ERROR_INVALID_DATA at mesh DFU
Hi
I try to implement DFU to our application using Mesh_SDK 2.0.1 and
nRF5_SDK_15.0.0
When I use the DFU-Example everything works fine. I then implemented the
DFU-code from the example to our client application to be able to update it
(without provisioning of servers at the moment).
To program the device I use:
cd pc-nrfutil-mesh_dfu
nrfutil dfu genpkg --application
../../Source/connectivity_client/build/connectivity_client_Debug/connectivit
y_client.hex --company-id 0x00000059 --application-id 1
--application-version 1 --sd-req 0x00A9 --mesh client.zip
cd dfu
python device_page_generator.py -d nrf52840_xxAA -sd "s140_6.0.0" -o
../client.hex
cd ..
nrfjprog --eraseall
nrfjprog --program
../../Mesh_SDK/bin/softdevice/s140_nrf52_6.0.0_softdevice.hex --chiperase
nrfjprog --program
bootloader/mesh_bootloader_serial_gccarmemb_nrf52840_xxAA.hex
nrfjprog --program
y_client.hex
nrfjprog --program client.hex
nrfjprog --reset
For DFU I use:
--application-version 2 --sd-req 0x00A9 --mesh client.zip
cd dfu
../client.hex
cd ..
nrfutil --verbose dfu serial -pkg client.zip -p COM19 -b 115200 -fc --mesh
This seems to work in the beginning, but then throws an error:
Flushing com-port...
Opened com-port
Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0,
application size: 131356
Sending DFU start packet, afterwards we wait for the flash on target to be
initialized before continuing.
PC -> target: 0502aabbccdd
target -> PC: 0582aabbccdd
Got echo response
Sending DFU init packet
PC -> target: 1378fdff040fc9d339f459000000010005000000
target -> PC: 16a6045900000001000500000059000000010001000000
target -> PC: 03847800
PC -> target: 1478fcff0000c9d339f4ffffffff4780000000000c
Sending firmware file
[------------------------------------] 1% 00:11:50PC -> target:
1978fcff0100c9d339f400f0032059620200896202008b620200
target -> PC: 03847883
PC -> target: 1978fcff0100c9d339f400f0032059620200896202008b620200
target -> PC: 03847887
Failed to upgrade target. Error is: Device returned status code
ERROR_INVALID_DATA (135) on a DFU data packet.
What could be the problem here?
Kind regards
Gerry
  • when i pause the debug session, after this happens i get to the disassembler. Addr2line.exe gives no result for this address.
    the client seems to work relaying DFU but fails to update its own firmware.
  • Hi Terje
    When I run my scripts with the DFU_Example, it works, so my scripts seem to be ok.
    Then I compared the Log-output of the working DFU-Example and of my client.
    DFU-Example:
     0> <t:     707308>, nrf_mesh_dfu.c,  390,  New firmware!
     0> <t:     707311>, main.c,  127, DFU Firmware Outdated
     0> <t:     707313>, main.c,  130, DFU Update DFU request
     0> <t:     707316>, nrf_mesh_dfu.c,  528,  RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFD
     0> <t:     707319>, nrf_mesh_dfu.c,  534, Killing a TX slot prematurely (repeats done: 3).
     0> <t:     707323>, nrf_mesh_dfu.c,  561,  SERIAL TX!
     0> <t:     773536>, nrf_mesh_dfu.c,  528,  RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFD
     0> <t:     773540>, nrf_mesh_dfu.c,  534, Killing a TX slot prematurely (repeats done: 0).
     0> <t:     773544>, nrf_mesh_dfu.c,  561,  SERIAL TX!
     0> <t:     839642>, nrf_mesh_dfu.c,  430,  DFU start
     0> <t:     839645>, main.c,  145, DFU Start
     0> <t:     839647>, nrf_mesh_dfu.c,  528,  RADIO TX! SLOT 1, count 6, interval: exponential, handle: FFFC
     0> <t:     903019>, nrf_mesh_dfu.c,  329, Erase complete (0x41000)
     0> <t:     903022>, nrf_mesh_dfu.c,  333, Flash idle.
     0> <t:     970994>, nrf_mesh_dfu.c,  528,  RADIO TX! SLOT 2, count 3, interval: exponential, handle: FFFC
     0> <t:     971009>, nrf_mesh_dfu.c,  324, Write complete (0x2003FE90)
     0> <t:     971013>, nrf_mesh_dfu.c,  333, Flash idle.
     0> <t:     987713>, nrf_mesh_dfu.c,  528,  RADIO TX! SLOT 3, count 3, interval: exponential, handle: FFFC
     0> <t:     987725>, nrf_mesh_dfu.c,  324, Write complete (0x2003FE90)
     0> <t:     987728>, nrf_mesh_dfu.c,  333, Flash idle.
     0> <t:    1004452>, nrf_mesh_dfu.c,  528,  RADIO TX! SLOT 4, count 3, interval: exponential, handle: FFFC
     0> <t:    1004464>, nrf_mesh_dfu.c,  324, Write complete (0x2003FE90)
     0> <t:    1004467>, nrf_mesh_dfu.c,  333, Flash idle.
     0> <t:    1021170>, nrf_mesh_dfu.c,  528,  RADIO TX! SLOT 5, count 3, interval: exponential, handle: FFFC
     0> <t:    1021182>, nrf_mesh_dfu.c,  324, Write complete (0x2003FE90)
     0> <t:    1021186>, nrf_mesh_dfu.c,  333, Flash idle.
     0> <t:    1037914>, nrf_mesh_dfu.c,  528,  RADIO TX! SLOT 6, count 3, interval: exponential, handle: FFFC
     0> <t:    1037927>, nrf_mesh_dfu.c,  324, Write complete (0x2003FE90)
     0> <t:    1037930>, nrf_mesh_dfu.c,  333, Flash idle.
     0> <t:    1054665>, nrf_mesh_dfu.c,  528,  RADIO TX! SLOT 7, count 3, interval: exponential, handle: FFFC
     0> <t:    1054677>, nrf_mesh_dfu.c,  324, Write complete (0x2003FE90)
     0> <t:    1054681>, nrf_mesh_dfu.c,  333, Flash idle.
     0> <t:    1071736>, nrf_mesh_dfu.c,  528,  RADIO TX! SLOT 1, count 3, interval: exponential, handle: FFFC
     0> <t:    1071749>, nrf_mesh_dfu.c,  324, Write complete (0x2003FE90)
     0> <t:    1071752>, nrf_mesh_dfu.c,  333, Flash idle.
     0> <t:    1088808>, nrf_mesh_dfu.c,  528,  RADIO TX! SLOT 2, count 3, interval: exponential, handle: FFFC
     0> <t:    1088820>, nrf_mesh_dfu.c,  324, Write complete (0x2003FE90)
     0> <t:    1088824>, nrf_mesh_dfu.c,  333, Flash idle.
     0> <t:    1105543>, nrf_mesh_dfu.c,  528,  RADIO TX! SLOT 3, count 3, interval: exponential, handle: FFFC
     0> <t:    1105555>, nrf_mesh_dfu.c,  324, Write complete (0x2003FE90)
     0> <t:    1105559>, nrf_mesh_dfu.c,  333, Flash idle.
     0> <t:    1122268>, nrf_mesh_dfu.c,  528,  RADIO TX! SLOT 4, count 3, interval: exponential, handle: FFFC
     0> <t:    1122280>, nrf_mesh_dfu.c,  324, Write complete (0x2003FE90)
     0> <t:    1122283>, nrf_mesh_dfu.c,  333, Flash idle.
     My client:
     0> <t:     343469>, nrf_mesh_dfu.c,  390,  New firmware!
     0> <t:     343471>, mesh.c,  715, DFU Firmware Outdated
     0> <t:     343474>, mesh.c,  718, DFU Update DFU request
     0> <t:     343476>, nrf_mesh_dfu.c,  528,  RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFD
     0> <t:     343480>, nrf_mesh_dfu.c,  534, Killing a TX slot prematurely (repeats done: 2).
     0> <t:     343484>, nrf_mesh_dfu.c,  561,  SERIAL TX!
     0> <t:     409368>, nrf_mesh_dfu.c,  528,  RADIO TX! SLOT 0, count 255, interval: periodic, handle: FFFD
     0> <t:     409372>, nrf_mesh_dfu.c,  534, Killing a TX slot prematurely (repeats done: 0).
     0> <t:     409375>, nrf_mesh_dfu.c,  561,  SERIAL TX!
     0> <t:     475887>, nrf_mesh_dfu.c,  430,  DFU start
     0> <t:     475890>, mesh.c,  732, DFU Start
     0> <t:     475892>, nrf_mesh_dfu.c,  528,  RADIO TX! SLOT 5, count 6, interval: exponential, handle: FFFC
     0> <t:     566814>, nrf_mesh_dfu.c,  329, Erase complete (0x47000)
     0> <t:     566817>, nrf_mesh_dfu.c,  333, Flash idle.
     no further messages, client crashed here or at least doesn't listen to the UART no more. Might also be a tomeout.
    ROM-Info of the application:
    <t:      58439>, mesh.c,  597, rom_base   26101
    <t:      58441>, mesh.c,  598, rom_end    460FC
    <t:      58443>, mesh.c,  599, rom_length 1FFFB
    <t:      58445>, mesh.c,  600, bank_addr   47000
     What could lead to this? I compared my code to the DFU-Example, but I can't find the difference.
     Regards
     Gerry
  • Hi Terje
    If I power cycle the device after programming, the "Crash on first packet" disapears. Then I only have an ERROR_INVALID_DATA.
    The output now looks as follows:
    for programming i use:
      echo {
      echo     "bootloader_config": {
      echo        "bootloader_id": 1,
      echo        "bootloader_version": 1,
      echo        "company_id": 89,
      echo        "application_id": 1,
      echo        "application_version": 1
      echo    }
      echo }
    ) > bootloader_config_default.json
    python device_page_generator.py -d nrf52840_xxAA -sd "s140_6.0.0" -o ../client.hex
    cd ..
    nrfjprog --eraseall
    nrfjprog --program ../../Mesh_SDK/bin/softdevice/s140_nrf52_6.0.0_softdevice.hex --chiperase
    nrfjprog --program bootloader/mesh_bootloader_serial_gccarmemb_nrf52840_xxAA.hex
    nrfjprog --program ../../Source/connectivity_client/build/connectivity_client_Debug/connectivity_client.hex
    nrfjprog --reset
    For DFU:
    nrfutil dfu genpkg --application ../../Source/connectivity_client/build/connectivity_client_Debug/connectivity_client.hex --company-id 0x00000059 --application-id 1 --application-version 2 --sd-req 0x00A9 --mesh client.zip
    nrfutil --verbose dfu serial -pkg client.zip -p COM%Comport% -b 115200 -fc --mesh
    Can you see what's going wrong here?
    Regards
    Gerry
  • I'm having the same problem aswell, any leads ?
  • it seems that the erase sequence takes too much time. I explicitly added --i 500 to the dfu serial command and it seems to be working but it take 42 minutes to do DFU instead of 10 minutes.
    500ms is the default value based on the help!
