ERROR_INVALID_DATA at mesh DFU
Hi
I try to implement DFU to our application using Mesh_SDK 2.0.1 and
nRF5_SDK_15.0.0
When I use the DFU-Example everything works fine. I then implemented the
DFU-code from the example to our client application to be able to update it
(without provisioning of servers at the moment).
To program the device I use:
cd pc-nrfutil-mesh_dfu
nrfutil dfu genpkg --application
../../Source/connectivity_client/build/connectivity_client_Debug/connectivit
y_client.hex --company-id 0x00000059 --application-id 1
--application-version 1 --sd-req 0x00A9 --mesh client.zip
cd dfu
python device_page_generator.py -d nrf52840_xxAA -sd "s140_6.0.0" -o
../client.hex
cd ..
nrfjprog --eraseall
nrfjprog --program
../../Mesh_SDK/bin/softdevice/s140_nrf52_6.0.0_softdevice.hex --chiperase
nrfjprog --program
bootloader/mesh_bootloader_serial_gccarmemb_nrf52840_xxAA.hex
nrfjprog --program
y_client.hex
nrfjprog --program client.hex
nrfjprog --reset
For DFU I use:
--application-version 2 --sd-req 0x00A9 --mesh client.zip
cd dfu
../client.hex
cd ..
nrfutil --verbose dfu serial -pkg client.zip -p COM19 -b 115200 -fc --mesh
This seems to work in the beginning, but then throws an error:
Flushing com-port...
Opened com-port
Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0,
application size: 131356
Sending DFU start packet, afterwards we wait for the flash on target to be
initialized before continuing.
PC -> target: 0502aabbccdd
target -> PC: 0582aabbccdd
Got echo response
Sending DFU init packet
PC -> target: 1378fdff040fc9d339f459000000010005000000
target -> PC: 16a6045900000001000500000059000000010001000000
target -> PC: 03847800
PC -> target: 1478fcff0000c9d339f4ffffffff4780000000000c
Sending firmware file
[------------------------------------] 1% 00:11:50PC -> target:
1978fcff0100c9d339f400f0032059620200896202008b620200
target -> PC: 03847883
PC -> target: 1978fcff0100c9d339f400f0032059620200896202008b620200
target -> PC: 03847887
Failed to upgrade target. Error is: Device returned status code
ERROR_INVALID_DATA (135) on a DFU data packet.
What could be the problem here?
Kind regards
Gerry
    Although probably not related to the error, I see that the application version actually sent is version 5 (59000000010005000000), while the command suggest it should be version 2 (nrfutil dfu genpkg (...)
    --application-version 2 (...).)
    I see from the log that there are actually two errors. The latest one is ERROR_INVALID_DATA (135), in hexadecimal 0x87, and it happens four times:
    Before that there is error 0x83 ERROR_INVALID_STATE:
    The ERROR_INVALID_STATE may occur if the following was not handled correctly:
    This is the NRF_MESH_EVT_DFU_FIRMWARE_OUTDATED_NO_AUTH event.
    Is the handler added the same way as in the DFU example, and does it handle the NRF_MESH_EVT_DFU_FIRMWARE_OUTDATED_NO_AUTH case, also as in the DFU example, calling either nrf_mesh_dfu_request() or nrf_mesh_dfu_relay()? Failing to do so might lead to the invalid state experienced.
    Terje
  • Thanks for your response Terje
    I copied the code from your link into my project, to make sure everything is correct. I also put some log-messages into the events to see what happens on the client.
    At programming, my application-id is now set to 100, the application-version is set to 5
    nrfutil dfu genpkg --application ../../Source/connectivity_client/build/connectivity_client_Debug/connectivity_client.hex --company-id 0x00000059 --application-id 100 --application-version 5 --sd-req 0x00A9 --mesh client.zip
    python device_page_generator.py -d nrf52840_xxAA -sd "s140_6.0.0" -o ../client.hex
    At DFU, my application-id is now set to 100, the application-version is set to 6
    nrfutil dfu genpkg --application ../../Source/connectivity_client/build/connectivity_client_Debug/connectivity_client.hex --company-id 0x00000059 --application-id 100 --application-version 6 --sd-req 0x00A9 --mesh client.zip
    nrfutil --verbose dfu serial -pkg client.zip -p COM%Comport% -b 115200 -fc --mesh
    Opened com-port
    Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0, application size: 131912
    Sending DFU start packet, afterwards we wait for the flash on target to be initialized before continuing.
    Got echo response
    PC -> target: 1378fdff040f8feb68ab59000000640006000000
    target -> PC: 16a6045900000064000600000059000000010001000000
    PC -> target: 1478fcff00008feb68abffffffffd280000000000c
    target -> PC: 0da2020459000000640006000000
      [------------------------------------]    1%  00:11:51PC -> target: 1978fcff01008feb68ab00f0032059620200896202008b620200
    PC -> target: 1978fcff02008feb68ab8d6202008f6202009162020000000000
    PC -> target: 1978fcff03008feb68ab00000000000000000000000093620200
    The transfer works, but in my Log messages I can see, that in fw_updated_event_is_for_me() the app_id and app_version are wrong
    and the client tries to relay instead of request himself (application-id should be 100 at programming and DFU)
    Log-messages of the client:
     0> <t:     487812>, mesh.c,  715, DFU Firmware Outdated
     0> <t:     487814>, mesh.c,  688, DFU NRF_MESH_DFU_TYPE_APPLICATION current app_id: 1 transfer: 100
     0> <t:     487818>, mesh.c,  689, DFU NRF_MESH_DFU_TYPE_APPLICATION current company_id: 89 transfer: 89
     0> <t:     487821>, mesh.c,  690, DFU NRF_MESH_DFU_TYPE_APPLICATION current app_version: 1 transfer: 6
     0> <t:     487825>, mesh.c,  725, DFU Update DFU relay
     0> <t:     619917>, mesh.c,  732, DFU Start
     I had expected a current app_version: 5 and a current app_id: 100
     Can you see, what's wrong here?
     Kind regards
     Gerry
    I am a little confused why you run "nrfutil dfu genpkg" twice, if the first package is never used?
    Anyway, prior to running device_page_generator.py you need to edit bootloader_config_default.json with the correct company ID and application ID. See step 2 of the DFU quick start guide. (I see that you use our company ID of 89 (0x59) for now which I guess is fine at least for development and testing purposes.)
    Note that device_page_generator.py is used for generating the data stored on the device (describing the current (old) application), while nrfutil is used for generating the DFU package that you want to upgrade to.
    Terje
  • Hi Terje,
    Thanks for clarification on this, I didn't get this about bootloader_config_default.json
    Now it looks better, Id and version are correct and the cliet tries to update himself.
    Sadly I get an error: "Crashed on start packet"
    CMD-messages:
    Opened com-port
    Got echo response
    PC -> target: 1378fdff040fbc0512f559000000640006000000
    target -> PC: 16a6045900000064000600000059000000640005000000
    PC -> target: 1478fcff0000bc0512f5ffffffffd280000000000c
    Failed to upgrade target. Error is: Crashed on start packet
    Log-messages on the client:
     0> <t:     414697>, mesh.c,  715, DFU Firmware Outdated
     0> <t:     414700>, mesh.c,  688, DFU NRF_MESH_DFU_TYPE_APPLICATION current app_id: 100 transfer: 100
     0> <t:     414703>, mesh.c,  689, DFU NRF_MESH_DFU_TYPE_APPLICATION current company_id: 89 transfer: 89
     0> <t:     414707>, mesh.c,  690, DFU NRF_MESH_DFU_TYPE_APPLICATION current app_version: 5 transfer: 6
     0> <t:     414711>, mesh.c,  718, DFU Update DFU request
     0> <t:     547429>, mesh.c,  732, DFU Start
    The client has no assert, at least not in the RTT viewer
    Do you have an idea what could trigger this crash?
    rRegards
    GGerryf
    This sounds a bit strange. Can you do a debug session on the DFU target and see where it gets stuck? (I.e. if it does not go to an assert handler you can stop it and see if it is stuck somewhere.)
    Terje
