MIN_CONN_INTERVAL and MAX_CONN_INTERVAL using ble_nus_data_send.
Im using SDK 15 ble pheripheral and central uart example on my custom nrf52832 board.
I would like to know how to set  MIN_CONN_INTERVAL and MAX_CONN_INTERVAL for connection when im sending 20bytes
in frame every 8ms using timer for 60 seconds continously. How to calculate it?
  • Very sorry for the delayed response. If you are using 52832 on both central & peripheral & set the MIN & MAX_CONN_INTERVAL to 7.5 ms, this should work. Could you please try it out & let me know?
    Update: These links could also be helpful: link 1, link 2, link 3, link 4, link 5, link 6, link 7.
  • 7.5 min and max  disconnecting much more than min 8ms and max 9ms settings.
  • How often does setting the min to 8 ms & the max to 9 ms result in a disconnection?
  • A disconnect may happen when the central does not accept the connection interval parameters. In this case a BLE_GAP_EVT_CONN_PARAM_UPDATE event is received with the parameters selected by the central. The peripheral attempts to update the parameters max_conn_params_update_count times, which will obviously fail since it keeps trying the same values. Next a BLE_CONN_PARAMS_EVT_FAILED is received and the connection drops. Usually the handler calls sd_ble_gap_disconnect, then the central reconnects. If it doesn't call this, then the central remains connected, but no further communication is possible. When first_conn_params_update_delay is 5, next_conn_params_update_delay is 30, and max_conn_params_update_count is 3, the expected time between disconnects is 95 seconds.
    The solution is to negotiate the parameters: When BLE_GAP_EVT_CONN_PARAM_UPDATE is received, check if the values match what the peripheral asked for. If not, I would reduce min, since I prefer low latency. If that fails too, I would set max to whatever the central suggested, and then it should work. Call ble_conn_params_change_conn_params with the new values.
    The iPhone behaviour in particular deprived of any sane logic. If you ask for 20-20 it will use 33.75. It will happily accept 15 or 30, then it jumps up 3 steps or 3.75 ms. One might think that simply using 45-45 will work since the value is supported, but the iPhone will refuse it and use 60 instead. But if we say 30-45, it will agree on 45.
