How to reject buttonless DFU attempt ?
Is there a way to reject a buttonless DFU attempt (nRF52832, SDK14.2) ?
I want my application to allow DFU only when certain conditions are met.
I thought using case BLE_DFU_EVT_BOOTLOADER_ENTER_PREPARE: in ble_dfu_evt_handler().
However, since it does not return any value (void) I don't see a way to 'abort' the DFU attempt (without messing with the DFU service implementation).
Any thoughts?
Thanks
  • Hei eyalasko,
    Yes, the ble_dfu_evt_handler is only used to notify the application which state the DFU Service module is in, there's no events that needs to be confirmed etc. So I am afraid that you will have to modify the DFU service implementation to do this.
    You should be able to check if the conditions are met when the DFU_OP_ENTER_BOOTLOADER opcode is written to the Buttonless DFU Control point, see ble_dfu_buttonless_on_ctrl_pt_write() in ble_dfu_unbonded.c or ble_dfu_bonded.c if you support bonds.
    Best regards
    Bjørn
