BLED112 scanning but cannot connect
Hello I'm using the official example and BLED112 dongle with the demo from C:/Bluegiga/ble-1.60-140/src/thermometer-demo (main.c in attachment). The problem is that device is visible during scanning but i cannot connect to them via application. The BLED GUI connects without problems.
The device i'm trying to connect is nRF51 dev kit with Nordic uart example (nus).
Does anyone had similar problem ?
// Bluegiga’s Bluetooth Smart Demo Application
// Contact: [email protected].
// This is free software distributed under the terms of the MIT license reproduced below.
// Copyright (c) 2012, Bluegiga Technologies
// Permission is hereby granted, free of charge, to any person obtaining a copy of this
// software and associated documentation files (the "Software"),
// to deal in the Software without restriction, including without limitation
// the rights to use, copy, modify, merge, publish, distribute, sublicense,
// and/or sell copies of the Software, and to permit persons to whom the Software is
// furnished to do so, subject to the following conditions:
// The above copyright notice and this permission notice shall be included
// in all copies or substantial portions of the Software.
// THIS CODE AND INFORMATION ARE PROVIDED "AS IS" WITHOUT WARRANTY OF ANY KIND,
// EITHER EXPRESSED OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE IMPLIED WARRANTIES OF
// MERCHANTABILITY AND/OR FITNESS FOR A PARTICULAR PURPOSE.
//#include <unistd.h>
#include <stdlib.h>
#include <stdio.h>
#include <ctype.h>
#include <string.h>
#include <math.h>
#include "cmd_def.h"
#include "uart.h"
//#define DEBUG
#define CLARG_PORT 1
#define CLARG_ACTION 2
#define UART_TIMEOUT 1000
#define MAX_DEVICES 64
int found_devices_count = 0;
bd_addr found_devices[MAX_DEVICES];
enum actions {
    action_none,
    action_scan,
    action_connect,
    action_info,
enum actions action = action_none;
typedef enum {
    state_disconnected,
    state_connecting,
    state_connected,
    state_finding_services,
    state_finding_attributes,
    state_listening_measurements,
    state_finish,
    state_last
} states;
states state = state_disconnected;
const char *state_names[state_last] = {
    "disconnected",
    "connecting",
    "connected",
    "finding_services",
    "finding_attributes",
    "listening_measurements",
    "finish"
#define FIRST_HANDLE 0x0001
#define LAST_HANDLE  0xffff
#define THERMOMETER_SERVICE_UUID            0x1809
#define THERMOMETER_MEASUREMENT_UUID        0x2a1c
#define THERMOMETER_MEASUREMENT_CONFIG_UUID 0x2902
uint8 primary_service_uuid[] = {0x00, 0x28};
uint16 thermometer_handle_start = 0,
       thermometer_handle_end = 0,
       thermometer_handle_measurement = 0,
       thermometer_handle_configuration = 0;
bd_addr connect_addr;
void usage(char *exe)
    printf("%s <COMx|list> <scan|address>\n", exe);
void change_state(states new_state)
#ifdef DEBUG
    printf("DEBUG: State changed: %s --> %s\n", state_names[state], state_names[new_state]);
    state = new_state;
 * Compare Bluetooth addresses
 * @param first First address
 * @param second Second address
 * @return Zero if addresses are equal
int cmp_bdaddr(bd_addr first, bd_addr second)
    int i;
    for (i = 0; i < sizeof(bd_addr); i++) {
        if (first.addr[i] != second.addr[i]) return 1;
    return 0;
void print_bdaddr(bd_addr bdaddr)
    printf("%02x:%02x:%02x:%02x:%02x:%02x",
            bdaddr.addr[5],
            bdaddr.addr[4],
            bdaddr.addr[3],
            bdaddr.addr[2],
            bdaddr.addr[1],
            bdaddr.addr[0]);
void print_raw_packet(struct ble_header *hdr, unsigned char *data)
    printf("Incoming packet: ");
    int i;
    for (i = 0; i < sizeof(*hdr); i++) {
        printf("%02x ", ((unsigned char *)hdr)[i]);
    for (i = 0; i < hdr->lolen; i++) {
        printf("%02x ", data[i]);
    printf("\n");
void output(uint8 len1, uint8* data1, uint16 len2, uint8* data2)
    if (uart_tx(len1, data1) || uart_tx(len2, data2)) {
        printf("ERROR: Writing to serial port failed\n");
        exit(1);
int read_message(int timeout_ms)
    unsigned char data[256]; // enough for BLE
    struct ble_header hdr;
    int r;
    r = uart_rx(sizeof(hdr), (unsigned char *)&hdr, UART_TIMEOUT);
    if (!r) {
        return -1; // timeout
    else if (r < 0) {
        printf("ERROR: Reading header failed. Error code:%d\n", r);
        return 1;
    if (hdr.lolen) {
        r = uart_rx(hdr.lolen, data, UART_TIMEOUT);
        if (r <= 0) {
            printf("ERROR: Reading data failed. Error code:%d\n", r);
            return 1;
    const struct ble_msg *msg = ble_get_msg_hdr(hdr);
#ifdef DEBUG
    print_raw_packet(&hdr, data);
    if (!msg) {
        printf("ERROR: Unknown message received\n");
        exit(1);
    msg->handler(data);
    return 0;
void enable_indications(uint8 connection_handle, uint16 client_configuration_handle)
    uint8 configuration[] = {0x02, 0x00}; // enable indications
    ble_cmd_attclient_attribute_write(connection_handle, thermometer_handle_configuration, 2, &configuration);
void ble_rsp_system_get_info(const struct ble_msg_system_get_info_rsp_t *msg)
    printf("Build: %u, protocol_version: %u, hardware: ", msg->build, msg->protocol_version);
    switch (msg->hw) {
    case 0x01: printf("BLE112"); break;
    case 0x02: printf("BLED112"); break;
    default: printf("Unknown");
    printf("\n");
    if (action == action_info) change_state(state_finish);
void ble_evt_gap_scan_response(const struct ble_msg_gap_scan_response_evt_t *msg)
    if (found_devices_count >= MAX_DEVICES) change_state(state_finish);
    int i;
    char *name = NULL;
    // Check if this device already found
    for (i = 0; i < found_devices_count; i++) {
        if (!cmp_bdaddr(msg->sender, found_devices[i])) return;
    found_devices_count++;
    memcpy(found_devices[i].addr, msg->sender.addr, sizeof(bd_addr));
    // Parse data
    for (i = 0; i < msg->data.len; ) {
        int8 len = msg->data.data[i++];
        if (!len) continue;
        if (i + len > msg->data.len) break; // not enough data
        uint8 type = msg->data.data[i++];
        switch (type) {
        case 0x09:
            name = malloc(len);
            memcpy(name, msg->data.data + i, len - 1);
            name[len - 1] = '\0';
        i += len - 1;
    print_bdaddr(msg->sender);
    printf(" RSSI:%u", msg->rssi);
    printf(" Name:");
    if (name) printf("%s", name);
    else printf("Unknown");
    printf("\n");
    free(name);
void ble_evt_connection_status(const struct ble_msg_connection_status_evt_t *msg)
    // New connection
    if (msg->flags & connection_connected) {
        change_state(state_connected);
        printf("Connected\n");
        // Handle for Temperature Measurement configuration already known
        if (thermometer_handle_configuration) {
            change_state(state_listening_measurements);
            enable_indications(msg->connection, thermometer_handle_configuration);
        // Find primary services
        else {
            change_state(state_finding_services);
            ble_cmd_attclient_read_by_group_type(msg->connection, FIRST_HANDLE, LAST_HANDLE, 2, primary_service_uuid);
void ble_evt_attclient_group_found(const struct ble_msg_attclient_group_found_evt_t *msg)
    if (msg->uuid.len == 0) return;
    uint16 uuid = (msg->uuid.data[1] << 8) | msg->uuid.data[0];
    // First thermometer service found
    if (state == state_finding_services && uuid == THERMOMETER_SERVICE_UUID && thermometer_handle_start == 0) {
        thermometer_handle_start = msg->start;
        thermometer_handle_end = msg->end;
void ble_evt_attclient_procedure_completed(const struct ble_msg_attclient_procedure_completed_evt_t *msg)
    if (state == state_finding_services) {
        // Thermometer service not found
        if (thermometer_handle_start == 0) {
            printf("No Health Thermometer service found\n");
        // Find thermometer service attributes
        else {
            change_state(state_finding_attributes);
            ble_cmd_attclient_find_information(msg->connection, thermometer_handle_start, thermometer_handle_end);
    else if (state == state_finding_attributes) {
        // Client characteristic configuration not found
        if (thermometer_handle_configuration == 0) {
            printf("No Client Characteristic Configuration found for Health Thermometer service\n");
        // Enable temperature notifications
        else {
void ble_evt_attclient_find_information_found(const struct ble_msg_attclient_find_information_found_evt_t *msg)
    if (msg->uuid.len == 2) {
        if (uuid == THERMOMETER_MEASUREMENT_UUID) {
            thermometer_handle_measurement = msg->chrhandle;
        else if (uuid == THERMOMETER_MEASUREMENT_CONFIG_UUID) {
            thermometer_handle_configuration = msg->chrhandle;
#define THERMOMETER_FLAGS_FAHRENHEIT 0x1
void ble_evt_attclient_attribute_value(const struct ble_msg_attclient_attribute_value_evt_t *msg)
    if (msg->value.len < 5) {
        printf("Not enough fields in Temperature Measurement value");
    uint8 flags = msg->value.data[0];
    int8 exponent = msg->value.data[4];
    int mantissa = (msg->value.data[3] << 16) | (msg->value.data[2] << 8) | msg->value.data[1];
    float value = mantissa * pow(10, exponent);
    if (exponent >= 0)
        exponent = 0;
        exponent = abs(exponent);
    printf("Temperature: %.*f ", exponent, value);
    if (flags & THERMOMETER_FLAGS_FAHRENHEIT)
        printf("F");
        printf("C");
    printf("\n");
void ble_evt_connection_disconnected(const struct ble_msg_connection_disconnected_evt_t *msg)
    change_state(state_disconnected);
    printf("Connection terminated, trying to reconnect\n");
    change_state(state_connecting);
    ble_cmd_gap_connect_direct(&connect_addr, gap_address_type_public, 40, 60, 100,0);
int main(int argc, char *argv[]) {
    char *uart_port = "";
    // Not enough command-line arguments
    if (argc <= CLARG_PORT) {
        usage(argv[0]);
        return 1;
    // COM port argument
    if (argc > CLARG_PORT) {
        if (strcmp(argv[CLARG_PORT], "list") == 0) {
            uart_list_devices();
            return 1;
        else {
            uart_port = argv[CLARG_PORT];
    // Action argument
    if (argc > CLARG_ACTION) {
        int i;
        for (i = 0; i < strlen(argv[CLARG_ACTION]); i++) {
            argv[CLARG_ACTION][i] = tolower(argv[CLARG_ACTION][i]);
        if (strcmp(argv[CLARG_ACTION], "scan") == 0) {
            action = action_scan;
        else if (strcmp(argv[CLARG_ACTION], "info") == 0) {
            action = action_info;
        else {
            int i;
            short unsigned int addr[6];
            if (sscanf(argv[CLARG_ACTION],
                    "%02hx:%02hx:%02hx:%02hx:%02hx:%02hx",
                    &addr[5],
                    &addr[4],
                    &addr[3],
                    &addr[2],
                    &addr[1],
                    &addr[0]) == 6) {
                for (i = 0; i < 6; i++) {
                    connect_addr.addr[i] = addr[i];
                action = action_connect;
    if (action == action_none) {
        usage(argv[0]);
        return 1;
    bglib_output = output;
    if (uart_open(uart_port)) {
        printf("ERROR: Unable to open serial port\n");
        return 1;
    // Reset dongle to get it into known state
    ble_cmd_system_reset(0);
    uart_close();
    do {
        usleep(500000); // 0.5s
    } while (uart_open(uart_port));
    // Execute action
    if (action == action_scan) {
        ble_cmd_gap_discover(gap_discover_observation);
    else if (action == action_info) {
        ble_cmd_system_get_info();
    else if (action == action_connect) {
        printf("Trying to connect\n");
    // Message loop
    while (state != state_finish) {
        if (read_message(UART_TIMEOUT) > 0) break;
    uart_close();
    return 0;
