ERROR_INVALID_DATA at mesh DFU
Hi
I try to implement DFU to our application using Mesh_SDK 2.0.1 and
nRF5_SDK_15.0.0
When I use the DFU-Example everything works fine. I then implemented the
DFU-code from the example to our client application to be able to update it
(without provisioning of servers at the moment).
To program the device I use:
cd pc-nrfutil-mesh_dfu
nrfutil dfu genpkg --application
../../Source/connectivity_client/build/connectivity_client_Debug/connectivit
y_client.hex --company-id 0x00000059 --application-id 1
--application-version 1 --sd-req 0x00A9 --mesh client.zip
cd dfu
python device_page_generator.py -d nrf52840_xxAA -sd "s140_6.0.0" -o
../client.hex
cd ..
nrfjprog --eraseall
nrfjprog --program
../../Mesh_SDK/bin/softdevice/s140_nrf52_6.0.0_softdevice.hex --chiperase
nrfjprog --program
bootloader/mesh_bootloader_serial_gccarmemb_nrf52840_xxAA.hex
nrfjprog --program
y_client.hex
nrfjprog --program client.hex
nrfjprog --reset
For DFU I use:
--application-version 2 --sd-req 0x00A9 --mesh client.zip
cd dfu
../client.hex
cd ..
nrfutil --verbose dfu serial -pkg client.zip -p COM19 -b 115200 -fc --mesh
This seems to work in the beginning, but then throws an error:
Flushing com-port...
Opened com-port
Starting DFU upgrade of type 4, SoftDevice size: 0, bootloader size: 0,
application size: 131356
Sending DFU start packet, afterwards we wait for the flash on target to be
initialized before continuing.
PC -> target: 0502aabbccdd
target -> PC: 0582aabbccdd
Got echo response
Sending DFU init packet
PC -> target: 1378fdff040fc9d339f459000000010005000000
target -> PC: 16a6045900000001000500000059000000010001000000
target -> PC: 03847800
PC -> target: 1478fcff0000c9d339f4ffffffff4780000000000c
Sending firmware file
[------------------------------------] 1% 00:11:50PC -> target:
1978fcff0100c9d339f400f0032059620200896202008b620200
target -> PC: 03847883
PC -> target: 1978fcff0100c9d339f400f0032059620200896202008b620200
target -> PC: 03847887
Failed to upgrade target. Error is: Device returned status code
ERROR_INVALID_DATA (135) on a DFU data packet.
What could be the problem here?
Kind regards
Gerry
  • Hi, is it a problem of the size (318kB Hexfile) or can we solve this with the Flash_placement?
    <!DOCTYPE Linker_Placement_File>
    <Root name="Flash Section Placement">
      <MemorySegment name="FLASH" start="$(FLASH_PH_START)" size="$(FLASH_PH_SIZE)">
        <ProgramSection load="no" name=".reserved_flash" start="$(FLASH_PH_START)" size="$(FLASH_START)-$(FLASH_PH_START)" />
        <ProgramSection alignment="0x100" load="Yes" name=".vectors" start="$(FLASH_START)" />
        <ProgramSection alignment="4" load="Yes" name=".init" />
        <ProgramSection alignment="4" load="Yes" name=".init_rodata" />
        <ProgramSection alignment="4" load="Yes" name=".text" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_soc_observers" inputsections="*(SORT(.sdh_soc_observers*))" address_symbol="__start_sdh_soc_observers" end_symbol="__stop_sdh_soc_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_ble_observers" inputsections="*(SORT(.sdh_ble_observers*))" address_symbol="__start_sdh_ble_observers" end_symbol="__stop_sdh_ble_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".pwr_mgmt_data" inputsections="*(SORT(.pwr_mgmt_data*))" address_symbol="__start_pwr_mgmt_data" end_symbol="__stop_pwr_mgmt_data" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_const_data" inputsections="*(SORT(.log_const_data*))" address_symbol="__start_log_const_data" end_symbol="__stop_log_const_data" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_balloc" inputsections="*(.nrf_balloc*)" address_symbol="__start_nrf_balloc" end_symbol="__stop_nrf_balloc" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_state_observers" inputsections="*(SORT(.sdh_state_observers*))" address_symbol="__start_sdh_state_observers" end_symbol="__stop_sdh_state_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_stack_observers" inputsections="*(SORT(.sdh_stack_observers*))" address_symbol="__start_sdh_stack_observers" end_symbol="__stop_sdh_stack_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_req_observers" inputsections="*(SORT(.sdh_req_observers*))" address_symbol="__start_sdh_req_observers" end_symbol="__stop_sdh_req_observers" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_queue" inputsections="*(.nrf_queue*)" address_symbol="__start_nrf_queue" end_symbol="__stop_nrf_queue" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".cli_command" inputsections="*(.cli_command*)" address_symbol="__start_cli_command" end_symbol="__stop_cli_command" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".crypto_data" inputsections="*(SORT(.crypto_data*))" address_symbol="__start_crypto_data" end_symbol="__stop_crypto_data" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections" address_symbol="__start_nrf_sections" />
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_dynamic_data"  inputsections="*(SORT(.log_dynamic_data*))" runin=".log_dynamic_data_run"/>
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".fs_data"  inputsections="*(.fs_data*)" runin=".fs_data_run"/>
        <ProgramSection alignment="4" keep="Yes" load="Yes" name=".cli_sorted_cmd_ptrs"  inputsections="*(.cli_sorted_cmd_ptrs*)" runin=".cli_sorted_cmd_ptrs_run"/>
        <ProgramSection alignment="4" load="Yes" name=".dtors" />
        <ProgramSection alignment="4" load="Yes" name=".ctors" />
        <ProgramSection alignment="4" load="Yes" name=".rodata" />
        <ProgramSection alignment="4" load="Yes" name=".ARM.exidx" address_symbol="__exidx_start" end_symbol="__exidx_end" />
        <ProgramSection alignment="4" load="Yes" runin=".fast_run" name=".fast" />
        <ProgramSection alignment="4" load="Yes" runin=".data_run" name=".data" />
        <ProgramSection alignment="4" load="Yes" runin=".tdata_run" name=".tdata" />
      </MemorySegment>
      <MemorySegment name="RAM" start="$(RAM_PH_START)" size="$(RAM_SIZE)">
        <ProgramSection load="no" name=".reserved_ram" start="$(RAM_PH_START)" size="$(RAM_START)-$(RAM_PH_START)" />
        <ProgramSection alignment="0x100" load="No" name=".vectors_ram" start="$(RAM_START)" address_symbol="__app_ram_start__"/>
        <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run" address_symbol="__start_nrf_sections_run" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".log_dynamic_data_run" address_symbol="__start_log_dynamic_data" end_symbol="__stop_log_dynamic_data" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".fs_data_run" address_symbol="__start_fs_data" end_symbol="__stop_fs_data" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".cli_sorted_cmd_ptrs_run" address_symbol="__start_cli_sorted_cmd_ptrs" end_symbol="__stop_cli_sorted_cmd_ptrs" />
        <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run_end" address_symbol="__end_nrf_sections_run" />
        <ProgramSection alignment="4" load="No" name=".fast_run" />
        <ProgramSection alignment="4" load="No" name=".data_run" />
        <ProgramSection alignment="4" load="No" name=".tdata_run" />
        <ProgramSection alignment="4" load="No" name=".bss" />
        <ProgramSection alignment="4" load="No" name=".tbss" />
        <ProgramSection alignment="4" load="No" name=".non_init" />
        <ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" />
        <ProgramSection alignment="8" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack"  address_symbol="__StackLimit" end_symbol="__StackTop"/>
        <ProgramSection alignment="8" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" />
      </MemorySegment>
    </Root>
    FLASH_PH_START=0x0
    FLASH_PH_SIZE=0x100000
    RAM_PH_START=0x20000000
    RAM_PH_SIZE=0x40000
    FLASH_START=0x26000
    FLASH_SIZE=0xf8000
    RAM_START=0x200032c8
    RAM_SIZE=0x3f000
    Regards
    Gerry
    It is not the size of the hexfile itself, but the size of the data described therein. I.e. the final size of that bulk of data. If you have hard coded entries in for instance UICR, or otherwise outside of the contiguous binary that you download, which ends up in the hex file used for generating the update, then that will result in a large binary that will not fit. So if you have done something like that then yes, removing that from the binary may solve the issue.
    If not the above, then it may just be that the new firmware is too big to fit in flash in addition to the existing bootloader and SoftDevice.
    Terje
    I have some UICR-Code to set the voltage to 3.3V and I also found some in the SDK according the reset pin. After commenting this out, there is no change in behavior. I also checked the size in Segger Studio and compared it to the dfu_example, that works fine.
    my Client:
    dfu_example:
    There seems to be no big difference in size and this should easily fit into flash 2 times. Is there a Bootloader other than the standalone version to get more messages?
    regards
    Gerry
    Sorry, it is not two separate DFU bootloaders, but the behavior changes between the two modes: First mode is "bootloader DFU", where there is no other application on the device and so the bootloader runs the entire DFU process. Second mode is "side-by-side DFU", where the download happens through the application, in the background. This second mode will generate more events, which makes it easier to figure out what is the error. So in other words, for instance use the dfu example for starting the DFU from.
    Regarding the program, I agree there should be enough space. As long as the image is one contiguous binary, that is. I can have a look at the hex file and double check if you want to, but please note that this is a public thread so if it is confidential you should create a public ticket and share it with me there. (If you refer to this thread in that ticket then we will quickly find it.)
    Terje
    Thank you for the files sent through private ticket.
    I agree size should not be a matter there, as the firmware size is 113 kB and the nRF52840 has 1MB of Flash... Also I can confirm the hex file looks normal.
    I will ask our mesh team to have a look at the zipfile, in particular the manifest.json, to see if there is anything wrong with it.
    If I need to refer to anything in particular within the files that you sent, then I will continue the communication in that other thread. Feel free to do the same if you have additional confidential information.
    Terje
