After build and run my device is stuck in DfuTarg and it is not jump in the application ? I am using SES nRF5_SDK_15.0.0_a53641a library and s132_nrf52_6.0.0_softdevice.hex
This is my Output, Looks good but not working/
Preparing target for download
Executing script TargetInterface.resetAndStop()
Reset: Halt core after reset via DEMCR.VC_CORERESET.
Reset: Reset device via AIRCR.SYSRESETREQ.
Downloading ‘s132_nrf52_6.0.0_softdevice.hex’ to J-Link
Programming 2.3 KB of addresses 00000000 — 00000967
Programming 142.5 KB of addresses 00001000 — 00024a23
J-Link: Flash download: Bank 0 @ 0x00000000: Skipped. Contents already match
Downloading ‘ble_app_hrs_pca10040_s132.elf’ to J-Link
Programming 38.9 KB of addresses 00026000 — 0002fbdb
Programming 0.0 KB of addresses 0002fbdc — 0002fc1f
Programming 0.0 KB of addresses 0002fc20 — 0002fc33
Programming 4.1 KB of .rodata addresses 0002fc34 — 00030cc3
Programming 0.1 KB of addresses 00030cc4 — 00030d3f
J-Link: Flash download: Bank 0 @ 0x00000000: 1 range affected (45056 bytes)
J-Link: Flash download: Total time needed: 0.894s (Prepare: 0.055s, Compare: 0.008s, Erase: 0.028s, Program: 0.773s, Verify: 0.001s, Restore: 0.027s)
Connecting ‘J-Link’ using ‘USB 158007781’
Connecting to target using SWD
Loaded C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 3.52/bin/JLink_x64.dll
Firmware Version: J-Link ARM V8 compiled Nov 28 2014 13:44:46
DLL Version: 6.34e
Hardware Version: V8.00
Target Voltage: 3.131
Device "NRF52832_XXAA" selected.
Found SW-DP with ID 0x2BA01477
Scanning AP map to find all available APs
AP[2]: Stopped AP scan as end of AP map has been reached
AP[0]: AHB-AP (IDR: 0x24770011)
AP[1]: JTAG-AP (IDR: 0x02880000)
Iterating through AP map to find AHB-AP to use
AP[0]: Core found
AP[0]: AHB-AP ROM base: 0xE00FF000
CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
Found Cortex-M4 r0p1, Little endian.
FPUnit: 6 code (BP) slots and 2 literal slots
CoreSight components:
ROMTbl[0] @ E00FF000
ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
Downloading ‘Fuel_BLE.hex’ to J-Link
Programming 90.5 KB of addresses 00026000 — 0003ca49
Programming 11.8 KB of addresses 0003ca4c — 0003f9a3
J-Link: Flash download: Bank 0 @ 0x00000000: 1 range affected (53248 bytes)
J-Link: Flash download: Total time needed: 1.108s (Prepare: 0.071s, Compare: 0.049s, Erase: 0.032s, Program: 0.914s, Verify: 0.001s, Restore: 0.039s)
Downloading ‘Fuel_BootLoader.hex’ to J-Link
Programming 33.0 KB of addresses 00072000 — 0007a459
Programming 13.5 KB of addresses 0007a45c — 0007da9f
Programming 0.0 KB of addresses 10001014 — 1000101b
J-Link: Flash download: Bank 0 @ 0x00000000: 1 range affected (4096 bytes)
J-Link: Flash download: Total time needed: 0.181s (Prepare: 0.056s, Compare: 0.069s, Erase: 0.009s, Program: 0.016s, Verify: 0.001s, Restore: 0.027s)
Downloading ‘Bootloader_setting.hex’ to J-Link
Programming 0.0 KB of addresses 0007f000 — 0007f05b
    Based on your description, it sounds that the bootloader settings page in not generated correctly.
    And looking at the logs, it looks like you are first flashing " ble_app_hrs_pca10040_s132” as the application and then the “Fuel_BLE.hex” .
    How are you generating the bootloader settings page ?
    Like this snippet?
    nrfutil settings generate --family NRF52 --Fuel_BLE.hex.hex --application-version 0 --bootloader-version 0 --bl-settings-version 1 settings.hex
    You could also try to flash the different .hex files using nRF Connect for Desktop's programming app, and see if that makes any difference.
