I'm using SPI 3 to communicate with a NAND memory. I'm able to go up to 8MHz but not more than that. Do I need to set an array list or use the spi manager.
Is there any exemple of the spi going up to 16Mhz?
Best regards
Best regards
There is no example of SPIM3 with speeds > 8 MHz. It is supported by the HW, but you have to adapt the driver slightly as it only supports up to 8 MHz. Note that that you should read the errata list if you use SPIM3 as there is quite a few issues with it.
I have seen the thread about the SPIM3->IFTIMING.RXDELAY and i've set it to 2 but it doesn't work either. Do you have more information about how I should adapt the driver? I have activated the anomaly 198 workaround but no success.
I see, then all should be good. Can you let me know which SDK you are using and how you have configured and are using the SPIM3 peripheral? Seeing your code would be helpful. In what way does it not work?
We are using the SDK 15, I'm now migrating to the 15.2. The device work fine at 8Mhz but to optimize our device, we need to go up to 16Mhz.
here is the init part in our code :
void init_spi() {
// CS output
nrf_gpio_cfg_output(SPI_CS);
nrfx_spim_config_t config = NRFX_SPIM_DEFAULT_CONFIG;
config.sck_pin = SPI_SCK;
config.miso_pin = SPI_MISO;
config.mosi_pin = SPI_MOSI;
config.rx_delay = 2;
config.frequency = NRF_SPIM_FREQ_8M; // max working frequency
config.irq_priority =2;
config.mode = NRF_SPIM_MODE_0;
nrf_gpio_cfg_default(IO_NAND_IO0);
nrf_gpio_cfg_default(IO_NAND_IO1);
nrf_gpio_cfg_output(IO_NAND_IO2);
nrf_gpio_cfg_output(IO_NAND_IO3);
nrf_gpio_pin_write(IO_NAND_IO2, 1);
nrf_gpio_pin_write(IO_NAND_IO3, 1);
uint32_t err_code = nrfx_spim_init(&m_spi, &config, spi_event_handler, NULL);
Thanks for your help
I see. What happens when you set "config.frequency = NRF_SPIM_FREQ_16M;" this instead? In what way does things fail?
when I set SPIM at 16Mz, there is no clk generated anymore but the firmware is still running background.
I have not been able to reproduce this on my side. I have modified the SDK 15.2 SPI example to use SPIM3 and the nrfx driver and 16 MHz, and this works as expected on my side.
This is my main.c and sdk_config.h file:
* Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
#include "nrf_drv_spi.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "boards.h"
#include "app_error.h"
#include <string.h>
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SPI_INSTANCE 3 /**< SPI instance index. */
static const nrfx_spim_t spi = NRFX_SPIM_INSTANCE(SPI_INSTANCE); /**< SPI instance. */
static volatile bool spi_xfer_done; /**< Flag used to indicate that SPI instance completed the transfer. */
#define TEST_STRING "Nordic"
static uint8_t m_tx_buf[] = TEST_STRING; /**< TX buffer. */
static uint8_t m_rx_buf[sizeof(TEST_STRING) + 1]; /**< RX buffer. */
static const uint8_t m_length = sizeof(m_tx_buf); /**< Transfer length. */
* @brief SPI user event handler.
* @param event
void spi_event_handler(nrfx_spim_evt_t const * p_event,
void * p_context)
spi_xfer_done = true;
NRF_LOG_INFO("Transfer completed.");
if (m_rx_buf[0] != 0)
NRF_LOG_INFO(" Received:");
NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
nrfx_spim_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
spi_config.ss_pin = SPI_SS_PIN;
spi_config.miso_pin = SPI_MISO_PIN;
spi_config.mosi_pin = SPI_MOSI_PIN;
spi_config.sck_pin = SPI_SCK_PIN;
spi_config.frequency = SPIM_FREQUENCY_FREQUENCY_M16;
APP_ERROR_CHECK(nrfx_spim_init(&spi, &spi_config, spi_event_handler, NULL));
NRF_LOG_INFO("SPI example started.");
while (1)
// Reset rx buffer and transfer done flag
memset(m_rx_buf, 0, m_length);
spi_xfer_done = false;
nrfx_spim_xfer_desc_t xfer_desc = NRFX_SPIM_SINGLE_XFER(m_tx_buf, m_length, m_rx_buf, m_length);
APP_ERROR_CHECK(nrfx_spim_xfer(&spi, &xfer_desc, 0));
while (!spi_xfer_done)
__WFE();
NRF_LOG_FLUSH();
bsp_board_led_invert(BSP_BOARD_LED_0);
nrf_delay_ms(200);
Can you upload your full source code including sck_config.h so that we can compare?
#include "boards.h"
#include <string.h>
* @param event
void * p_context)
while (1)
__WFE();
NRF_LOG_FLUSH();
nrf_delay_ms(200);
