Unable to connect to nrf52840 dongle after "erase all" in Programmer
The set up which are used are a nRF52840 dongle programmed through nRF52832DK's debugger. After executing "erase all" in Programmer app, which erased the bootloader, it's not possible connect to the dongle. It should be right to assume that the nRF52840's flash was erased and not the DevKit's since the programmer identified correct hardware as 1Mb flash memory in Programmer app.
According to my understanding, I need to flash the bootloader again as stated in here: https://devzone.nordicsemi.com/f/nordic-q-a/37796/nrf52-dongle-can-t-program-with-segger-no-idcode-error-after-jlink-erase-all/147290#147290
Though I cannot make it work.
When trying to reinstall the bootloader in SES from path \nRF5_SDK_15.2.0\examples\dfu\open_bootloader\pca10059_usb\ses\Output\Release\Exe\bootloader.hex, following error message is received:
I have also tried to install the bootloader hex with nrfjprog by executing command "nrfjprog -f nrf52 --program \nRF5_SDK_15.2.0\examples\dfu\open_bootloader\pca10059_usb\ses\Output\Release\Exe\open_bootloader_usb_mbr_pca10059.hex --chiperase". This gives following error message:
How would you advice me to proceed?
  • Sorry for the delayed response. Did you remember to update the public key before building the open bootloader example? If not, you can run these two commands (found in this blog post):
    nrfutil.exe keys generate private.key
    nrfutil.exe keys display --key pk --format code private.key --out_file public_key.c
    Then, you can exclude the dfu_public_key.c from the build by Right clicking on it -> Exclude from Build. Next, build the open bootloader. I used the Release version in SES. Then, if the dongle is already erased, connect the swd cable to the dongle (the other end should be connected to a J-Link, such as on the 52 dev kit). The dongle needs to be connected to USB (it will not receive power from the SWD cable)
    Flash the softdevice to the dongle first via nrfjprog located here: nRF5_SDK_15.2.0_9412b96\components\softdevice\s140\hex\
    Then, flash the bootloader hex file. That should work without any issues. To test, I opened up nRF Connect Programmer app & read the flash. I could see this:
    which indicates that everything worked fine.
    Hope that helps! Kind Regards.
    Bjørn
  • hi, how do you manage to resolve the problem since the nRF52840 Dongle cannot be detected using Segger J-Link after it is erased fully because the nrfjprog.exe kept returning error as mentioned by you ?
  • hi Bjorn, the nrfjprog.exe totally failed reporting something like below:
    C:\Program Files\SEGGER\JLink>nrfjprog -v
    nrfjprog version: 10.13.0
    JLinkARM.dll version: 7.50a
    C:\Program Files\SEGGER\JLink>nrfjprog.exe -f NRF52 --program c:\scratch\graviton_bootloader_mbr_v1.0.1.hex --chiperase --log
    ERROR: [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
    ERROR: JLinkARM DLL reported an error. Try again. If error condition
    ERROR: persists, run the same command again with argument --log, contact Nordic
    ERROR: Semiconductor and provide the generated log.log file to them.
    THE .LOG FILE LOOK LIKE BELOW:
    [2021-Jul-19 19:56:35] [ info] --------------------------------------------------------------------------------
    [2021-Jul-19 19:56:35] [ info] nrfjprog.exe -f NRF52 --program c:\scratch\graviton_bootloader_mbr_v1.0.1.hex --chiperase --log
    [2021-Jul-19 19:56:35] [ info] nrfjprog version 10.13.0
    [2021-Jul-19 19:56:35] [ info] Load library at C:\Program Files (x86)\Nordic Semiconductor\nrf-command-line-tools\bin\nrfjprog.dll.
    [2021-Jul-19 19:56:35] [ info] Library loaded, loading member functions.
    [2021-Jul-19 19:56:35] [ info] Member functions succesfully loaded.
    [2021-Jul-19 19:56:35] [debug] [ Client] - open
    [2021-Jul-19 19:56:35] [debug] [ Client] - start
    [2021-Jul-19 19:56:35] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 60627e97-c7f0-4def-a767-b34e021156f9.
    [2021-Jul-19 19:56:35] [trace] [ Client] - Command open executed for 36 milliseconds with result 0
    [2021-Jul-19 19:56:35] [debug] [ Client] - enum_emu_snr
    [2021-Jul-19 19:56:35] [trace] [ Client] - Command enum_emu_snr executed for 15 milliseconds with result 0
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2021-Jul-19 19:56:35] [debug] [  JLink] - Logger sink registered in JLink logger
    [2021-Jul-19 19:56:35] [debug] [  nRF52] - open
    [2021-Jul-19 19:56:35] [debug] [ Client] - connect_to_emu_with_snr
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - open_dll
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2021-Jul-19 19:56:35] [ info] [SeggerBackend] - Load library at C:\Program Files\SEGGER\JLink\JLinkARM.dll.
    [2021-Jul-19 19:56:35] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2021-Jul-19 19:56:35] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - dll_version
    [2021-Jul-19 19:56:35] [ info] [SeggerBackend] - Segger dll version 7.50.a loaded.
    [2021-Jul-19 19:56:35] [trace] [ Worker] - Command open executed for 7 milliseconds with result 0
    [2021-Jul-19 19:56:35] [debug] [  nRF52] - enum_emu_snr
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - is_connected_to_emu
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - enum_emu_snr
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - ---just_get_num_emus
    [2021-Jul-19 19:56:35] [trace] [ Worker] - Command enum_emu_snr executed for 4 milliseconds with result 0
    [2021-Jul-19 19:56:35] [debug] [  nRF52] - connect_to_emu_with_snr
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - Segger logging enabled.
    [2021-Jul-19 19:56:35] [trace] [  JLink] - Firmware: J-Link V11 compiled Jun 29 2021 16:12:24
    [2021-Jul-19 19:56:35] [trace] [  JLink] - Decompressing FW timestamp took 165 us
    [2021-Jul-19 19:56:35] [trace] [  JLink] - Hardware: V11.00
    [2021-Jul-19 19:56:35] [trace] [  JLink] - S/N: 261011558
    [2021-Jul-19 19:56:35] [trace] [  JLink] - OEM: SEGGER-EDU
    [2021-Jul-19 19:56:35] [trace] [  JLink] - Feature(s): FlashBP, GDB
    [2021-Jul-19 19:56:35] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2021-Jul-19 19:56:35] [trace] [  JLink] - WEBSRV Starting webserver
    [2021-Jul-19 19:56:35] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 20.828ms returns "O.K."
    [2021-Jul-19 19:56:35] [trace] [  JLink] - JLINK_HasError()
    [2021-Jul-19 19:56:35] [trace] [  JLink] - JLINK_Lock()
    [2021-Jul-19 19:56:35] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.335ms returns 0
    [2021-Jul-19 19:56:35] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.004ms returns 0x01
    [2021-Jul-19 19:56:35] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.008ms returns 0x00
    [2021-Jul-19 19:56:35] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.005ms returns 0x00
    [2021-Jul-19 19:56:35] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2021-Jul-19 19:56:35] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.021ms returns 0
    [2021-Jul-19 19:56:35] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 1.329ms returns 0x00
    [2021-Jul-19 19:56:35] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.325ms
    [2021-Jul-19 19:56:35] [trace] [  JLink] - JLINK_GetSN()
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.008ms returns 261011558
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - read_debug_port_idr
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - read_debug_port_register
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - coresight_configure
    [2021-Jul-19 19:56:35] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 100.380ms returns 0
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2021-Jul-19 19:56:35] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.805ms returns -1
    [2021-Jul-19 19:56:35] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2021-Jul-19 19:56:35] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.816ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.711ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.872ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.679ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.812ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.840ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.808ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.682ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.689ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.681ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.686ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.661ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.675ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.639ms returns -1
    [2021-Jul-19 19:56:35] [trace] [ Client] - Command connect_to_emu_with_snr executed for 202 milliseconds with result -102
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.636ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.652ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.635ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.648ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.665ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.730ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.747ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.657ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.650ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.700ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.697ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.683ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.614ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.694ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.020ms
    [2021-Jul-19 19:56:35] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 195 milliseconds with result -102
    [2021-Jul-19 19:56:35] [debug] [  nRF52] - close
    [2021-Jul-19 19:56:35] [trace] [  JLink] - JLINK_IsOpen()
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.015ms returns 0x01
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - close
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - disconnect_from_emu
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - is_connected_to_device
    [2021-Jul-19 19:56:35] [trace] [  JLink] - JLINK_IsConnected()
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.008ms returns FALSE
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.684ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.696ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.734ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.647ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.653ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.663ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.792ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.658ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.676ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.625ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.621ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.693ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.588ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.742ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.622ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.605ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.603ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.707ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.640ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.600ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.701ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.660ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.678ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.721ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.642ms returns -1
    [2021-Jul-19 19:56:35] [trace] [  JLink] - - 0.035ms
    [2021-Jul-19 19:56:35] [trace] [  JLink] - JLINK_Close()
    [2021-Jul-19 19:56:35] [debug] [SeggerBackend] - Segger Backend closed.
    [2021-Jul-19 19:56:35] [debug] [  nRF52] - nRF family DLL closed
    [2021-Jul-19 19:56:35] [trace] [ Client] - Command close executed for 141 milliseconds with result 0
    [2021-Jul-19 19:56:35] [debug] [ Client] - terminate
    [2021-Jul-19 19:56:35] [trace] [ Client] - Command terminate executed for 0 milliseconds with result 0
    [2021-Jul-19 19:56:35] [trace] [ Worker] - Command close executed for 139 milliseconds with result 0
    [2021-Jul-19 19:56:35] [trace] [ Worker] - Command terminate executed for 0 milliseconds with result 0
    [2021-Jul-19 19:56:35] [trace] [ Worker] - Executed 5 commands for 345 milliseconds
    [2021-Jul-19 19:56:35] [debug] [ Client] - Worker process exited with code: 0
    [2021-Jul-19 19:56:35] [debug] [ Client] - Child process terminated with result 0
    [2021-Jul-19 19:56:35] [trace] [ Client] - Executed 5 commands for 394 milliseconds
    I am using genuine Segger J-Link Home to connect the SWDIO and SWCLK pins of the nRF52840 Dongle, either user USB power or soldered SB1 ( with SB2 broken ) with 3.3V supply to VDD, J-LINK VREF to 3.3V
    Please advise.
