SPIS set buffer
I have a doubt regarding buffer setting in SPIS.
In the SDK15 SPIS example, buffers are set using nrfx_spis_buffers_set(...) and it works perfectly.
I was wondering if it's possible to avoid the buffer_set cal, setting a fixed RAM region using, for example:
   NRF_SPIS1->TXD.PTR = &my_data
   NRF_SPIS1->TXD.MAXCNT = my_data_size
(my_data is updated periodically every 500us)
Does nrfx_spis_buffers_set have to be called for every SPI transaction or is there any alternative method?
Marco
  • If you want to re-use your tx/rx buffers then you only need to call nrfx_spis_buffers_set once during initialization. The SPIS will use whatever's in the RXD/TXD registers and it does not reset the register after a transaction is completed.
  • Thank you haakonsh for your reply.
    Starting from the SDK example I deleted the nrf_drv_spis_buffers_set row in while(1) and I made these attempts:
    • I set the buffers after the initialization:
        NRF_LOG_INFO("SPIS example");
        nrf_drv_spis_config_t spis_config = NRF_DRV_SPIS_DEFAULT_CONFIG;
        spis_config.csn_pin               = APP_SPIS_CS_PIN;
        spis_config.miso_pin              = APP_SPIS_MISO_PIN;
        spis_config.mosi_pin              = APP_SPIS_MOSI_PIN;
        spis_config.sck_pin               = APP_SPIS_SCK_PIN;
        APP_ERROR_CHECK(nrf_drv_spis_init(&spis, &spis_config, spis_event_handler));
    	  nrf_drv_spis_buffers_set(&spis, m_tx_buf, m_length, m_rx_buf, m_length);
    In this way the SPIS sends correctly only during the fist HITOLO transition of master chip select, then the MISO becomes HIGH and doesn't trasmit data anymore.
    • I set the buffers also in the spis_event_handler, like in the code below reported:
    void spis_event_handler(nrf_drv_spis_event_t event)
        if (event.evt_type == NRF_DRV_SPIS_XFER_DONE)
            spis_xfer_done = true;
            NRF_LOG_INFO(" Transfer completed. Received: %s",(uint32_t)m_rx_buf);
    In this way the SPIS works fine but I have to recall nrf_drv_spis_buffers_set for every transition.
    I didn't change anything also from the example code, I report it for completeness:
     * Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    #include "sdk_config.h"
    #include "nrf_drv_spis.h"
    #include "nrf_gpio.h"
    #include "boards.h"
    #include "app_error.h"
    #include <string.h>
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define SPIS_INSTANCE 1 /**< SPIS instance index. */
    static const nrf_drv_spis_t spis = NRF_DRV_SPIS_INSTANCE(SPIS_INSTANCE);/**< SPIS instance. */
    #define TEST_STRING "Nordic"
    static uint8_t       m_tx_buf[] = TEST_STRING;           /**< TX buffer. */
    static uint8_t       m_rx_buf[sizeof(TEST_STRING) + 1];    /**< RX buffer. */
    static const uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
    static volatile bool spis_xfer_done; /**< Flag used to indicate that SPIS instance completed the transfer. */
     * @brief SPIS user event handler.
     * @param event
        // Enable the constant latency sub power mode to minimize the time it takes
        // for the SPIS peripheral to become active after the CSN line is asserted
        // (when the CPU is in sleep mode).
        NRF_POWER->TASKS_CONSTLAT = 1;
        while (1)
            memset(m_rx_buf, 0, m_length);
            spis_xfer_done = false;
    //        APP_ERROR_CHECK(nrf_drv_spis_buffers_set(&spis, m_tx_buf, m_length, m_rx_buf, m_length));
            while (!spis_xfer_done)
                __WFE();
            NRF_LOG_FLUSH();
            bsp_board_led_invert(BSP_BOARD_LED_0);
    Did I make any mistake during the initialization?
  • I am connecting 2 nrf52832 boards. The SPI master works with the "spi" SDK example.
