTLSerial.htm
EDIT
The Fanstel Evaluation Board uses a USB-to-UART chip - you can download the schematic from the link given in my previous reply.
Thanks Edvin. I have decided to go for nRF52840. How I can send the text data to USB of nRF52840?
