Voltage divider/thermistor: GPIO high, ADC read, get temperature, GPIO low
I have a voltage divider/thermistor circuit where R1 is an NTC thermistor of 100kOhm at 25°C. R2 is 100kOhm right now.
I took peripheral_saadc example for SDK15 and modified it to get the temperature readings in saadc_callback(); Temperature conversion algorithm is equal to the ones used in:
learn.adafruit.com/.../using-a-thermistor
www.jameco.com/.../temperature-measurement-ntc-thermistors.html
https://devzone.nordicsemi.com/f/nordic-q-a/14583/nrf52832-saadc-sampling
The current during my normal measurement should not exceed ~0.4mA (102kOhm over 3.6V) and I was thinking to use a GPIO as the Vin for the divider circuit.
I would like to: Set GPIO high -> get ADC value -> Clear GPIO -> Calculate temperature - > repeat minimum every 1 second;
How to do it? I am able to power the voltage divider from GPIO but I am unsure where should I make the switch? I cannot make it in the saadc_callback() because if I understand correctly, ADC conversion is already done at that point. Switching GPIO high needs to occur probably some time before ADC sample...
    Setup an app_timer to run at 1 second interval, you should find examples that show how to use app_timer in the SDK (for instance the BLE examples).
    The app_timer timeout handler (callback) can set the GPIO high and start the saadc conversion.
    The saadc handler (callback) can calculate the temperature and set the GPIO low again.
    Kenneth
  • Thank you for your response, I managed to implement this solution by calling "nrf_drv_saadc_sample();" from my app_timer function and using other example pieces.
    The problem is with switching the GPIO for ADC measurement... When voltage divider is powered by GPIO pin then I am getting correct ADC readings for my application. However, if I:
    toggle GPIO HIGH->perform ADC->toggle GPIO LOW then the values I am getting are very low (multimeter shows the voltage of 0.37V).
    I suspect that the GPIO does not reach the ultimate "HIGH" state when the measurements are already taken and pin toggled low again. I do not have an oscilloscope right now to confirm it but I will keep tweaking it. In case of any suggestions, ideas, please let me know Slight smile
    Cheers!
  • It make sense, try to #include "nrf_delay.h" in your project and add a small delay, e.g:
    toggle GPIO HIGH->nrf_delay_us(100);->perform ADC
  • Problem solved. The trick was to place a small delay after the ADC measurement and then clear the GPIO. If the delay was placed after toggling GPIO high, taking the measurement and toggling low, the measurements were wrong. I could place in there a 1000us delay without any success while 10us after sampling is enough.
    I guess placing the delay after the ADC sampling made sure that the samples were taken before unpowering the sensor but I can not prove the fact as I do not have an oscilloscope at hand.
    If anybody has a good explanation before closing this thread, it would be nice. How does delay help to get the measurement? Isn't the processor "not doing anything" during the delay?
    void saadc_thermistor_get_adc(){
        ret_code_t err_code;
        nrf_gpio_pin_set(PIN);
        err_code = nrf_drv_saadc_sample();
        nrf_delay_us(10);
        nrf_gpio_pin_clear(PIN);
  • I though you had implemented it differently, where you would clear the pin after the measurement was ready, not after starting the measurement. In your case you should have a delay equal TACQ:
    http://infocenter.nordicsemi.com/topic/com.nordic.infocenter.nrf52832.ps.v1.1/saadc.html?cp=2_1_0_36_8#concept_qh3_spp_qr
