nRF52840 - sd_ble_gattc_exchange_mtu_request() returned NRF_ERROR_INVALID_PARAM.
Hi All.
I have modified the ble_app_multilink_central project, and replaced the button service LBS with the NUS service. When I switch on my peripheral device (based on the ble_app_uart project), then I get the following errors;
<info> app: Multilink example started.
<info> app: Start scanning for device name SWTG1.
<info> app: Name is a match
<error> nrf_ble_gatt: sd_ble_gattc_exchange_mtu_request() returned NRF_ERROR_INVALID_PARAM.
<info> app: Connection 0x0 established, starting DB discovery.
<error> nrf_ble_gatt: sd_ble_gatts_exchange_mtu_reply() returned NRF_ERROR_INVALID_PARAM.
<info> app: NUS service discovered on conn_handle 0x0
<info> app: Connected to device with Nordic UART Service.
<error> app: ERROR 17 [NRF_ERROR_BUSY] at C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\examples\ble_central\ble_app_multilink_central - Dock\main.c:205
PC at: 0x0002D60B
<error> app: End of error report
I have adjusted the ble connection parameters of both to match, and updated the NRF_SDH_BLE_GATT_MAX_MTU_SIZE  in the sdk_config (had to update the RAM start location after that update).
I have attached the main.c and config file. Is there anything obvious I have missed?
Thanks
 * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
 * @brief BLE LED Button Service central and client application main file.
 * This example can be a central for up to 8 peripherals.
 * The peripheral is called ble_app_blinky and can be found in the ble_peripheral
 * folder.
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "app_timer.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_db_discovery.h"
//#include "ble_lbs_c.h"
#include "ble_nus_c.h"
#include "ble_conn_state.h"
#include "nrf_ble_gatt.h"
#include "nrf_pwr_mgmt.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define APP_BLE_CONN_CFG_TAG      1                                     /**< A tag that refers to the BLE stack configuration we set with @ref sd_ble_cfg_set. Default tag is @ref APP_BLE_CONN_CFG_TAG. */
#define APP_BLE_OBSERVER_PRIO     3                                     /**< Application's BLE observer priority. You shouldn't need to modify this value. */
#define UART_TX_BUF_SIZE          256                                     /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE          256                                     /**< UART RX buffer size. */
#define CENTRAL_SCANNING_LED      BSP_BOARD_LED_0
#define CENTRAL_CONNECTED_LED     BSP_BOARD_LED_1
#define LEDBUTTON_LED             BSP_BOARD_LED_2                       /**< LED to indicate a change of state of the the Button characteristic on the peer. */
#define LEDBUTTON_BUTTON          BSP_BUTTON_0                          /**< Button that will write to the LED characteristic of the peer. */
#define BUTTON_DETECTION_DELAY    APP_TIMER_TICKS(50)                   /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
#define SCAN_INTERVAL             0x00A0                                /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW               0x0050                                /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION             0x0000                                /**< Duration of the scanning in units of 10 milliseconds. If set to 0x0000, scanning will continue until it is explicitly disabled. */
#define MIN_CONNECTION_INTERVAL   MSEC_TO_UNITS(20, UNIT_1_25_MS)      /**< Determines minimum connection interval in milliseconds. */
#define MAX_CONNECTION_INTERVAL   MSEC_TO_UNITS(100, UNIT_1_25_MS)       /**< Determines maximum connection interval in milliseconds. */
#define SLAVE_LATENCY             0                                     /**< Determines slave latency in terms of connection events. */
#define SUPERVISION_TIMEOUT       MSEC_TO_UNITS(4000, UNIT_10_MS)       /**< Determines supervision time-out in units of 10 milliseconds. */
uint16_t dataLength = 0;
uint16_t reportLength = 0;
uint8_t txPower = 0;
uint8_t rssi = 0;
uint8_t test2[];
uint32_t count = 0;
NRF_BLE_GATT_DEF(m_gatt);                                               /**< GATT module instance. */
BLE_NUS_C_ARRAY_DEF(m_nus_c, NRF_SDH_BLE_CENTRAL_LINK_COUNT);                                             /**< BLE NUS service client instance. */
//BLE_LBS_C_ARRAY_DEF(m_lbs_c, NRF_SDH_BLE_CENTRAL_LINK_COUNT);           /**< LED Button client instances. */
BLE_DB_DISCOVERY_ARRAY_DEF(m_db_disc, NRF_SDH_BLE_CENTRAL_LINK_COUNT);  /**< Database discovery module instances. */
static char const m_target_periph_name[] = "SWTG1";             /**< Name of the device we try to connect to. This name is searched for in the scan report data*/
static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
/**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */
static ble_data_t m_scan_buffer =
    m_scan_buffer_data,
/**@brief Scan parameters requested for scanning and connection. */
static ble_gap_scan_params_t const m_scan_params =
    .active   = 0,  //was 0
    .interval = SCAN_INTERVAL,
    .window   = SCAN_WINDOW,
    .timeout           = SCAN_DURATION,
    .scan_phys         = BLE_GAP_PHY_1MBPS,
    .filter_policy     = BLE_GAP_SCAN_FP_ACCEPT_ALL,
/**@brief Connection parameters requested for connection. */
static ble_gap_conn_params_t const m_connection_param =
    (uint16_t)MIN_CONNECTION_INTERVAL,
    (uint16_t)MAX_CONNECTION_INTERVAL,
    (uint16_t)SLAVE_LATENCY,
    (uint16_t)SUPERVISION_TIMEOUT
/**@brief Function to handle asserts in the SoftDevice.
 * @param[in] line_num     Line number of the failing ASSERT call.
 * @param[in] p_file_name  File name of the failing ASSERT call.
    app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for the LEDs initialization.
 * @details Initializes all LEDs used by the application.
static void leds_init(void)
/**@brief Function to start scanning. */
static void scan_start(void)
    ret_code_t ret;
    (void) sd_ble_gap_scan_stop();
    NRF_LOG_INFO("Start scanning for device name %s.", (uint32_t)m_target_periph_name);
    ret = sd_ble_gap_scan_start(&m_scan_params, &m_scan_buffer);
    APP_ERROR_CHECK(ret);
    // Turn on the LED to signal scanning.
    bsp_board_led_on(CENTRAL_SCANNING_LED);
/**@brief Callback handling NUS Client events.
 * @details This function is called to notify the application of NUS client events.
 * @param[in]   p_ble_nus_c   NUS Client Handle. This identifies the NUS client
 * @param[in]   p_ble_nus_evt Pointer to the NUS Client event.
/**@snippet [Handling events from the ble_nus_c module] */
static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
    ret_code_t err_code;
    switch (p_ble_nus_evt->evt_type)
        case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
            NRF_LOG_INFO("NUS service discovered on conn_handle 0x%x", p_ble_nus_evt->conn_handle);
            err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
            err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
            NRF_LOG_INFO("Connected to device with Nordic UART Service.");
        case BLE_NUS_C_EVT_NUS_TX_EVT:
            //ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
            NRF_LOG_DEBUG("Receiving data.");
            NRF_LOG_HEXDUMP_DEBUG(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
            //NRF_LOG_INFO("Data received : %X", p_ble_nus_evt->p_data);
//        case BLE_NUS_C_EVT_DISCONNECTED:
//            NRF_LOG_INFO("Disconnected.");
//            scan_start();
//            break;
/**@brief Function for handling the advertising report BLE event.
 * @param[in] p_adv_report  Advertising report from the SoftDevice.
static void on_adv_report(ble_gap_evt_adv_report_t const * p_adv_report)
//NRF_LOG_INFO("report rx'd");
    dataLength = p_adv_report->data.len;
    reportLength = sizeof(*p_adv_report);
    txPower = p_adv_report->tx_power;
    rssi = p_adv_report->rssi;
    //memcpy(test2, p_adv_report, sizeof(*p_adv_report));
    memcpy(test2, p_adv_report->data.p_data, p_adv_report->data.len);
    if (ble_advdata_name_find(p_adv_report->data.p_data,
                              p_adv_report->data.len,
                              m_target_periph_name))
        //Test code
        NRF_LOG_INFO("Name is a match");
        // Name is a match, initiate connection.
        err_code = sd_ble_gap_connect(&p_adv_report->peer_addr,
                                      &m_scan_params,
                                      &m_connection_param,
                                      APP_BLE_CONN_CFG_TAG);
        if (err_code != NRF_SUCCESS)
            NRF_LOG_ERROR("Connection Request Failed, reason %d", err_code);
        //NRF_LOG_INFO("Advertisment wasn't match to %s ", p_adv_report->data.p_data);// m_target_periph_name);
        err_code = sd_ble_gap_scan_start(NULL, &m_scan_buffer);
    // For readability.
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        // Upon connection, check which peripheral has connected, initiate DB
        // discovery, update LEDs status and resume scanning if necessary.
        case BLE_GAP_EVT_CONNECTED:
            NRF_LOG_INFO("Connection 0x%x established, starting DB discovery.",
                         p_gap_evt->conn_handle);
            APP_ERROR_CHECK_BOOL(p_gap_evt->conn_handle < NRF_SDH_BLE_CENTRAL_LINK_COUNT);
           // err_code = ble_lbs_c_handles_assign(&m_lbs_c[p_gap_evt->conn_handle],
                                          //      p_gap_evt->conn_handle,
                                         //       NULL);
            err_code = ble_nus_c_handles_assign(&m_nus_c[p_gap_evt->conn_handle],
                                                NULL);
            err_code = ble_db_discovery_start(&m_db_disc[p_gap_evt->conn_handle],
            if (err_code != NRF_ERROR_BUSY)
            // Update LEDs status, and check if we should be looking for more
            // peripherals to connect to.
            bsp_board_led_on(CENTRAL_CONNECTED_LED);
            if (ble_conn_state_central_conn_count() == NRF_SDH_BLE_CENTRAL_LINK_COUNT)
                bsp_board_led_off(CENTRAL_SCANNING_LED);
                // Resume scanning.
                scan_start();
        } break; // BLE_GAP_EVT_CONNECTED
        // Upon disconnection, reset the connection handle of the peer which disconnected, update
        // the LEDs status and start scanning again.
            NRF_LOG_INFO("NUS central link 0x%x disconnected (reason: 0x%x)",
                         p_gap_evt->params.disconnected.reason);
            if (ble_conn_state_central_conn_count() == 0)
                err_code = app_button_disable();
                // Turn off connection indication LED
                bsp_board_led_off(CENTRAL_CONNECTED_LED);
            // Start scanning
            scan_start();
            // Turn on LED for indicating scanning
        } break;
        case BLE_GAP_EVT_ADV_REPORT:
            on_adv_report(&p_gap_evt->params.adv_report);
        case BLE_GAP_EVT_TIMEOUT:
            // We have not specified a timeout for scanning, so only connection attemps can timeout.
            if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                NRF_LOG_DEBUG("Connection request timed out.");
        } break;
        case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
            NRF_LOG_DEBUG("BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST.");
            // Accept parameters requested by peer.
            err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                        &p_gap_evt->params.conn_param_update_request.conn_params);
        } break;
            ble_gap_phys_t const phys =
                .rx_phys = BLE_GAP_PHY_AUTO,
                .tx_phys = BLE_GAP_PHY_AUTO,
        } break;
        case BLE_GATTC_EVT_TIMEOUT:
        } break;
        case BLE_GATTS_EVT_TIMEOUT:
        } break;
            // No implementation needed.
/**@brief Function for initializing the NUS Client. */
static void nus_c_init(void)
    ble_nus_c_init_t nus_c_init_obj;
    nus_c_init_obj.evt_handler = ble_nus_c_evt_handler;
    for (uint32_t i = 0; i < NRF_SDH_BLE_CENTRAL_LINK_COUNT; i++)
        err_code = ble_nus_c_init(&m_nus_c[i], &nus_c_init_obj);
 * @details Initializes the SoftDevice and the BLE event interrupts.
    uint32_t ram_start = 0;
    // Enable BLE stack.
/**@brief Function for handling events from the button handler module.
 * @param[in] pin_no        The pin that the event applies to.
 * @param[in] button_action The button action (press/release).
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
    switch (pin_no)
        case LEDBUTTON_BUTTON:
            NRF_LOG_INFO("Button state %d", button_action);
            APP_ERROR_HANDLER(pin_no);
/**@brief Function for initializing the button handler module.
static void buttons_init(void)
   // The array must be static because a pointer to it will be saved in the button handler module.
    static app_button_cfg_t buttons[] =
        {LEDBUTTON_BUTTON, false, BUTTON_PULL, button_event_handler}
    err_code = app_button_init(buttons, ARRAY_SIZE(buttons), BUTTON_DETECTION_DELAY);
/**@brief Function for handling database discovery events.
 * @details This function is callback function to handle events from the database discovery module.
 *          Depending on the UUIDs that are discovered, this function should forward the events
 *          to their respective services.
 * @param[in] p_event  Pointer to the database discovery event.
static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
    NRF_LOG_DEBUG("call to ble_nus_on_db_disc_evt for instance %d and link 0x%x!",
                  p_evt->conn_handle,
    ble_nus_c_on_db_disc_evt(&m_nus_c[p_evt->conn_handle], p_evt);
/** @brief Database discovery initialization.
static void db_discovery_init(void)
    ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
 * @details Handle any pending log operation(s), then sleep until the next event occurs.
        nrf_pwr_mgmt_run();
/** @brief Function for initializing the log module.
static void log_init(void)
/** @brief Function for initializing the timer.
static void timer_init(void)
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
    ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
    // Initialize.
    log_init();
    timer_init();
    leds_init();
    buttons_init();
    power_management_init();
    ble_stack_init();
    gatt_init();
    db_discovery_init();
 //   lbs_c_init();
    nus_c_init();
    ble_conn_state_init();
    // Start execution.
    NRF_LOG_INFO("Multilink example started.");
    scan_start();
    for (;;)
        idle_state_handle();
sdk_config.h
  • Hi, I have changed the debug level and get this;
    <debug> ble_db_disc: Starting discovery of service with UUID 0x1 on connection handle 0x0.
    <debug> nrf_ble_gatt: Peer on connection 0x0 requested an ATT MTU of 247 bytes.
    <debug> nrf_ble_gatt: Updating ATT MTU to 247 bytes (desired: 4352) on connection 0x0.
    <debug> nrf_ble_gatt: Peer on connection 0x0 requested a data length of 251 bytes.
    <debug> nrf_ble_gatt: Updating data length to 182 on connection 0x0.
    <debug> nrf_ble_gatt: Data length updated to 182 on connection 0x0.
    <debug> nrf_ble_gatt: max_rx_octets: 182
    <debug> nrf_ble_gatt: max_tx_octets: 182
    <debug> nrf_ble_gatt: max_rx_time: 2120
    <debug> nrf_ble_gatt: max_tx_time: 2120
    <debug> ble_db_disc: Found service UUID 0x1.
    <debug> ble_db_disc: Found service UUID 0x0.
    <debug> app: call to ble_nus_on_db_disc_evt for instance 0 and link 0x0!
    <debug> ble_db_disc: Discovery of service with UUID 0x1 completed with success on connection handle 0x0.
    <error> app: ERROR 17 [NRF_ERROR_BUSY] at C:\Nordic_Semi\nRF5_SDK_15.0.0_a53641a\examples\ble_central\ble_app_multilink_central - Dock\main.c:215
    PC at: 0x0002D77D
  • Hi. I have just added the answer in this other question (link below), which has solved one issue of it crashing. Now the remaining issue seems to be that the MTU exchange fails, so the link disconnects after about 20 seconds.
    <info> app: NUS central link 0x0 disconnected (reason: 0x13)
    Here is the log.
    devzone.nordicsemi.com/.../multiple-connect-discover-service-multiple-why
  • Disconnect reason 0x13 (BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION) indicates that the device in the other end of the link (your peripheral) decided to disconnect. It could very well be because of the failed MTU update procedure.
    But I'm still not able to recreate the problem.
    1. Are you still using the same code as you have shown here, both on the peripheral and the central?
    2. Are you using SDK 15.0.0 on both applications?
    3. Are both devices nRF52840s?
    4. Are you using S140 v6.0.0 on both applications?
    Can you provide a sniffer log? If you have an extra Nordic dev kit to spare you can use our nRF Bluetooth Sniffer solution.
  • Hi, so it connects and stays connected ok for you?
    1 - Same code
    2 - nRF5_SDK_15.0.0_a53641a on both applications
    3 - Central is nRF52840 dev board, peripheral is nRF52832 dev board.
    4 - SD on the nRF52832 is S132, SD on the nRF52840 is S140.
    I don't have an extra dev kit to act as a sniffer. We could buy another I suppose.
  • I think my problem is definately something to do with this before the NRF_ERROR_INVALID_PARAM.
    Have no idea where the 4352 is coming from.
