I am using fatfs of nRF5_SDK_15.0.0_a53641a.
I am writing a program with keil.
I am currently doing SPI communication with BLENanov2(nRF52832) and SD card with fatfs.
#define SDC_SCK_PIN 2 ///< SDC serial clock (SCK) pin. #define SDC_MOSI_PIN 29 ///< SDC serial data in (DI) pin. #define SDC_MISO_PIN 30 ///< SDC serial data out (DO) pin. #define SDC_CS_PIN 28 ///< SDC chip select (CS) pin.
I tried writing fatfs by SPI communication with the pin setting as above and it was possible to write without problem.
At this time, in sdk_config
// <e> SPI0_ENABLED - Enable SPI0 instance //========================================================== #ifndef SPI0_ENABLED #define SPI0_ENABLED 1 #endif // <q> SPI0_USE_EASY_DMA - Use EasyDMA #ifndef SPI0_USE_EASY_DMA #define SPI0_USE_EASY_DMA 1 #endif // </e> // <e> SPI1_ENABLED - Enable SPI1 instance //========================================================== #ifndef SPI1_ENABLED #define SPI1_ENABLED 0 #endif // <q> SPI1_USE_EASY_DMA - Use EasyDMA #ifndef SPI1_USE_EASY_DMA #define SPI1_USE_EASY_DMA 1 #endif // </e> // <e> SPI2_ENABLED - Enable SPI2 instance
#define SDC_SCK_PIN 8 ///< SDC serial clock (SCK) pin. #define SDC_MOSI_PIN 6 ///< SDC serial data in (DI) pin. #define SDC_MISO_PIN 7 ///< SDC serial data out (DO) pin. #define SDC_CS_PIN 3 ///< SDC chip select (CS) pin.
