Full UUID values for Blood Pressure App
I'm using the Nordic nRF Toolbox Blood Pressure Monitor "BPM" app on my phone and I have the development software running.  Things work fine.  However, I'm trying to figure out what exactly the complete UUID is for the information that I'm sending across.
All I have been able to find is:
static ble_uuid_t m_adv_uuids[] =                                       /**< Universally unique service identifiers. */
    {BLE_UUID_BLOOD_PRESSURE_SERVICE,     BLE_UUID_TYPE_BLE},
    {BLE_UUID_BATTERY_SERVICE,            BLE_UUID_TYPE_BLE},
    {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
But I want to know what the full 128 bit UUID is so I can begin to write my own program.  Along those same lines, if anyone can point me to the function calls to modify them I would appreciate it, but I would like to know where the default ones are coming from as well.
Thanks for the help!
  • Some follow up info:
    I am using soft device s132, SDK 15.0.0 and the chip is an NRF52 device.
    Essentially I need to create a new UUID base id, and I can't see in the firmware where I can add in my new custom 128 bit UUID.  I can't find in the documentation how to do this or what files the information would be in.
  • Use ble_app_uart example (UART/Serial Port Emulation over BLE) as a template. The Nordic Uart Service uses a 128-bit Vendor Specific UUID. See NUS_BASE_UUID on line 64 of ble_nus.c.
    The nRF Connect app on android has a detailed log that show the full UUIDs that you interact with when connected to a device. Just swipe right on the main screen to access the logs.
  • I tried to run the example program, but ran into two issues.  One, I got a compile error for
    Building ‘ble_app_uart_pca10040_s132’ from solution ‘ble_app_uart_pca10040_s132’ in configuration ‘Debug’
      Compiling ‘retarget.c’
        conflicting types for '__putchar'
        retarget.c
        previous declaration of '__putchar' was here
    Build failed
    After trying to work around that, I'm getting an error for:
    UART started.
    <info> app: Debug logging for UART over RTT started.
    <error> app: ERROR 2 [NRF_ERROR_SOFTDEVICE_NOT_ENABLED] at C:\Sandbox\...
    Is this example a good one to use?  I'm using SES and board PCA10040, not sure why this is giving me issues when I haven't made any changes to it.
  • The examples should all compile out of the box. Most likely you've inadvertently  made changes to the SDK libraries/drivers, folder structure, or the sdk_config.h file included in the example. It could also be a path issue in windows because it only supports 256 character long paths.
    Either way I suggest you download a new SDK 15.2 and place it as close to the c:/ disk root as possible, and then try to compile the ble_app_uart example.
