I got the fail result of the test CPS/SEN/SPE/BI-05-C [Cycling Power Control Point Procedure Timeout].
At this test, the tester does not send the confirmation until ATT Transaction Timeout expired.
Our App does not know whether get the confirmation from tester or not. So the product will send the notifications after ATT Transaction Timeout, and the test failed.
Could you tell me how to check the confirmation from the tester?
I send the indication to the tester as follows.
memset(&hvx_params, 0, sizeof(hvx_params));
hvx_params.handle = p_cp_ctrlpt->cp_ctrlpt_handles.value_handle;
hvx_params.type = BLE_GATT_HVX_INDICATION;
hvx_params.offset = 0;
hvx_params.p_len = &hvx_len;
hvx_params.p_data = encoded_ctrl_rsp;
err_code = sd_ble_gatts_hvx(p_cp_ctrlpt->conn_handle, &hvx_params);
How can I get the information of the confirmation from the tester?
test-log
CPS/SEN/SPE/BI-05-C
Tuesday, October 02, 2018, 16:35:15
+0 ms
Initialize Test Case: Build date: Jul 18 2018, 09:31:58
+0 ms
Start Test Case: CPS/SEN/SPE/BI-05-C
+0 ms
Message: PTS Log started on Tuesday, October 02, 2018, 16:35:15
+0 ms
Message: PTS: v7.3.0 Build 40
+0 ms
Message: OS: Microsoft Windows NT 6.1.7601 Service Pack 1
+0 ms
Message: OS Name: Microsoft Windows 7 Home Premium
+4009 ms
Preliminary Verdict: PASS
+4056 ms
Send Event: HCI!HCI_RESET
+4181 ms
Receive Event: HCI?HCI_RESET_COMPLETE_EVENT{
status=HCI_OK
+4181 ms
+4181 ms
Send Event: HCI!HCI_SET_EVENT_MASK{
eventMask=0x3FFFFFFFFFFFFFFF
+4181 ms
Receive Event: HCI?HCI_SET_EVENT_MASK_COMPLETE_EVENT{
status=HCI_OK
+4181 ms
+4181 ms
Send Event: HCI!HCI_READ_LOCAL_VERSION_INFORMATION
+4181 ms Receive Event: HCI?HCI_READ_LOCAL_VERSION_INFORMATION_COMPLETE_EVENT{
status=HCI_OK,
hciVersion=HCI_VERSION_4_0,
hciRevision=0x2031,
lmpVersion=0x06,
manufacturerName=0x000A,
lmpSubversion=0x2031
+4181 ms
+4181 ms
Send Event: HCI!HCI_READ_BD_ADDR
+4196 ms
Receive Event: HCI?HCI_READ_BD_ADDR_COMPLETE_EVENT{
status=HCI_OK,
bdAddress=0x001BDC0808A3
+4196 ms
+4196 ms
Send Event: HCI!HCI_LE_SET_EVENT_MASK{
leEventMask=0x000000000000001F
+4196 ms
Receive Event: HCI?HCI_LE_SET_EVENT_MASK_COMPLETE_EVENT{
status=HCI_OK
+4196 ms
+4196 ms
Send Event: HCI!HCI_WRITE_LE_HOST_SUPPORTED{
leSupportedHost=HCI_LE_SUPPORTED_HOST_ENABLED,
simultaneousLeHost=HCI_SIMULTANEOUS_LE_HOST_ENABLED
+4196 ms
Receive Event: HCI?HCI_WRITE_LE_HOST_SUPPORTED_COMPLETE_EVENT{
status=HCI_OK
+4196 ms
+4196 ms
Send Event: HCI!HCI_LE_CLEAR_WHITE_LIST
+4227 ms
Receive Event: HCI?HCI_LE_CLEAR_WHITE_LIST_COMPLETE_EVENT{
status=HCI_OK
+4227 ms
+4227 ms
Send Event: HCI!HCI_WRITE_SIMPLE_PAIRING_MODE{
simplePairingMode=HCI_SIMPLE_PAIRING_ENABLED
+4227 ms
Receive Event: HCI?HCI_WRITE_SIMPLE_PAIRING_MODE_COMPLETE_EVENT{
status=HCI_OK
+4227 ms
+4227 ms
+4227 ms
Send Event: HCI!HCI_LE_ADD_DEVICE_TO_WHITE_LIST{
addressType=HCI_LE_PUBLIC_DEVICE_ADDRESS,
address=0xC58DCE70012F
+4243 ms
Receive Event: HCI?HCI_LE_ADD_DEVICE_TO_WHITE_LIST_COMPLETE_EVENT{
status=HCI_OK
+4243 ms
+4243 ms
addressType=HCI_LE_RANDOM_DEVICE_ADDRESS,
+4243 ms
status=HCI_OK
+4243 ms
+4243 ms
+4243 ms
+4243 ms
Send Event: HCI!HCI_LE_SET_SCAN_PARAMETERS{
leScanType=HCI_LE_ACTIVE_SCANNING,
leScanInterval=0x001E,
leScanWindow=0x001E,
ownAddressType=HCI_LE_PUBLIC_DEVICE_ADDRESS,
scanningFilterPolicy=HCI_LE_ACCEPT_WHITE_LIST_ADVERTISING_PACKETS
+4259 ms
Receive Event: HCI?HCI_LE_SET_SCAN_PARAMETERS_COMPLETE_EVENT{
status=HCI_OK
+4259 ms
+4290 ms
Send Event: HCI!HCI_LE_SET_SCAN_ENABLE{
leScanEnable=HCI_LE_SCAN_ENABLE,
filterDuplicates=HCI_LE_DUPLICATE_FILTERING_DISABLE
+5226 ms
+5226 ms
+9235 ms
+9235 ms
+11247 ms
+11247 ms
leScanEnable=HCI_LE_SCAN_DISABLE,
+11263 ms
+11279 ms
Send Event: ATT!ATT_CONNECT_REQ{
peerAddr=0xC58DCE70012F,
peerAddrType=HCI_LE_RANDOM_DEVICE_ADDRESS,
ownAddrType=HCI_LE_PUBLIC_DEVICE_ADDRESS,
minInterval=0x0032,
maxInterval=0x0046,
latency=0x0000
+13260 ms
Receive Event: SEC?SEC_LE_REMOTE_CSRK_REQUEST_REQ{
+13260 ms
Send Event: SEC!SEC_LE_REMOTE_CSRK_REQUEST_RSP{
accept=FALSE,
keyType=HCI_UNAUTHENTICATED_COMBINATION_KEY,
csrk=0x00000000000000000000000000000000,
signCounter=0x00000000
+13260 ms
Receive Event: ATT?ATT_CONNECT_RSP{
bdAddr=0xC58DCE70012F,
lcid=0x0040, status=HCI_OK
+13260 ms
Receive Event: HCI?HCI_LE_CONNECTION_COMPLETE_EVENT{
status=HCI_OK,
connectionHandle=0x004D,
role=HCI_ROLE_MASTER,
peerAddressType=HCI_LE_RANDOM_DEVICE_ADDRESS,
peerAddress=C58DCE70012F,
connInterval=0x0046,
connLatency=0x0000,
supervisionTimeout=0x07D0,
clockAccuracy=HCI_LE_CLOCK_ACCURACY_500PPM
+13275 ms
+13275 ms
Verdict Description: Connection setup successfully.
+13275 ms
Pass: Tester successfully initiated connection.
+13275 ms
Verdict Description: Tester successfully initiated connection.
+13275 ms
Verdict Description: LE Security not initiated due to TSPX_security_enabled value.
+13275 ms
Send Event: ATT!ATT_FIND_BY_TYPE_VALUE_REQ{
lcid=0x0040,
startingHandle=0x0001,
endingHandle=0xFFFF,
attributeType=0x2800,
length=0x0002,
PrimaryService=0x1818
+13431 ms
Receive Event: ATT?ATT_FIND_BY_TYPE_VALUE_RSP{
lcid=0x0040,
HandleRange={
foundAttributeHandle=0x000F,
endFoundHandle=0x0019
+13619 ms
Receive Event: ATT?ATT_FIND_BY_TYPE_VALUE_CFM{
lcid=0040,
result=0x0100,
errorHandle=0x0000,
HandleRanges={
endFoundHandle=0x0019,
+13619 ms
+13619 ms
Verdict Description: Discover Primary Service by Service UUID Request completed successfully.
+13619 ms
Pass: The IUT successfully returned the UUID for Cycling Power
+13619 ms
Verdict Description: The IUT successfully returned the UUID for Cycling Power
+13619 ms
Send Event: ATT!ATT_READ_BY_TYPE_REQ{
lcid=0x0040,
startingHandle=0x000F,
endingHandle=0x0019,
attributeTypeSize=0x02,
attributeType=0x2803
+13790 ms
Receive Event: ATT?ATT_READ_BY_TYPE_RSP{
handle=0x0010
value{
Properties=0x10,
Handle=0x0011,
UUID=0x2A63
handle=0x0013
value{
Properties=0x02,
Handle=0x0014,
UUID=0x2A65
handle=0x0015
value{
Properties=0x02,
Handle=0x0016,
UUID=0x2A5D
+13962 ms
handle=0x0017
value{
Properties=0x28,
Handle=0x0018,
UUID=0x2A66
+14133 ms
Receive Event: ATT?ATT_READ_BY_TYPE_CFM{
lcid=0x0040,
attributeType=0x2803,
result=0x0100,
errorHandle=0x0000
+14133 ms
handle=0x0010
value{
Properties=0x10,
Handle=0x0011,
UUID=0x2A63
handle=0x0013
value{
Properties=0x02,
Handle=0x0014,
UUID=0x2A65
handle=0x0015
value{
Properties=0x02,
Handle=0x0016,
UUID=0x2A5D
handle=0x0017
value{
Properties=0x28,
Handle=0x0018,
UUID=0x2A66
+14133 ms
+14133 ms
Verdict Description: Discover All Characteristics of Service Request completed successfully.
+14133 ms
Send Event: ATT!ATT_FIND_INFO_REQ{
lcid=0x0040,
startingHandle=0x0012,
endingHandle=0x0012
+14305 ms
Receive Event: ATT?ATT_FIND_INFO_CFM{
lcid=0x0040,
result=0x0100,
errorHandle=0x0000
+14305 ms
Receive Event: ATT?ATT_FIND_INFO_RSP{ {
handle=0x0012,
uuid=0x2902
+14305 ms
handle=0x0012,
uuid=0x2902,
+14305 ms
+14305 ms
Verdict Description: Discover All Characteristic Descriptors Request completed successfully.
+14305 ms
lcid=0x0040,
startingHandle=0x0019,
endingHandle=0x0019
+14492 ms
lcid=0x0040,
result=0x0100,
errorHandle=0x0000
+14492 ms
handle=0x0019,
uuid=0x2902
+14492 ms
handle=0x0019,
uuid=0x2902,
+14492 ms
+14492 ms
+14492 ms
Send Event: ATT!ATT_WRITE_REQ{
lcid=0x0040,
attributeHandle=0x0019,
length=0x0002,
value{
Properties=0x0000
+14664 ms
Receive Event: ATT?ATT_WRITE_CFM{
lcid=0x0040,
result=0x0100,
errorHandle=0x0000
+14664 ms
+17659 ms
lcid=0x0040,
length=0x0002,
value{
Properties=0x0002
+17893 ms
lcid=0x0040,
result=0x0100,
errorHandle=0x0000
+17893 ms
+17893 ms
lcid=0x0040,
attributeHandle=0x0012,
length=0x0002,
value{
Properties=0x0000
+18065 ms
lcid=0x0040,
result=0x0100,
errorHandle=0x0000
+18065 ms
+21075 ms
lcid=0x0040,
length=0x0002,
value{
Properties=0x0001
+21216 ms
lcid=0x0040,
result=0x0100,
errorHandle=0x0000
+21216 ms
+21231 ms Send Event: ATT!ATT_READ_REQ{
lcid=0x0040,
attributeHandle=0x0014
+21387 ms
Receive Event: ATT?ATT_READ_CFM{
lcid=0x0040,
length=0x0004,
result=0x0100,
errorHandle=0x0000,
value{
CyclingPowerFeature=0x0019020A
+21387 ms
+21387 ms
Verdict Description: Read Request completed successfully.
+21387 ms
+21387 ms
Pass: The data received for 'Cycling Power Feature' conforms to the schema
+21387 ms
Verdict Description: The data received for 'Cycling Power Feature' conforms to the schema
+21419 ms
lcid=0x0040,
attributeHandle=0x0018,
length=0x0001,
value{
OpCode=0x0C,
CyclingPowerVectorControlValue=0x0063
+21653 ms
lcid=0x0040,
result=0x0100,
errorHandle=0x0000
+21653 ms
+22183 ms
Receive Event: ATT?ATT_HANDLE_VALUE_NOTIFICATION_REQ{
lcid=0x0040,
attributeHandle=0x0011,
length=0x000A,
attributeValue=0x00000000002B0000002C
+22183 ms
Receive Event: ATT?ATT_HANDLE_VALUE_IND{
lcid=0x0040,
length=0x0005,
attributeValue=0x00FFFF010C20
+22183 ms
+22183 ms
Pass: The value for 'Cycling Power Control Point' sent by the IUT was correctly formatted.
+22183 ms
Verdict Description: The value for 'Cycling Power Control Point' sent by the IUT was correctly formatted.
+23150 ms
lcid=0x0040,
length=0x000A,
+24196 ms
lcid=0x0040,
length=0x000A,
+25163 ms
lcid=0x0040,
length=0x000A,
+26208 ms
lcid=0x0040,
length=0x000A,
+27128 ms
Receive Event: HCI?HCI_LE_CONNECTION_UPDATE_COMPLETE_EVENT{
status=HCI_OK,
connInterval=0x0208,
connLatency=0x0000,
supervisionTimeout=0x0190
+27752 ms
lcid=0x0040,
length=0x000A,
+28408 ms
lcid=0x0040,
length=0x000A,
+29718 ms
lcid=0x0040,
length=0x000A,
attributeValue=0x00000000002C0000002C
+30358 ms
lcid=0x0040,
length=0x000A,
attributeValue=0x00000000002D0000002C
+31668 ms
lcid=0x0040,
length=0x000A,
+32308 ms
lcid=0x0040,
length=0x000A,
attributeValue=0x00000000002E0000002C
+33618 ms
lcid=0x0040,
length=0x000A,
+34258 ms
lcid=0x0040,
length=0x000A,
+35568 ms
lcid=0x0040,
length=0x000A,
attributeValue=0x00000000002F0000002C
+36208 ms
lcid=0x0040,
length=0x000A,
+37518 ms Receive Event: ATT?ATT_HANDLE_VALUE_NOTIFICATION_REQ{
lcid=0x0040,
length=0x000A,
attributeValue=0x0000000000300000002C
+38158 ms Receive Event: ATT?ATT_HANDLE_VALUE_NOTIFICATION_REQ{
lcid=0x0040,
length=0x000A,
+39468 ms
lcid=0x0040,
length=0x000A,
+40763 ms
lcid=0x0040,
length=0x000A,
attributeValue=0x0000000000310000002C
+41402 ms
lcid=0x0040,
length=0x000A,
attributeValue=0x0000000000320000002C
+42713 ms
lcid=0x0040,
length=0x000A,
+43368 ms
lcid=0x0040,
length=0x000A,
attributeValue=0x0000000000330000002C
+44663 ms
lcid=0x0040,
length=0x000A,
+45318 ms
lcid=0x0040,
length=0x000A,
attributeValue=0x0000000000340000002C
+46613 ms
lcid=0x0040,
length=0x000A,
+47268 ms
lcid=0x0040,
length=0x000A,
attributeValue=0x0000000000350000002C
+48563 ms
lcid=0x0040,
length=0x000A,
attributeValue=0x0000000000360000002C
+49218 ms
lcid=0x0040,
length=0x000A,
attributeValue=0x0000000000370000002C
+50513 ms
lcid=0x0040,
length=0x000A,
+51168 ms
lcid=0x0040,
length=0x000A,
attributeValue=0x0000000000380000002C
+52198 ms
Receive Event: ATT?ATT_TRANSACTION_TIMEOUT_IND{
lcid=0x0040,
primitiveTimeout=0xA81C
+52198 ms
Verdict Description: ATT Transaction timeout!
+52198 ms
Preliminary Verdict: INCONC
+52463 ms
lcid=0x0040,
length=0x000A,
attributeValue=0x0000000000390000002C
+52463 ms
Fail: Received notification or indication which is not expected.
+52463 ms
Verdict Description: Received notification or indication which is not expected.
+52478 ms
Send Event: ATT!ATT_DISCONNECT_REQ{
lcid=0x0040
+53758 ms
Receive Event: ATT?ATT_DISCONNECT_RSP{
lcid=0x0040,
result=0x0000
+53773 ms
Receive Event: HCI?HCI_LE_DISCONNECTION_COMPLETE_EVENT{
status=HCI_OK,
reason=HCI_CONNECTION_TERMINATED_BY_LOCAL_HOST
+53773 ms
+53773 ms
Verdict Description: Connection terminated successfully.
+55365 ms
Final Verdict: FAIL
+55365 ms
Encrypted Verdict:
A1#ZWY4MzQ5MDg3MmQwNTIxOGQzMzQ5YjY2ODA5M2MzNjQ5ZDY4NmY0Yjc2MzIzM2VkNTUyNTFhNGU4Mjg1MjI0NA==#S7tk81R4UBNybhi344ItZQcAkOV/VfJlJHVvJvU+j6Y/c1DeEcQgLNWpZq3KtxNv
+55365 ms
Test Case Ended: CPS/SEN/SPE/BI-05-C
Kiyoshi Iwai
