No valid bidirectional (UART) communication between the iMX6 UL-S evk board running the Nordic PC BLE driver and the nRF52 DK running the Nordic connectivity 132 uart software
Hallo,
Currently I'm investigating different Low Energy Bluetooth solutions for our healtcare products that we build in Televic Healthcare.
So  here is the setup I have build to verify how fast and easy we can integrate the Nordic products into our healthcare products:
As we want still  to have our own board running the application software the Exceet IMX6 UL-S 2 evk board is used (see : https://docs.exceet-electronics.de/board-imxceet-ul-2-s/) in combination with the Nordic nRF52 DK board.
Both boards are linked together via a UART connection for bidirectional communication.
As proposed by Nordic to handle this kind of use case I have been investigating the serialize concept as described in the Nordic v15 SDK documentation.
So the Exceet board will operate as application board and the Nordic nRF52 DK board shall operate as connectivity board
However for fast proof of concept and evaluation I found the wonderful and powerful BLE driver SW provided by Nordic distributed via GIT.
So I managed to build (cross compiling for Cortex 7A processor) and run the BLE driver SW on the Exceet IMX6 board.
As mentioned both boards are connected via a UART link.
On the Nordic board that operates as connectivity board I flashed the connectivity_2.0.1_115k2_with_s132_5.0.hex (downloaded from GIT)
Unfortunately the BLE driver application on the application board exits after trying to send 6 times the LINK CTRL packet or better the SYNC message : 01 7e
The UART message as it was trapped by a logical analyzer.
Debug output:
Any ideas how to proceed further, what  further debug information can be interesting for Nordic?
I also tried to use the HR connectivity SW as provided by the latest Nordic SDK v15 for debugging via the SEGGER IDE debugger.
In that case I flashed the latest SoftDevice SW and flased the HR connectivity applic SW after it was build in the SEGGER IDE.
BTW I have also posted some comments on the github site for the BLE driver project:
https://github.com/NordicSemiconductor/pc-ble-driver/issues/143
Thanks in advance,
Frank Vieren
  • Hi , all,
    Please find my report on the PC BLE driver concept implemented on a custom board running Linux OS.
    Nordic© PC BLE driver concept implemented on a custom board-v40-20181010_1445.pdf
    Maybe most important the conclusion of  my quick succesful proto experience.
    Pros:
    • Very nice concept compared to having to implement yourself the UART driver functionality in plain C to support the HAL transport layer. In other words simplifies/speeds up the implementation process.
    • Nice C++ implementation.
    Contras:
    • Use of a patch, API version 5 PC BLE driver sources not in sync with the SDK v15 API 5.
    • Struggling when building the patched project, ble_connectivity_s132v5_hci_pca10040 in SEGGER IDE (flash_placement, debug build fails), this is not the case with the non-patched SDK v15 version.
      Strange because normally full support expected for SEGGER.
    • Not part of the Nordic SDK, it should be see the Pros.
    • Limited documentation, as far as I know no direct reference on Nordic web page cfr. SDK.
    Most surprising to me, is the fact the mismatch of the API v5 applied on the connectivity and PC BLE driver application sources. Despite the mismatch I would rather expect the patch needed on the PC BLE driver application sources regarding the sd function calls.
    Also it should be part of the SDK as it is very powerful implementation that simplifies very much the development on the custom board.
    Bjorn, thanks for the support the last days, much appreciated.
    Frank
  • thank you for the detailed report. It is of good value to get detailed insight into end products like that. You state valid comments.
    Note: I think you willl see that the build scripts and build workflow has improved in the next release of pc-ble-driver, currently consolidate-api branch.
    Thanks.
