Thingy52 sleep_mode_enter() Runs Bootloader Instead of Restarting Program
Hi, when my program calls sleep_mode_enter(), it enters system off (deep sleep) as expected. However, when I press the button on the Thingy52 to wake up, the bootloader starts running instead of my program restarting.
Below is my sleep_mode_enter() function. Any advice on how to get my program to restart instead of running the bootloader upon a button press would be appreciated. Thanks in advance.
/**@brief Function for putting Thingy into sleep mode.
    uint32_t err_code;
    drv_ext_light_rgb_intensity_t color;
    NRF_LOG_INFO("Entering sleep mode \r\n");
    err_code = support_func_configure_io_shutdown();
    // Enable wake on button press.
    nrf_gpio_cfg_sense_input(BUTTON, NRF_GPIO_PIN_PULLUP, NRF_GPIO_PIN_SENSE_LOW);
    color.r = 128;
    color.g = 12
    color.b = conf_ui.data.mode_const.b;
    err_code = drv_ext_light_rgb_intensity_set(DRV_EXT_RGB_LED_LIGHTWELL, &color);
    // nrf_gpio_cfg_input(MIC_DOUT, NRF_GPIO_PIN_NOPULL);
    // err_code = drv_ext_gpio_pin_set(SX_MIC_PWR_CTRL);
    NRF_LOG_FLUSH();
    nrf_delay_ms(5);
    // Go to system-off (sd_power_system_off() will not return; wakeup will cause a reset). When debugging, this function may return and code execution will continue.
    NRF_LOG_WARNING("sd_power_system_off() returned. -Probably due to debugger being used. Instructions will still run. \r\n");
    NRF_LOG_FLUSH();
    #ifdef DEBUG
        if(!support_func_sys_halt_debug_enabled())
            APP_ERROR_CHECK(err_code); // If not in debug mode, return the error and the system will reboot.
            NRF_LOG_WARNING("Exec stopped, busy wait \r\n");
            NRF_LOG_FLUSH();
            while(true) // Only reachable when entering emulated system off.
                // Infinte loop to ensure that code stops in debug mode.
    #else
