I am using fatfs of nRF5_SDK_15.0.0_a53641a.
I am writing a program with keil.
I am currently doing SPI communication with BLENanov2(nRF52832) and SD card with fatfs.
Fullscreen
1
2
3
4
#define SDC_SCK_PIN 2 ///< SDC serial clock (SCK) pin.
#define SDC_MOSI_PIN 29 ///< SDC serial data in (DI) pin.
#define SDC_MISO_PIN 30 ///< SDC serial data out (DO) pin.
#define SDC_CS_PIN 28 ///< SDC chip select (CS) pin.
I tried writing fatfs by SPI communication with the pin setting as above and it was possible to write without problem.
At this time, in sdk_config
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
// <e> SPI0_ENABLED - Enable SPI0 instance
#ifndef SPI0_ENABLED
#define SPI0_ENABLED 1
// <q> SPI0_USE_EASY_DMA - Use EasyDMA
#ifndef SPI0_USE_EASY_DMA
#define SPI0_USE_EASY_DMA 1
// </e>
// <e> SPI1_ENABLED - Enable SPI1 instance
#ifndef SPI1_ENABLED
#define SPI1_ENABLED 0
// <q> SPI1_USE_EASY_DMA - Use EasyDMA
#ifndef SPI1_USE_EASY_DMA
#define SPI1_USE_EASY_DMA 1
It has become like.
Here,SPI communication will be done with a different pin
Fullscreen
1
2
3
4
#define SDC_SCK_PIN 8 ///< SDC serial clock (SCK) pin.
#define SDC_MOSI_PIN 6 ///< SDC serial data in (DI) pin.
#define SDC_MISO_PIN 7 ///< SDC serial data out (DO) pin.
#define SDC_CS_PIN 3 ///< SDC chip select (CS) pin.
When I set the pin like this,I can not write SDcard.
Please tell me how to resolve.
Thank you.
