RESETREAS issue after WD Reset
Hi, I am using nRF5_SDK_15.0.0_a53641a.
I'm using code below to start WD and I'm not feeding WD.
NRF_WDT->CONFIG = (WDT_CONFIG_HALT_Pause << WDT_CONFIG_HALT_Pos) | ( WDT_CONFIG_SLEEP_Run << WDT_CONFIG_SLEEP_Pos);
NRF_WDT->CRV = 10*32768;             // 10sec timout
NRF_WDT->RREN |= WDT_RREN_RR0_Msk;  // Enable reload register 0
NRF_WDT->TASKS_START = 1;           // Start the Watchdog timer
After WD reset, I'm looking at RESETREAS register and DOG bit is not high, only PINRESET is high.
What am I missing?
I found that in in system_nrf52840.c there is errata136 that resets all bits but PINRESET, when I remove that code it works fine. Why does this errata exist and if I need it?
    After WD reset, I'm looking at RESETREAS register and DOG bit is not high, only PINRESET is high.  What am I missing?
    After PINRESET bit is set, you need to clear the RESETREAS register yourself after you have read the register and taken appropriate actions based on the value. If you don't clear the register, the DOG bit will always be masked out after a PINRESET.
    Snippet:
        do_something_based_on_resetreas_value();
        // Action taken. Now clear the flag
        NRF_POWER->RESETREAS = 0xFFFFFFFF;
  • I too have stumbled upon this problem.
    I am getting a genuine watchdog reset but errata136 is wiping the status from the watchodg register.
    I was relyng on this as designed to log reset reasons; why is this bit being cleared by this errata.
    And when is the bug being fixed so we may use this status register properly?
  • Hi Owain,
    See this post. Quote:
    "Are you clearing the RESETREAS register after you read it out on startup? The reason I ask is that workaround for errata 136 implemented in system_nrf52.c will clear the other bits if the PINRESET bit is set. In other words, you can expect to see this behavior if you don't clear the register, and you have done a pinreset since the last power-on reset. "
  • I have done nothing with the RESETREAS rgeister. I just see its contents using my debugger.
    Scenario I have is we are going through our bootrom; starting our application and I am seeing an unexpected reset. We don't start the watchdog until we start our application.
    Selecting our application project I was seeing a restart and NOT hitting any fault handler or NVIC reset breakpoint; so I suspected a watchdog; hence setting a breakpoint in the bootrom early on before the errata stuff is processed. In this situation I see the DOG and Reset bits set. If I restart via the debugger then I only the Reset bit.
    I may only be seeing this issue when rhe device is connected on a segger JLink. Selecting our application project I was seeing a restart and not hitting any fault handler breakpoint; so I suspected a watchdog. I don't understand this.
  • Please be aware of what sources that are resetting, and not resetting the watchdog. See this link.
    Also be aware of how the watchdog CONFIG register is set. See this link
    If you are still having issues with this, please create a new support case. See this link.
