stop and restart SAADC to power saving
Hello, I'm using softdevice 6.0 and SDK 15.
In my application, I would like stop the SAADC at the disconnection and then restart SAADC at the connection to power saving.
To start SAADC I use this code:
void saadc_init(void)
    ret_code_t err_code;
    err_code = nrf_drv_saadc_init(NULL, saadc_callback);
    err_code = nrf_drv_saadc_channel_init(0, &channel_config_PRESSURE);
    err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
To launch a sampling I use the call:
nrf_drv_saadc_sample();
To stop the SAADC I use the call:
nrf_drv_saadc_uninit()
The problem is that after the stop the interrupt handler of SAADC no longer works.
The code for interrupt handler is the following:
  nrf_saadc_value_t adc_result;
  uint16_t pressure_mV_local;
  uint16_t pressure_mV_acc;
  int i;
  char debug_str[10] = {0};
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
        adc_result = p_event->data.done.p_buffer[0];
What is the correct procedure to stop and then to restart the SAADC?
Thanks
