Nordic Uart Example RX Reset and multiple Peripherals
I currently use the uart-ble-central example with the 6.1.0 stack. I would like to make two changes.
1.) In the case of received data via Uart, the board jumps directly into the error case. Error 0x01 is stored in the error mask. Even after increasing the buffer size, this does not change. In addition, this case only occurs when the rx-pin is connected. The pure tx use works flawlessly.
2.) I would like to connect two peripherals with the central one. By adjusting the Counk_Links but no connection is possible.
Many thanks for your help.
  • Update: I have solved the connection problem by now. It works with the following code.
     * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    #include <stdio.h>
    #include <stdint.h>
    #include <stdbool.h>
    #include "nordic_common.h"
    #include "ble_conn_state.h"
    #include "app_error.h"
    #include "app_uart.h"
    #include "ble_db_discovery.h"
    #include "app_timer.h"
    #include "app_util.h"
    #include "bsp_btn_ble.h"
    #include "ble.h"
    #include "ble_gap.h"
    #include "ble_hci.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "ble_advdata.h"
    #include "ble_nus_c.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_drv_uart.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_ble_scan.h"
    #define APP_BLE_CONN_CFG_TAG    1                                       /**< A tag that refers to the BLE stack configuration we set with @ref sd_ble_cfg_set. Default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
    #define APP_BLE_OBSERVER_PRIO   3                                       /**< Application's BLE observer priority. You shoulnd't need to modify this value. */
    #define UART_TX_BUF_SIZE        1024                                     /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE        1024                                     /**< UART RX buffer size. */
    #define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN              /**< UUID type for the Nordic UART Service (vendor specific). */
    #define SCAN_INTERVAL           0x00A0                                  /**< Determines scan interval in units of 0.625 millisecond. */
    #define SCAN_WINDOW             0x0050                                  /**< Determines scan window in units of 0.625 millisecond. */
    #define SCAN_DURATION           0x0000                                  /**< Timout when scanning. 0x0000 disables timeout. */
    #define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS)         /**< Determines minimum connection interval in millisecond. */
    #define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS)         /**< Determines maximum connection interval in millisecond. */
    #define SLAVE_LATENCY           0                                       /**< Determines slave latency in counts of connection events. */
    #define SUPERVISION_TIMEOUT     MSEC_TO_UNITS(4000, UNIT_10_MS)         /**< Determines supervision time-out in units of 10 millisecond. */
    #define ECHOBACK_BLE_UART_DATA  1                                       /**< Echo the UART data that is received over the Nordic UART Service back to the sender. */
    BLE_NUS_C_ARRAY_DEF(m_ble_nus_c, NRF_SDH_BLE_CENTRAL_LINK_COUNT);                                             /**< BLE NUS service client instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                               /**< GATT module instance. */
    BLE_DB_DISCOVERY_ARRAY_DEF(m_db_disc, NRF_SDH_BLE_CENTRAL_LINK_COUNT);  /**< Database discovery module instances. */
    NRF_BLE_SCAN_DEF(m_scan);
    static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static uint8_t data_crc[BLE_NUS_MAX_DATA_LEN];
    void uart_event_handle(app_uart_evt_t * p_event);
    static char const m_target_periph_name[] = "Nordic_UART";
    /**@brief Connection parameters requested for connection. */
    static ble_gap_conn_params_t const m_connection_param =
        (uint16_t)MIN_CONNECTION_INTERVAL,  // Minimum connection
        (uint16_t)MAX_CONNECTION_INTERVAL,  // Maximum connection
        (uint16_t)SLAVE_LATENCY,            // Slave latency
        (uint16_t)SUPERVISION_TIMEOUT       // Supervision time-out
    static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
    /**@brief Pointer to the buffer where advertising reports will be stored by the SoftDevice. */
    static ble_data_t m_scan_buffer =
        m_scan_buffer_data,
    /** @brief Parameters used when scanning. */
    static ble_gap_scan_params_t const m_scan_params =
        .active   = 1,
        .interval = SCAN_INTERVAL,
        .window   = SCAN_WINDOW,
        .timeout          = SCAN_DURATION,
        .scan_phys        = BLE_GAP_PHY_1MBPS,
        .filter_policy    = BLE_GAP_SCAN_FP_ACCEPT_ALL,
    /**@brief NUS uuid. */
    static ble_uuid_t const m_nus_uuid =
        .uuid = BLE_UUID_NUS_SERVICE,
        .type = NUS_SERVICE_UUID_TYPE
    static void scan_evt_handler(scan_evt_t const * p_scan_evt)
        ret_code_t err_code;
        switch(p_scan_evt->scan_evt_id)
            case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
                err_code = p_scan_evt->params.connecting_err.err_code;
            } break;
    static void scan_init(void)
        nrf_ble_scan_init_t init_scan;
        memset(&init_scan, 0, sizeof(init_scan));
        init_scan.connect_if_match = true;
        init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
        err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
        err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, m_target_periph_name);
        err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
    /**@brief Function for asserts in the SoftDevice.
     * @param[in] line_num     Line number of the failing ASSERT call.
     * @param[in] p_file_name  File name of the failing ASSERT call.
        app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function to start scanning. */
    static void scan_start(void)
        ret_code_t ret;
        NRF_LOG_INFO("Start scanning for device name %s.", (uint32_t)m_target_periph_name);
        ret = nrf_ble_scan_start(&m_scan);
        APP_ERROR_CHECK(ret);
        // Turn on the LED to signal scanning.
        bsp_board_led_invert(BSP_BOARD_LED_3);
    /**@brief Function for handling database discovery events.
     * @details This function is callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function should forward the events
     *          to their respective services.
     * @param[in] p_event  Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
         NRF_LOG_DEBUG("call to ble_lbs_on_db_disc_evt for instance %d and link 0x%x!",
                      p_evt->conn_handle,
                      p_evt->conn_handle);
        ble_nus_c_on_db_disc_evt(&m_ble_nus_c[p_evt->conn_handle], p_evt);
    /**@brief Function for handling characters received by the Nordic UART Service.
     * @details This function takes a list of characters of length data_len and prints the characters out on UART.
     *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
    static uint32_t ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
        ret_code_t ret_val;
        uint8_t byte[1024] = {0};
        uint32_t check = 0;
        NRF_LOG_DEBUG("Receiving data.");
        NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
        for (uint32_t i = 0; i < data_len; i++)
            do
                ret_val = app_uart_put(p_data[i]);
                if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                    APP_ERROR_CHECK(ret_val);
            } while (ret_val == NRF_ERROR_BUSY);
        if (p_data[data_len-1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
        if (ECHOBACK_BLE_UART_DATA)
            // Send data back to peripheral.
            do
                ret_val = ble_nus_c_string_send(m_ble_nus_c, p_data, data_len);
                    NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
              byte[i] = p_data[i];
        bsp_board_led_invert(BSP_BOARD_LED_0);
        return nrf_drv_uart_tx(&app_uart_inst,byte,data_len);
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
        static uint16_t index = 0;
        uint8_t rx_byte;
        uint32_t ret_val;
        uint32_t get_state;
        switch (p_event->evt_type)
            /**@snippet [Handling data from UART] */
            case APP_UART_DATA_READY:
               do
                 get_state = app_uart_get(&rx_byte);
                 if(get_state == NRF_SUCCESS)
                   data_array[index] = rx_byte;
                   if( data_array[index] == 0x03  || index + 1 >= m_ble_nus_max_data_len )
                        if(m_ble_nus_c->conn_handle != BLE_CONN_HANDLE_INVALID)
                          do
                              ret_val = ble_nus_c_string_send(m_ble_nus_c, data_array, index);
                              if(0)
                        index = 0;
                      index++;
                      if(index > sizeof(data_array))
                        index = 0;
              while(get_state == NRF_SUCCESS);
                NRF_LOG_ERROR("Communication error occurred while handling UART.");
            case APP_UART_FIFO_ERROR:
                NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
    /**@brief Callback handling NUS Client events.
     * @details This function is called to notify the application of NUS client events.
     * @param[in]   p_ble_nus_c   NUS Client Handle. This identifies the NUS client
     * @param[in]   p_ble_nus_evt Pointer to the NUS Client event.
    /**@snippet [Handling events from the ble_nus_c module] */
    static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
        switch (p_ble_nus_evt->evt_type)
            case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
                NRF_LOG_INFO("Discovery complete.");
                err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
                err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
                NRF_LOG_INFO("Connected to device with Nordic UART Service.");
            case BLE_NUS_C_EVT_NUS_TX_EVT:
                ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
            case BLE_NUS_C_EVT_DISCONNECTED:
                NRF_LOG_INFO("Disconnected.");
                scan_start();
     * @brief Function for shutdown events.
     * @param[in]   event       Shutdown type.
    static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
        switch (event)
            case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
                // Prepare wakeup buttons.
        return true;
    NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
    /**@brief Function for handling the advertising report BLE event.
     * @param[in] p_adv_report  Advertising report from the SoftDevice.
    static void on_adv_report(ble_gap_evt_adv_report_t const * p_adv_report)
        NRF_LOG_INFO("Packet received");
        if (ble_advdata_name_find(p_adv_report->data.p_data,
                                  p_adv_report->data.len,
                                  m_target_periph_name))
            NRF_LOG_INFO("Device name found");
            err_code = sd_ble_gap_scan_start(NULL,&m_scan_buffer);
            //APP_ERROR_CHECK(err_code);
            err_code = sd_ble_gap_scan_start(NULL, &m_scan_buffer);
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
            case BLE_GAP_EVT_ADV_REPORT:
                on_adv_report(&p_gap_evt->params.adv_report);
                break; // BLE_GAP_EVT_ADV_REPORT
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connection 0x%x established, starting DB discovery.",
                             p_gap_evt->conn_handle);
                APP_ERROR_CHECK_BOOL(p_gap_evt->conn_handle < NRF_SDH_BLE_CENTRAL_LINK_COUNT);
                err_code = ble_nus_c_handles_assign(&m_ble_nus_c[p_gap_evt->conn_handle], p_ble_evt->evt.gap_evt.conn_handle, NULL);
                err_code = ble_db_discovery_start(&m_db_disc[p_gap_evt->conn_handle],
                // start discovery of services. The NUS Client waits for a discovery result
                err_code = ble_db_discovery_start(m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
                if (err_code != NRF_ERROR_BUSY)
                if (ble_conn_state_central_conn_count() == 2)
                    // Resume scanning.
                    bsp_board_led_on(BSP_BOARD_LED_3);
                    scan_start();
            case BLE_GAP_EVT_TIMEOUT:
                if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_SCAN)
                    NRF_LOG_INFO("Scan timed out.");
                    scan_start();
                else if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                    NRF_LOG_INFO("Connection Request timed out.");
                // Pairing not supported
                err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accepting parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                        &p_gap_evt->params.conn_param_update_request.conn_params);
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
            NRF_LOG_INFO("ATT MTU exchange completed.");
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in] event  Event generated by button press.
        switch (event)
            case BSP_EVENT_SLEEP:
                nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_ble_nus_c->conn_handle,
    /**@brief Function for initializing the UART. */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    /**@brief Function for initializing the NUS Client. */
    static void nus_c_init(void)
        ble_nus_c_init_t init;
        init.evt_handler = ble_nus_c_evt_handler;
        err_code = ble_nus_c_init(m_ble_nus_c, &init);
    /**@brief Function for initializing buttons and leds. */
    static void buttons_leds_init(void)
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
        err_code = bsp_init(BSP_INIT_BUTTONS, bsp_event_handler);
    /**@brief Function for initializing the timer. */
    static void timer_init(void)
    /**@brief Function for initializing the nrf log module. */
    static void log_init(void)
    /** @brief Function for initializing the Database Discovery Module. */
    static void db_discovery_init(void)
        ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
     * @details Handle any pending log operation(s), then sleep until the next event occurs.
            nrf_pwr_mgmt_run();
        // Initialize.
        log_init();
        timer_init();
        uart_init();
        buttons_leds_init();
        db_discovery_init();
        power_management_init();
        ble_stack_init();
        gatt_init();
        nus_c_init();
        scan_init();
        // Start execution.
        printf("BLE UART central example started.\r\n");
        NRF_LOG_INFO("BLE UART central example started.");
        scan_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
    However, only the Peripheral may send the first message to the Central. The connection is available for both
  • Commenting out APP_ERROR_CHECK(err_code) to circumvent a function that returns an error is a bold move, and a move that is likely to come back to haunt you. It is much better to figure out why the function returns an error to start with, and what to do about it.
    What happens in your case is that you are using the Scanning Module and in scan_init() you tell the module to auto-connect by setting connect_if_match set to true. If you dive into the code you can see that the module stops scanning whenever it auto-connects:
    static void nrf_ble_scan_connect_with_target(nrf_ble_scan_t           const * const p_scan_ctx,
                                                 ble_gap_evt_adv_report_t const * const p_adv_report)
        scan_evt_t scan_evt;
        // For readability.
        ble_gap_addr_t const        * p_addr        = &p_adv_report->peer_addr;
        ble_gap_scan_params_t const * p_scan_params = &p_scan_ctx->scan_params;
        ble_gap_conn_params_t const * p_conn_params = &p_scan_ctx->conn_params;
        uint8_t                       con_cfg_tag   = p_scan_ctx->conn_cfg_tag;
        // Return if the automatic connection is disabled.
        if (!p_scan_ctx->connect_if_match)
            return;
        // Stop scanning.
        nrf_ble_scan_stop();
    And as you mention this causes sd_ble_gap_scan_start() to return NRF_ERROR_INVALID_STATE because scanning is not running and p_scan_params is NULL.
    I suggest that you look at the BLE Multi-link Example and how it continues to scan using nrf_ble_scan_start(). Note also how it configures an array of m_lbs_c instances in lbs_c_init(). You should probably implement something similar for your array of m_ble_nus_c instances. This might solve your current problem.
