I'm developing a custom driver (C++) for the SPI master. Somewhere I've made a mistake, where the first received byte is written with a memory offset in SPI mode 1. I.e. we expect the slave to return three bytes [0x0C 0xA3 0xC0], but we must read four bytes and we receive [0x?? 0x0C 0xA3 0x33]. We've verified with an oscilloscope that the slave responds as expected and that the SPI mode is correct and the slave is selected correctly.
To initiate the transfer we use this code:
// Static variables static constexpr uint8_t kBufferSize = 4U; static volatile rx_buffer[kBufferSize]; static volatile tx_buffer[kBufferSize]; // Transaction start // (Since we're only reading we could set the TX values to something more // elegant, but for simplicitly we set them explicitly) NRF_SPIM0->CONFIG = (SPIM_CONFIG_CPOL_ActiveHigh << SPIM_CONFIG_CPOL_Pos) | (SPIM_CONFIG_CPHA_Leading << SPIM_CONFIG_CPHA_Pos); NRF_SPIM0->TXD.PTR = reinterpret_cast<uint32_t>(tx_buffer); NRF_SPIM0->RXD.PTR = reinterpret_cast<uint32_t>(rx_buffer); NRF_SPIM0->TXD.MAXCNT = kBufferSize; NRF_SPIM0->RXD.MAXCNT = kBufferSize; NRF_SPIM0->TASKS_START = 0x01U; // Interrupt service routine NRF_SPIM0->EVENTS_END = 0U; NRF_SPIM0->EVENTS_STOPPED = 0U; NRF_SPIM0->EVENTS_ENDRX = 0U; NRF_SPIM0->EVENTS_ENDTX = 0U; NRF_SPIM0->EVENTS_STARTED = 0U; // Slave transmits [0x0C 0xA3 0xC0 0xFF] // Rx buffer contains [0x?? 0x0C 0xA3 0xC0]
