SWDIO pin PCB layout.
I made a PCB of the nRF51822 chip and tried to program it with a simple led toggle code, but am not able to see any output, I am trying to figure out what is wrong with my PCB and why it isn't programming. I stumbled upon the nRF51 DK schematic where I saw that the SWDIO pin was pulled high by an 18k ohms resistor and was wondering if that is necessary for our design because the schematic that I got for the nRF51822 chip doesn't have the SWDIO pulled high. Is that the problem in my PCB?
Thank You.
    There is an internal pull up on the SWDIO already, so that is not a problem.
    You should only need to connect GND, VDD, SWDIO and SWDCLK to program the board. (And GND_DETECT if you are using a nRF51-DK as programmer). Make sure that VDD voltage is supported by the programmer (e.g. 3 - 3.3V if you are using a nRF51-DK as programmer).
    Kenneth
