Crash in the sd_mbr_command
I try to build the DFU with:
  1. S110 V7.0
  2. SDK 6.1
  3. Eclipse w/ GCC
  4. LEDs for DEBUG
  5. BOOTLOADER_REGION_START = 0x0003C000
And, always crash (no return) in the sd_mbr_command().
Code as below:
static void ble_stack_init(bool init_softdevice) {
uint32_t         err_code;
sd_mbr_command_t com = {SD_MBR_COMMAND_INIT_SD, };
nrf_gpio_pin_set(LED_1);
if (init_softdevice)
	nrf_gpio_pin_set(LED_2);
    err_code = sd_mbr_command(&com);
nrf_gpio_pin_set(LED_3);
err_code = sd_softdevice_vector_table_base_set(BOOTLOADER_REGION_START);
SOFTDEVICE_HANDLER_INIT(NRF_CLOCK_LFCLKSRC_XTAL_20_PPM, true);
  • LED_0 : ON (at start)
  • LED_1 : ON
  • LED_2 : ON
  • LED_3 : Never ON
What is the problem ?
